| Re: self tacking jib???
[Re: SunnyZ]
#76483 05/31/06 10:02 PM 05/31/06 10:02 PM |
Posts: 215 Ohio | Yep... no pin and don't drill the ball... I won't tell you to hold down on the mast but that is what everyone does <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Mike, Ohio Former H16, H18, N20, N17, M4.3
[Re: SunnyZ]
#76485 05/31/06 10:14 PM 05/31/06 10:14 PM |
Joined: Mar 2003 Posts: 736 Westport, Ma. U.S.A. Brian_Mc
Posts: 736 Westport, Ma. U.S.A. | Wendy, Congrats on the new vessel! I don't know the Mystere, but on my Hobie there's a pin to put through the mast base when raising or lowering. It goes through below the socket for the ball, and creates a sort of lock. I would hope that any newer boat would have something like this. Another thing to consider when righting, I once flipped in a gust as I leaned over to pull on my downhall, I never did cleat it. Went for a swim first. As the boat righted, the main came unhooked, and came down. I couldn't get it back up on the water by myself, but luckily had a friend jump aboard to help. So I'm not too keen on releasing the downhall... The 4.3 looks like a great boat. Have fun! | | | Re: self tacking jib???
[Re: Mike Fahle]
#76487 06/01/06 07:05 AM 06/01/06 07:05 AM |
Posts: 12,310 South Carolina | but managed to drop it on Mosley's head the first time I tried. Word on the street is that this was intentional. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Jake Kohl | | | Re: self tacking jib???
#76488 06/01/06 07:10 AM 06/01/06 07:10 AM |
Joined: Feb 2006 Posts: 169 Upstate, South Carolina SunnyZ OP
Posts: 169 Upstate, South Carolina | but managed to drop it on Mosley's head the first time I tried. Word on the street is that this was intentional. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> I may have been a little irritated with him later on but not at that particular moment. LOL. I really felt bad. Okay...I will push down on the mast to raise it like David told me to. (Mosley was right again. That is getting irritating) Just be careful if you are the one behind me. The hole for the pin in the base of the mast is too high to go under the ball. It lines up with the widest diameter of it. I won't worry about it anymore. | | | Re: self tacking jib???
[Re: SunnyZ]
#76489 06/01/06 07:16 AM 06/01/06 07:16 AM |
Posts: 12,310 South Carolina | (Mosley was right again. That is getting irritating) I know that's right. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
#76490 06/01/06 09:31 AM 06/01/06 09:31 AM |
Posts: 1,253 Columbia South Carolina, USA | do you not remember who pulls your mainsheet, jib, and spinnaker in at your request, every time, sometimes in a timely manner? I may be irritatingly right sometimes, but I work hard! Wendy, we'll get you a pin next time, dont worry...
[Re: SunnyZ]
#76491 06/01/06 10:08 AM 06/01/06 10:08 AM |
Posts: 1,121 Eastern NC, USA | In lieu of using the pin (NACRA called them captive mast steps), you could also use a spare line to tie the mast base to the dolphin striker post (bowline around the post and a bowline around the mast rotator or something on the base of the mast). This would act like a safety harness when the mast pops off the ball - b/c it will pop off the ball. The base of the mast will pop up, but will catch on the line and you should be able to recover. Remember to leave a little bit of slack in the line so that you can lower the mast all the way. IMO, lowering the mast without some sort of "catch" is an accident waiting to happen.
Tom | | | Re: self tacking jib???
[Re: SunnyZ]
#76493 06/01/06 08:27 PM 06/01/06 08:27 PM |
Posts: 364 | On my Nacras, I'd always use a Philips screwdriver of about the right diameter and length when my pin was missing (usually, in other words). When derigging, make sure the handle is on the side that's going UP! Good luck.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
#76494 06/01/06 09:54 PM 06/01/06 09:54 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | If you are close to righting the boat, try this:
Tie a loop in the righting line so that you can hook your trapeze harness to it and be in somewhat of a position to right the boat. Use a Glad bag/contractor bag to scoop water and sit in your lap. It works best if you fill the bag between your knees, pull it out of the water just enough to get it on your shins/knees and voila the boat comes right up. I am about 10 pounds shy of righting my boat and this has worked every time.
Call it the Alabama Trash Righting System (ATRS).
t connecting myself to anything while righting gives me the willies. I'm fine with knots in the rope to facilitate easier handling, but getting tangled underneath the boat worries me...it once caused me enough delay for the boat to turn and accelerate before I could get on board. Sounds like a fair point. I usually put a couple of wraps around my hook so that once I let go of the righting rope it immediatly falls off. Tiger Mike | | |
2,640
guests, and 390
