| Re: self tacking jib???
[Re: SunnyZ]
#76466 05/30/06 08:02 PM 05/30/06 08:02 PM |
Posts: 149 Long Island, NY | Congratulations...
I'd get to know the boat a little first before spending money. There may be other upgrades you will benefit from more but you haven't realized those yet...
Thomas
Mystere 6.0
[Re: SunnyZ]
#76467 05/30/06 08:45 PM 05/30/06 08:45 PM |
Posts: 1,121 Eastern NC, USA | If you are close to righting the boat, try this:
Tie a loop in the righting line so that you can hook your trapeze harness to it and be in somewhat of a position to right the boat. Use a Glad bag/contractor bag to scoop water and sit in your lap. It works best if you fill the bag between your knees, pull it out of the water just enough to get it on your shins/knees and voila the boat comes right up. I am about 10 pounds shy of righting my boat and this has worked every time.
Call it the Alabama Trash Righting System (ATRS).
t
Tom | | | Re: self tacking jib???
[Re: tshan]
#76469 05/30/06 09:12 PM 05/30/06 09:12 PM |
Posts: 12,310 South Carolina | If you are close to righting the boat, try this:
t connecting myself to anything while righting gives me the willies. I'm fine with knots in the rope to facilitate easier handling, but getting tangled underneath the boat worries me...it once caused me enough delay for the boat to turn and accelerate before I could get on board.
Jake Kohl | | | Re: self tacking jib???
[Re: SunnyZ]
#76470 05/31/06 02:14 AM 05/31/06 02:14 AM |
Posts: 3,348 | I saw some foam knee pads at Lowe's for @ $5. Also, one of the drills at Rick's seminar was to sail standing up. You might want to try it. Happy sailing! | | | Re: self tacking jib???
[Re: SunnyZ]
#76471 05/31/06 03:06 AM 05/31/06 03:06 AM |
Posts: 1,449 | Sunny, I you take the idea of learning to drive a manual car and apply it to sailing your new boat when considering tacking the equivalent would probably be to remove the jib for a while. I don't know your boat as we don't have them in Australia but generally speaking boats are harder to tack without a jib. Once you are doing perfect tacks add the jib.
It really is more difficult to right a boat in no wind. When you have wind and you turn the boat into the breese it generates lift on the sails as they come out of the water and this helps get the rig out of the water and into the air.
I tie knots in my righting line every 12 or 14 inches. Just one wrap around my trap hook and the knot stops the line. As the boat starts to come up I can grab the line and another knot helps me pull the line to slip it along to the next knot. This would also work with a righting bag with your free hand. I would not like to have a loop on the righting line. I have had the boat right itself and take off because the tiller and main sheet were tangled up. This would be bad if I was hooked up under the boat.
Another thing is to let the downhaul off before righting. That way when the boat comes up the main is less likely to develop lift and either take off or flog violently in heavy wind. Basically it just makes the boat more docile in the newly righted position. Of course you would already be letting the mainsheet and traveller off. Hope you enjoy your new boat. One last thing .........next time don't forget the pictures.
Hope this helps. Regards, Phill
[Re: phill]
#76472 05/31/06 03:38 AM 05/31/06 03:38 AM |
Posts: 1,382 Essex, UK | Congrats on the new toy Wendy, and what Phill said goes for me too! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
In addition see if you can pressure test your mast for leaks and search this forum for how best to solve those leaks that you'll inevitably find.
Even a pint of water sitting in the top of your mast when capsized takes a hell of a lot of effort to lift. (No doubt some of our more geeky forum members will provide us with an exact calc of effort required for a 4.3 with a pint of water in the mast <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />)
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: self tacking jib???
[Re: SunnyZ]
#76474 05/31/06 07:43 AM 05/31/06 07:43 AM |
Posts: 12,310 South Carolina | The bag is usually hung from the upper hull (tied and thrown over the hull) and has some sort of purchase system on it (3:1 or similar). You lower the rope putting the bag in the water, then you hoist the bag up a bit using the 3:1 (so if you have 100lbs of water in it, it's like pulling 33lbs on the rope). Then you use your righting line like normal but try to get the waterbag behind your shoulders - you push the bag outwards and it helps add to your weight. Seriously though, I bet you will be able to right the boat without the righting bag.
Say, are you going to bring that new ride to the Reggae Regatta at Lake Lanier in a couple of weeks!?
[Re: SunnyZ]
#76476 05/31/06 10:14 AM 05/31/06 10:14 AM |
Posts: 3,293 Long Beach, California | Hi Sunny -
The self-tacking jib is indeed class legal and I considered one as well. In the time it took me to decide if one was right for me, I got so used to sailing without it that I stopped worrying about it. Bill Gillespie mounted a self-tacker on two boats, I think - he bent the tracks himself and it looked like it would work just fine.
On the matter of learning to tack - don't waste your time taking the jib off. That actually makes it harder. The beauty of that tiny jib is that you can leave it cleated on the wrong side and it won't bother you too much - what I mean is that you don't have to frantically rush to break it free on one side to sheet it in on the other.
My learning curve was this: in the beginning, I would start my tack by footing just a bit for a little squirt of speed, then turning steadily (but not slamming it over) up through the wind holding the mainsheet right next to the cleat. As soon as the mainsail went slack, I uncleated the main and moved to the other side of the boat so I could look forward again at the jib, which I haven't touched yet. Having the jib stay cleated will help you get the nose of the boat around, but it isn't so big as to cause a problem (like flipping <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />). I watched the jib fill up on the wrong side of the boat and felt the mainsheet play out a little bit, maybe a little less than a foot. Once I could *feel* the jib backwinding, I would straighten out the rudders and cleat the main where it was. Only then would I reach forward and break the jib free, sheeting it in hard and quick on the new leeward side. Then I would sheet the main in and steer up for speed. Once I got going, I'd take a look at sail trim to see if the jib was set ok.
This is NOT an incredibly fast tack, but it was how I learned and I got quicker and quicker tacking every time I sailed and got used to the feeling of the boat turning through the wind and powering back up after the tack. By the time Nationals came around, I had it down to one smooth quick series of motions as I crossed under the main.
If you take the jib off, I think you'll be learning the way some Hobie 14 sailors did - crank the rudders over and back through the tack. There's nothing wrong with learning that way, too, but you have a jib so you might as well use it. Plus, the boat goes uphill sooooo much better with the jib on. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> I did an event once without the jib and it was waaaay less fun.
Enjoy the practice.
[Re: SunnyZ]
#76479 05/31/06 12:07 PM 05/31/06 12:07 PM |
Posts: 2,921 Michigan | Wendy- try it sometime. Head somewhat off of close hauled and let all your sails flap- you will still be moving but not fast obviously. grab the boom with your hand and pull it towards you without steering and you will feel the boat head up. then do the same with the jib and you will feel the bows head off. It has to do with the center of effort in the sail relative to the daggerboards/center of resistance of the boat.
2,688
guests, and 504
