| Re: Ordered My Blade
[Re: tau]
#75187 05/17/06 09:07 PM 05/17/06 09:07 PM |
Posts: 1,121 Eastern NC, USA | does anyone know where i can get a daggerboard bag/cover? I was thinking Taipan daggerboard covers would fit pretty good. Wouter, do you have a Blade nearby to compare board dimensions? and rudder?
Tom | | | Re: Ordered My Blade
[Re: tau]
#75188 05/17/06 09:26 PM 05/17/06 09:26 PM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | Its been too frustrating trying to snag the ring at the top. The ring and hook system works perfectly once you get it set up right. You have to experiment a lot with the many different ways the halyard can be tied to the ring. There's usually one combination that will work. I would pull the sail up, then get the Blade on it's side and get someone to pull on the halyard while you experiment at the top of the mast.
Tim Shepperd Mosquito 1775 Karma Cat
[Re: tshan]
#75190 05/18/06 04:32 AM 05/18/06 04:32 AM |
Posts: 9,582 North-West Europe | I was thinking Taipan daggerboard covers would fit pretty good. Wouter, do you have a Blade nearby to compare board dimensions? and rudder?
Dimensions are very much the same, the Blade daggerboards are just a little longer. I think the Taipan covers will work. Wouter
[Re: tau]
#75191 05/18/06 05:20 AM 05/18/06 05:20 AM | Anonymous
| Anonymous
Unregistered | Hi Tau,
I wouldn't use a halyard that locks at base of mast, you are adding compression loads to the mast you just don't need. A bit of persistence with the lock at the top is all that is required, once you get it sorted it is right for ever more. I use a push up luff which is said to be even more difficult than the halyard, but with persistence it now works well.
Regards Gary. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> | | | Re: Ordered My Blade
[Re: ]
#75192 05/18/06 05:48 AM 05/18/06 05:48 AM |
I don't think that a steel cable can handle the F16 loads, never mind the sheeve at the top.
On a F16 you can easily pull with 500 kg = 1100 lbs on the halyard ring and hook. I've broken two halyard shackles already and now sail with a beefed up Taipan 5.7 halyard shackle. This one is holding. There is no way any sheeve up the mast can hold that as it will be under twice this 500 kg load = 1000 kg = 2200 lbs.
Personally I have no troubles at all with my ring and hook system ones I tweaked it right. How you tie the halyard to the ring is indeed very important. There is a lengthy post about this in this F16 forum. I think it was covered about a year back. Look for it.
With regard to the 1:12 internal downhaul, get it. Best upgrade in the package
[Re: tau]
#75193 05/18/06 07:28 AM 05/18/06 07:28 AM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | does anyone know where i can get a daggerboard bag/cover? There's nothing easier than an old (or new if you'd like) pair of pants. Just slide a blade into each leg. You can take a few stitches here or there to make a custom fit or close the ankle. A stylish white belt and you're into the Florida retirement scene! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> | | | Re: Ordered My Blade
[Re: David Parker]
#75194 05/18/06 08:49 AM 05/18/06 08:49 AM |
Posts: 576 | That's the bomb man ,Groovy babe' Yeh! Start cutting wet suits there is no end in sight for this. My vote for "Mr. Recycle " of the Month............ does anyone know where i can get a daggerboard bag/cover? There's nothing easier than an old (or new if you'd like) pair of pants. Just slide a blade into each leg. You can take a few stitches here or there to make a custom fit or close the ankle. A stylish white belt and you're into the Florida retirement scene! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> | | | Re: Ordered My Blade
[Re: Rolf_Nilsen]
#75196 05/20/06 07:13 AM 05/20/06 07:13 AM |
Posts: 6,049 Sebring, Florida. | I had trouble getting the ring off until I bought one of those "Aussie Halyard Rings" which has the little tie loop on the inside of the ring, off to the side a bit, instead of the outside top of the ring. I pass the halyard through, tie a stopper knot on the outside and it has worked great ever since.
Also, I make sure I park the boat at a slight angle to the wind, maybe 20-30 degrees off dead up wind, to hold the main to one side of the boat, then rotate the mast in the other direction, it seems to help get the ring off the hook. I've been getting it unhooked the first try with the new halyard ring where it used to take me 4-5 attempts with the old one.
Blade F16 #777
20,439
guests, and 536
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 18 hours ago | | |
