Castings seem loose #74761
05/10/06 10:36 AM
05/10/06 10:36 AM
Jeremy Offline OP
Jeremy  Offline OP
I was turning my H16 over to buff the hulls. I noticed that one of my hulls i could move back and forth slightly. It seems loose at the casting(I have included a pic of where it is). The other hull is strong and does not move. It seems that I might need to tighten that bolt that holds it on. Is this normal, If not what can I do to correct the problem?
Re: Castings seem loose [Re: Jeremy] #74762
05/10/06 11:45 AM
05/10/06 11:45 AM
The bolts shouldn't be tightened more than snug. Too tight and you'll break the casting.
You need to either shim the pylons or glue the boat. Do a forum seach on that - it's been discussed many times.
0 registered members (), 21,144 guests, and 562 spiders.
Yesterday at 04:54 AM
