mast rake #75844
05/22/06 02:09 PM
05/22/06 02:09 PM
Chesapeake va
C
catsailor2032 Offline OP
C
Chesapeake va
can anyone tell me the proper mast rake on an inter 20 and how do i measure it thanks
Sailing catana411. i20
Re: mast rake [Re: catsailor2032] #75845
05/25/06 10:59 AM
05/25/06 10:59 AM
I would think it depends on a few factors:
Diamond wire tension
Spreader Rake
Team weight
Wind conditions
Distance/bouy race
Easiest way to measure is to rig the boat, take a trapeze line and a short stretch of line. Attach the line to the end of the trapeze and walk it up to the front spinaker bridle attachment point (on the inside of the hull). Stretch the trapeze/line and mark where it meets the bridle attachment.
Now, walk that to the back of the boat and see where that length touches the boat. I prefer to have the rudder in the up position, as my rake setting puts the trapeze/line right about 1 foot behind the hull on the trailing edge of the rudder.
I sail with about 340 lbs, spreader rake at 1 3/4" and about 700 lbs diamond tension in 15 kts breeze, for distance sailing
I go with a little less rake, diamond tension, and spreader rake for bouys in light stuff...
Hope it helps!
Re: mast rake [Re: catsailor2032] #75846
05/28/06 02:16 PM
05/28/06 02:16 PM
You could look at this trimguide from nacra europe, although its intended for use with the new Nacra 20 mainsail it should be good for a basic setup.
http://www.nacraeurope.com/news_details.php?id=23
0 registered members (), 300 guests, and 46 spiders.
