Sail Tubes? #75224
05/15/06 04:09 PM
05/15/06 04:09 PM
dannno Offline OP
dannno  Offline OP
I'm into my second season looking for a sail tube and am still coming up empty. Just really looking for some 10 or 12 inch PVC to make my own. Any time I see any lying around, the contractor is not interested in selling. I've priced this stuff new, and at $10-12/foot it pretty pricy.
Don't think there are too many members from Central New York (Syracuse area), but does anybody have a line on some old PVC or an exisiting sail tube?
Danno
Re: Sail Tubes? [Re: dannno] #75225
05/15/06 05:12 PM
05/15/06 05:12 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Danno,
Did you check on the price of thinwall PVC, which is used for underground heat ducts in commercial buildings / cement slab houses. I think you can get 14" for around $9.00 a foot. Not cheap, but the extra diameter is a bonus. Check with a local HVAC contractor that does that type of work. Maybe they will have some left over from a job??
Jack
Re: Sail Tubes? [Re: jmhoying] #75226
05/15/06 06:32 PM
05/15/06 06:32 PM
Colorado
SteveT Offline
SteveT  Offline
Colorado
I've found the black drainage tubing like that used on highway projects and farms is the best bet. It is rigid and sturdy, and has a smooth inner liner. I got 10 feet of 18-inch diameter tubing with a cap on one end for about $100. It can hold three or four sails, my boom with blocks and line, a tiller, and rudder connecting arm. It doesn't get much cheaper than this.
H-20 #896
Re: Sail Tubes? [Re: SteveT] #75227
05/15/06 06:54 PM
05/15/06 06:54 PM
Where did you find it? Can you get it at Home Depot or Lowe's?
Doug
Re: Sail Tubes? [Re: ] #75228
05/15/06 07:57 PM
05/15/06 07:57 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Irrigation supply companies will have it.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Sail Tubes? [Re: hobie1616] #75229
05/16/06 02:50 PM
05/16/06 02:50 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
We handle the black corrugated pipe. It comes in various sizes, probably you will want the 12" double wall (smooth inside) with end plugs. They are manufactured by ADS (Advanced Drainage Systems) www dot ADS-Pipe dot com. Some local Home improvement stores will carry it. They come in 20' lengths, we sell 1/2 lengths but most do not cut them. As a ref. you can figure aro $5 per ft. plus the end plugs.
Too expensive to ship that so local will be the best bet. I've used that before and works well.
Clayton
Re: Sail Tubes? [Re: Clayton] #75230
05/16/06 07:04 PM
05/16/06 07:04 PM
dannno Offline OP
dannno  Offline OP
I'm glad you mentioned the black coragated pipe. That is available and less expensive then PVC. I was concerned about whether the black pipe has any residue that will get on my sails? Any streaking problems on the sail???
If not, that's probably the way I will go.
Danno
Danno
Re: Sail Tubes? [Re: dannno] #75231
05/17/06 09:06 AM
05/17/06 09:06 AM
Clayton Offline
Clayton  Offline
My sails were usually in a sail bag, but no problems as long as you keep the tube clean.
Re: Sail Tubes? [Re: dannno] #75232
05/17/06 02:36 PM
05/17/06 02:36 PM
Dunedin Causeway, FL
hobiephil Offline
hobiephil  Offline
I use 24" single wall ( fits 3 sails, booms, tiller extentions). Very light, very strong, corrugation allows damp sail to dry, tube does not mark sails.
Bonus, for 24" size tube, 32 gal garbage can top fits perfectly as end cap.
Re: Sail Tubes? [Re: hobiephil] #75233
05/17/06 04:22 PM
05/17/06 04:22 PM
Clayton Offline
Clayton  Offline
Where do you mount the 24" tube? I haven't measured but it seems like it wouldn't fit.
C
Re: Sail Tubes? [Re: Clayton] #75234
05/17/06 09:54 PM
05/17/06 09:54 PM
Colorado
SteveT Offline
SteveT  Offline
Colorado
The ADS tubes are the ticket. Get a semi-permanant cap for the front and mount it so the "bell" end is facing the back and make a removable cap for the back and you're set. Mine has been in use for four seasons with no signs of wear.
H-20 #896
Re: Sail Tubes? [Re: SteveT] #75235
05/18/06 07:43 AM
05/18/06 07:43 AM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
I like to line the inside with something like astro-turf so that the bags slide in better and are up off the tube itself. Just 2 cents.
0 registered members (), 4,150 guests, and 676 spiders.
