Page 1 of 6 1 2 3 4 5 6
Blade Trailer Layout #76230
05/28/06 05:29 PM
05/28/06 05:29 PM
Orange County, CA, USA
JJD Offline OP
JJD  Offline OP
Hello:
I'm new to this forum and soon to the F16 and Blade community. I've just sent in a deposit on a boat to Vector Works.
I'll be getting a trailer locally, Orange County, CA, so need to know what I should be looking for. Do any of you have a good photo of a well thought out trailer for a Blade?
What is the distance between the centerlines on the hulls?
Where is best place to support the hulls?
I home built my first fiberglass cat in 1965 and have owned a B-Lion, Tornado and presently a Shark. I'm looking forward to a boat I can actually beach launch by myself!
John, Shark US 421, soon to be Blade #?
Re: Blade Trailer Layout [Re: JJD] #76231
05/28/06 07:04 PM
05/28/06 07:04 PM
I'd talk to Matt about this. His trailers have double rollers on the back and cradles in the front. See if he will supply you with those.
I've only trailered a few hundred miles with this set up, but no complaints so far.
I'll get you some pictures in the next few days.
Robi: What do you have on hand?
Re: Blade Trailer Layout [Re: fin.] #76232
05/28/06 10:09 PM
05/28/06 10:09 PM
I dont have any photos sorry guys.
My trailer was a hobie 16 trailer. I removed all rollers and I have two rear home made cradles, and the two front cradles are Vector Works Special Edition blade cradles. Make sure you ask for the special edition cradles. Tell Matt, I sent you. lol <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Blade Trailer Layout [Re: Robi] #76233
05/28/06 10:31 PM
05/28/06 10:31 PM
Victoria, Australia
C2 Mike Offline
C2 Mike  Offline
Victoria, Australia
Hi Guys,
I recommend what is quoted above. On my trailer I have the normal roller on the back and then a removable cradle that slips over it to support the hull once the boat is on the trailer. Rollers alone can gradualy wear the hull at the point that they touch over time.
Tiger Mike
Re: Blade Trailer Layout [Re: C2 Mike] #76234
05/29/06 03:58 AM
05/29/06 03:58 AM
I have cradles in the front as well and rollers at the back. I too have removable cradles that fit on top of the rollers at the back. I fit these before I start driving. So my boat rests on 4 cradles. Many aussies prefer to not have the hulls be touched by the trailer and suspend the boat on its beams. I finally decided to go with the cradle option and my hulls are surviving very well indeed. I have a timber hulled F16. Spread the load out well and you'll be fine.
The rollers make it very easy for a singlehanded sailor to load and unload the boat (singlehandedly)
Re: Blade Trailer Layout [Re: C2 Mike] #76235
05/29/06 04:01 AM
05/29/06 04:01 AM
Tiger Mike,
I would do the same if I supported my boat on its hulls when on the trailer. There is not much weight on the rear when on the trailer still I wouldn' let them sit on rollers while trailering.
At the very least I'd slip some pads between the hulls and rollers.
Welcome John, please put your location pin on ... [Re: JJD] #76236
05/29/06 04:01 AM
05/29/06 04:01 AM
Welcome to the F16 class John, please put your location pin on our world map at :
http://www.frappr.com/formula16classgroup
Best of enjoyment with your new boat !
