Cleating angle on Harken 6:1 blocks?? #74254
05/05/06 02:46 PM
05/05/06 02:46 PM
Ontario, Canada
Captain_Dave Offline OP
Ontario, Canada
Hey fellas,
I finally upgraded me ol`Seaway blocks to the Harken 6:1 setup. In an effort to minimize trial and error can anyone tell me a good starting point for the adjustable cleating angle?
Thanks
Dave
Re: Cleating angle on Harken 6:1 blocks?? [Re: Captain_Dave] #74255
05/05/06 05:59 PM
05/05/06 05:59 PM
California
mmiller Offline
mmiller  Offline
California
Set up the boat. Sails up and rig tensioned. Sheet as normal and test on the beach. Depends on mast rake, so no fixed adjustment is good from boat to boat. Higher jaws are safer, but harder to get in the cleat while on the wire. Lower will cleat as you sheet, but requires a good snap of the line to release.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Cleating angle on Harken 6:1 blocks?? [Re: Captain_Dave] #74256
05/06/06 10:03 AM
05/06/06 10:03 AM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
One to two holes up from all the way down.
BTW: It's almost impossible to uncleat if you go ALL the way down. You will likely flip in the first puff. Best to start two holes up and see how that works.
Re: Cleating angle on Harken 6:1 blocks?? [Re: rhodysail] #74257
05/08/06 01:40 PM
05/08/06 01:40 PM
Ontario, Canada
Ontario, Canada
Thanks Guys,
I`ve clearly set it too low to start with and it is fair to say that you`ve probably saved me fom an uneccessary swim in Lake Huron in May - one degree above freezing.
Dave
Re: Cleating angle on Harken 6:1 blocks?? [Re: Captain_Dave] #74258
05/09/06 03:59 PM
05/09/06 03:59 PM
Minnesota
Jeff Peterson Offline
Minnesota
Lake Huron??? So, THAT'S where you sail. For some reason, I thought you were from the Thunder Bay area.
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Cleating angle on Harken 6:1 blocks?? [Re: Jeff Peterson] #74259
05/09/06 05:29 PM
05/09/06 05:29 PM
Thunder Bay ON CAN
M
mmadge Offline
mmadge  Offline
M
Thunder Bay ON CAN
That would be me
Re: Cleating angle on Harken 6:1 blocks?? [Re: mmadge] #74260
05/10/06 08:11 AM
05/10/06 08:11 AM
Central Texas
yoh Offline
yoh  Offline
Central Texas
second to the lowest - tried for a while the lowest possition but had trouble with uncleating in situations where you need to release fast...
Patrick
Patrick, Hobie 16 '85
Re: Cleating angle on Harken 6:1 blocks?? [Re: yoh] #74261
05/10/06 09:37 AM
05/10/06 09:37 AM
Roanoke, VA
mattp Offline
mattp  Offline
Roanoke, VA
I have mine set on the next to lowest setting too and it still seems way too high. When I am trapped out, it feels like I have to pull the sheet over my head to be able to cleat it. This is surprising to me since I think my traps are set a little on the high side as I get more comfortable with trapping.
(Insert Witty Signature Here) 1988 H16
Re: Cleating angle on Harken 6:1 blocks?? [Re: mattp] #74262
05/10/06 11:48 AM
05/10/06 11:48 AM
Have you changed from the old mainsheet system (two bails on the boom)? If so, try putting the upper block on the forward bail.
0 registered members (), 6,227 guests, and 642 spiders.
