I20 Main sheet system? #73885
05/01/06 08:58 AM
05/01/06 08:58 AM
Crofton, MD
Chris9 Offline OP
Chris9  Offline OP
Crofton, MD
What blocks does the 10:1 system use?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: I20 Main sheet system? [Re: Chris9] #73886
05/01/06 09:40 AM
05/01/06 09:40 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
It uses a 5 block on the top and a 3+2 block on the bottom. A regular 3 with a becket on the bottom with a 2 block attached to the becket.
Mike Hill
www.stlouiscats.com
Mike Hill
N20 #1005
Re: I20 Main sheet system? [Re: Chris9] #73887
05/01/06 10:24 AM
05/01/06 10:24 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Chris,
Alec and I suggest you try this system. Put two together, you might 10:1. Or more. Or less.
Bitchin' Mainsheet Hardware
Re: I20 Main sheet system? [Re: Keith] #73888
05/01/06 06:19 PM
05/01/06 06:19 PM
Budapest, Hungary, Europe
CatSailingHu Offline
It is probably the same I got for my Nacra F18 (2005),
Check the pictures:
and
and
It is working really fine.
Best
Sanyi
www.catsailing.hu
Sanyi
Nacra Infusion
www.catsailing.hu
Re: I20 Main sheet system? [Re: CatSailingHu] #73889
05/01/06 11:29 PM
05/01/06 11:29 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Sanyi, can you describe the tapered(?) mainsheet set up, and where does the the sheet terminate on the lower blk?
Thanks!
Dave
Re: I20 Main sheet system? [Re: davefarmer] #73890
05/02/06 07:55 AM
05/02/06 07:55 AM
Crofton, MD
Chris9 Offline OP
Chris9  Offline OP
Crofton, MD
Sanyi, Thank you that, that’s what I was looking for.
Dave, I would guess the mainsheet dead ends by tying around or thru the block attached to the becket.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: I20 Main sheet system? [Re: davefarmer] #73891
05/02/06 08:12 AM
05/02/06 08:12 AM
you can get a pre-tapered I20 mainsheet from a couple of places online. They have the length of the taper pretty darn near figgered out.
Re: I20 Main sheet system? [Re: MauganN20] #73892
05/02/06 09:49 AM
05/02/06 09:49 AM
Northern Virginia
SoggyCheetoh Offline
Northern Virginia
Can you tell us which websites?
Alec D.
Pirates of the Chesapeake www.teampiratesofthechesapeake.com
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: I20 Main sheet system? (race Legal?) [Re: CatSailingHu] #73893
05/02/06 11:34 AM
05/02/06 11:34 AM
Houston, Texas
EasyReiter Offline
EasyReiter  Offline
Houston, Texas
Is the 10:1 now Class legal? (I am so out of the loop)
Marc Reiter I 20 #861 Dikes, Ferries and Tramps. www.texascitydike.com
Re: I20 Main sheet system? (race Legal?) [Re: EasyReiter] #73894
05/02/06 12:08 PM
05/02/06 12:08 PM
Yes - comes standard on the new Nacra 20s (and F18s).
Re: I20 Main sheet system? (race Legal?) [Re: Jake] #73895
05/02/06 12:30 PM
05/02/06 12:30 PM
Crofton, MD
Chris9 Offline OP
Chris9  Offline OP
Crofton, MD
Taken from INCA website Class Rules
http://www.nacraclass.com/northamerica/NAINDEX.htm
5.6a Main sheet purchase may not exceed 10:1 on any boat. Multiplier or
fine tuning systems (Magic Blocks) are illegal.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: I20 Main sheet system? [Re: SoggyCheetoh] #73896
05/02/06 02:14 PM
05/02/06 02:14 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Soggy Cheetoh:
Sites that offer tapered mainsheets:
www.Onlinemarinestore.com -Rick's very own site here has them
www.sailmax.biz
And of course, me...:)
Trey
Re: I20 Main sheet system? [Re: davefarmer] #73897
05/02/06 06:17 PM
05/02/06 06:17 PM
Dave,
lower block second picture:
From the Nacra I got the 3 blocks (up, down and the extra small one) and the tapered main sheet in the box.
After a half night of thinking finally I find out this solution to install…
Best regards,
Sanyi
Sanyi
Nacra Infusion
www.catsailing.hu
Re: I20 Main sheet system? [Re: CatSailingHu] #73898
05/03/06 11:59 PM
05/03/06 11:59 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Great! What is that blk attached to the becket, a carbo single? 29 or 40mm? What are the 2 line diameters, and the kind of line? I have a new carbo ratchamatic 8 to 1 that I'd like to convert to 10 to one, and I think I'm close. Thanks for the help!
Dave
Re: I20 Main sheet system? [Re: davefarmer] #73899
05/04/06 04:00 AM
05/04/06 04:00 AM
Australia
macca Offline
macca  Offline
Australia
lots of friction with that system even with the taper in the sheet.
why not use a cascading system inside the boom? much better to use, less than half the weight and cleaner boat as well.
attached is the system we use on the tornado and I cant see why it wouldnt work on a F18 / F20
________________________
http://aus300.blogspot.com
Re: I20 Main sheet system? [Re: macca] #73900
05/04/06 07:59 AM
05/04/06 07:59 AM
Macca,
Most of the F18s are going to the thin round booms that couldn't possibly support this sheeting arrangement...we will, however, be considering it on our rectangular boomed boat - thanks for the tip!
Re: I20 Main sheet system? [Re: davefarmer] #73901
05/04/06 01:09 PM
05/04/06 01:09 PM
Dave,
the attached blk is a 2650 BLK-40MM CARBO FIXED
the lines are swifcords, maybe 9mm and 5mm.
I also recommend you to order a pre-tapered sheet, because I agree with macca: the weak point of this solution is the tapered part of the sheet. It has to run smootly.
As Macca recommended you can also use boom-integrated sheet, as most of the T sailors, but I think it also has some (more) disadvantage.
First of all, you have to remove nerarly everything from the boom, clean it inside and also outside. Outhaull, rotator, negative rotator, etc.
Inside - of course you need a place for the running block
Ouside - yes, also - if there are rivet ends inside the boom, it can stop the running bolck.
In 2004 I visited a Volvo T race in Germany, and I made a few pictures, like this, and some additional.
That time I sailed an old Panthercraft Tornado so I converted my sheet soon. It is a 1:5 ouside x 1:2 inside.
Sanyi
Sanyi
Nacra Infusion
www.catsailing.hu
0 registered members (), 2,682 guests, and 704 spiders.
2 hours ago