Re: Blade Trailer Layout [Re: JJD] #76237
05/29/06 09:34 AM
05/29/06 09:34 AM
Here ya' go! Blame Robi for the bad pix. He insulted my camera as an antique and it hasn't worked right since! <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Trailer Dimensions:
overall length- 240"
cross bar width- 96"
rear bar set forward- 15"
front bar set forward of rear bar-68 1/2"
Re: Blade Trailer Layout [Re: JJD] #76238
05/29/06 09:36 AM
05/29/06 09:36 AM
side view
Re: Blade Trailer Layout [Re: fin.] #76239
05/29/06 09:38 AM
05/29/06 09:38 AM
side
Re: Blade Trailer Layout [Re: fin.] #76240
05/29/06 09:39 AM
05/29/06 09:39 AM
cradle
Re: Blade Trailer Layout [Re: fin.] #76241
05/29/06 09:40 AM
05/29/06 09:40 AM
cradle again
Re: Blade Trailer Layout [Re: fin.] #76242
05/29/06 09:41 AM
05/29/06 09:41 AM
rollers
Re: Blade Trailer Layout [Re: fin.] #76243
05/29/06 09:42 AM
05/29/06 09:42 AM
roller again
Re: Blade Trailer Layout [Re: fin.] #76244
05/29/06 09:45 AM
05/29/06 09:45 AM
rear
Re: Blade Trailer Layout [Re: fin.] #76245
05/29/06 10:48 AM
05/29/06 10:48 AM
Very nice Pete, but what stops your boat from moving sideways off the rear rollers? (apart from the tiedown)
Re: Blade Trailer Layout [Re: Jalani] #76246
05/29/06 11:59 AM
05/29/06 11:59 AM
Nothing.
Re: Blade Trailer Layout [Re: JJD] #76247
05/29/06 12:05 PM
05/29/06 12:05 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Here's a rubbish photo of my trailer. I use 4 cradles, no rollers as I'm not a big fan of putting rounded hulls onto a flat roller, and anyway, it's pretty easy to get the boat onto cradles single-handed.
I don't normally put it on the trailer backwards. It's something I tried once, but it's easier to get on and off the other way round.
Cradles are from Vectorworks. The only thing to watch out for is to make sure that you have enough clearance below the dolphin striker if you're going to put a box on the trailer. As you can see, I've got some extra 50mm x 50mm on the arms to lift it up a bit, and to give a wider base to bolt the cradles to.
The arms are adjustable and can be removed which makes it less hassle to tow without the boat or leave in a crowded car park. Also, it adds a little more greyness to the legally grey area of towing 2.5m wide loads in the UK (as in, "the trailer's only 2m wide, officer, it's just that the load is overhanging" <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> )
Re: Blade Trailer Layout [Re: pdwarren] #76248
05/29/06 08:37 PM
05/29/06 08:37 PM
Arkansas, USA
C
CaptainKirt Offline
CaptainKirt  Offline
C
Arkansas, USA
Jim Boyer and Greg Goodall strongly recommend trailering the Taipans (and their Flyers and Auscats) supported by the beams not the hulls. To that end I made up a front beam support for my Taipan that bolts to a "standard" cat trailer and a rear mast support that also supports the boat by the rear beam (there is very little load on the rear beam, as you can imagine most of the weight centers very close to the "front" beam- which is actually very close to the middle of the boat). I'll try to attach a photo.
Kirt
Kirt Simmons
Taipan, Flyer
Re: Blade Trailer Layout [Re: CaptainKirt] #76249
05/29/06 08:48 PM
05/29/06 08:48 PM
Arkansas, USA
C
CaptainKirt Offline
CaptainKirt  Offline
C
Arkansas, USA
Here's hopefully a photo of the rear support- note the cat wheels are used as the rear "cradles" when loading the boat (actually I place the wheels under the rear beam and tie off, lift the boat by one bow and wheel to the trailer- load the bows on the front cradles then walk to back of boat, lift boat and wheels and slide boat up until the front beam touches it's "cradles" and set the wheels down in their "cradles", then go forward and lift boat slightly and pull forward so front beam supports boat. Then place rear mast step which also traps wheels, untie wheels and use a line to lace rear beam up to mast stand. Mast is lowered over the front into telescoping mast stand utilizing mainsheet blocks to assist in lowering.)
Kirt
Kirt Simmons
Taipan, Flyer
0 registered members (), 16,525 guests, and 861 spiders.
Most Online22,490
Yesterday at 08:14 AM
