Mike had asked for this information and since I took the trouble to measure I thought others might be interested-
The lines I measured myself are in inches that I converted, the dimensions from Goodall's in metric that I converted to inches (in case my math is off!)-
Mine-
Spi sheets-
Large (21 sq m spi) - 3/8" x 45' 9mm x 13.7m
Small (17 sq m spi) - 3.8" x 39' 6" 9mm x 12m
Spectra upper halyard (used w/ double ended block in snuffer system ala the Tornado of Lars Guck) -
1/8" x 48' 3mm x 14.6m
Goodall's- (Came with their spi pole "set")-
Halyard- 5/32" x 72' 4mm x 22m
Rope brace (midpole between tangs)- 1/8" x 7' 6" 3mm x 2.3m
Rope brace (bridle to pole)- 1/8" x 2' 4" 3mm x 0.7m
Pole brace (end of pole to bows)- 5/32" x 10' 6" 4mm x 3.2m
Tack halyard- 5/32" x 16' 5" 4mm x 5m
I also measured my other sheets for the heck of it (that came with my boat)-
Jib sheets- (I would prefer these slightly longer personally)-
3/8" x 33' 9mm x 10.1m
Mainsheet- (7:1)- 3/8" x 36' 9mm x 11m
Hope this is of use to someone out there-
Kirt
