Battens #74081
05/03/06 10:35 AM
05/03/06 10:35 AM
Richmond Virginia
NACRADUDE Offline OP
Richmond Virginia
Where to go to get custom battens made for a EP square top?
Money can't buy you love, but it can rent it for a while
Re: Battens [Re: NACRADUDE] #74082
05/03/06 10:54 AM
05/03/06 10:54 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
Re: Battens [Re: tami] #74083
05/03/06 12:33 PM
05/03/06 12:33 PM
White Bear Lake, MN
h17racer Offline
h17racer  Offline
White Bear Lake, MN
What does your sailmaker recommend for optimum shape and for your use (race, recreational, both, etc.)?
They should be matched to the sail cut, material used, mast bend characteristics and typical winds you sail/race in.
Tom G
Re: Battens [Re: h17racer] #74084
05/03/06 09:50 PM
05/03/06 09:50 PM
toronto, canada
basket.case Offline
basket.case  Offline
toronto, canada
Re: Battens [Re: h17racer] #74085
05/03/06 11:35 PM
05/03/06 11:35 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
The EP Pentex sq top main I got last spring came with Performance Catbattens, available from Murray's.
dave
Re: Battens [Re: davefarmer] #74086
05/03/06 11:56 PM
05/03/06 11:56 PM
Dave:
I have these on my Sabre Pentex squaretop too. These are good battens.
Doug
Re: Battens [Re: h17racer] #74087
05/04/06 10:45 AM
05/04/06 10:45 AM
Richmond Virginia
Richmond Virginia
That's what I'm looking for. The foam battens at the lower three spots on the sail seem to me to not be able to shape the sail the way I would like. With a boomless main I get too much curve at the foot, which is giving me a crappy looking slot.
Re: Battens [Re: NACRADUDE] #74088
05/04/06 11:20 AM
05/04/06 11:20 AM
I have the boomless design as well and usually put the traveler on the clew almost all the way forward to pull the foot flatter. I think that does more than the batten type/tension
Re: Battens [Re: PTP] #74089
05/05/06 11:58 AM
05/05/06 11:58 AM
Richmond Virginia
Richmond Virginia
I have tried that but it seems to flatten the main more than I would like. Wouldn't some beefier battens in the lower three accomplish more without depowering the main.It doesn't seem right to depower for a better slot.
1 registered members (vasil), 504 guests, and 48 spiders.
