| Re: Volvo Extreme 40 specs?
[Re: Wouter]
#76727 06/08/06 10:24 AM 06/08/06 10:24 AM |
Joined: Jun 2004 Posts: 141 Panama City Beach, FL steveh
Posts: 141 Panama City Beach, FL |
So you are saying that a Navy Frigat doing 35 knots with its twin 10.000 HP gas turbine engines at full throttle (expending just over 1 liter fuel per second) is in planing mode ?
Speed itself doesn't determine wether you plane or not. The hulls shape has to be designed to go up on a plane otherwise you pretty much stay in displacement mode.
Remember the very old assie 18 skiffs ? Before the introduction of the planing hulls ? Same sailarea and still they couldn't get up to a plane.
Hull speed of a 450 ft LOA FFG-7 class frigate is going to be about 27 kn. Published max speed for the FFG is 29 kn, so not planing. However, a 40 ft cat (hull speed 8.5 kn) at 30+ kn is not acting as a displacement hull and if it's not planing, then it must be in the "fourth mode." | | | Re: Volvo Extreme 40 specs?
[Re: steveh]
#76728 06/08/06 10:29 AM 06/08/06 10:29 AM |
Posts: 9,582 North-West Europe | I still derives by far most of it's "gravitational suspension" due to archimedes law therefor it is still in its displacement mode.
Bethwaite invented some extra modes, but that is a different topic.
[Re: Wouter]
#76729 06/08/06 10:42 AM 06/08/06 10:42 AM |
Posts: 1,382 Essex, UK | then it must be in the "fourth mode." Please, please don't go anywhere near mentioning HWSNBN!! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Volvo Extreme 40 specs?
[Re: Jalani]
#76730 06/08/06 10:58 AM 06/08/06 10:58 AM |
Posts: 545 Brighton, UK | It is very hard to say at what point a boat is planing, you will always generate some lift regardless of speed. Interestingly if you plug a beach cat into the simple planing eqn given in http://www.hydrocompinc.com/knowledge/whitepapers/HC113-MinPlaningSpeed.pdfYou get a planing speed of about 30knots, and a VX40 gets on the plane at 40knots! Is this the fourth mode <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Gareth | | | Re: Volvo Extreme 40 specs?
[Re: Wouter]
#76731 06/08/06 01:29 PM 06/08/06 01:29 PM |
Posts: 141 Panama City Beach, FL | I still derives by far most of it's "gravitational suspension" due to archimedes law therefor it is still in its displacement mode.
Hmmmm, can you prove that, or am I required to disprove it? Also, define "most." Also, I have yet to see a consensus as to when a boat is planing. Or stating it another way, I have yet to see a consensus on what defines a planing boat. However, if you look at the immersed lines of the leeward hull of the attached F16, you see some straight, flat runs. So you have speed well in excess of hull speed, some percentage (most? significant?) of boat weight and sail force counteracted by dynamic lift, flow separating cleanly from the transom and a portion of the hull of proper (if compromised) planing geometry. If not planing, then in that power-sucking semi-planing regime. But not displacement. | | | Re: Volvo Extreme 40 specs?
[Re: steveh]
#76732 06/08/06 02:36 PM 06/08/06 02:36 PM |
Posts: 9,582 North-West Europe | Hull speed formulae are boogus when looking at beach catamarans. The hullspeed formula that is so often thrown about is really a misintepretation of the Froude law which actually only links wave length to wave speed. For some boats the Froude law coincided with the maximum speed they can attained given a limited drive due to some factor. Of course all sailboats are limited in drive their sails can produce because of stability considerations. Now Froude's law applied to beach cats as well it just that the commonly encoutered misintepretation of it is not rightfully applied to these designs. Hence the parados that catamarans can sail faster then "their maximum hull speed". I can tell everybody out there that debunking the "max hull speed formula" is like fighting the multi-headed hydra. For some reason this "error" is immortal and ever since its rise to fame it has dominated discussions where. I'm done with it. If you don't understand the true meaning of Froude's law and the true nature of the "max hull speed" formula that is derived of it, then there is simply no use in continueing the discussion. It is like arguing that the earth is round with a midevil christian fundamentalist who thinks it is actually a flat pancake because he can see with his own eyes that it is flat. Sorry about this, but that is just the way things are. If not planing, then in that power-sucking semi-planing regime. But not displacement.
Read Bethwaite very carefully again and then see where his "modes" are just names he gives to a limited series of specific displacement craft. He doesn't include catamarans for example and later on in the book he actually writes that cats are "different" and don't seem to have the forced displacement mode (or whatever he calls it). So his model is only applicable to a specific type of sail craft and it falls down when looking at more different craft. And that Stealth F16 is definatly still in displacement mode. It may have a component of dynamic lift somewhere. Either from the angled foils or from some pressure build-up under the hull, but 80 % of its weight is still carried by archimedes law. Therefor it is a displacement craft. I'm sorry Wouter
[Re: Wouter]
#76736 06/08/06 04:11 PM 06/08/06 04:11 PM |
Posts: 545 Brighton, UK | Hull speed formulae are boogus when looking at beach catamarans. I don't think anyone is talking about hull speed here, we have progressed to talking about planing speeds. I am certain from towing tests that I have perfromed that long slender hulls with elliptical profiles do plane. I had a video to prove it. But I wiped it, actually that sounds a bit like the alien autopsy story so forget I said it. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> You only have to look at planing moths to realise that long slender hulls can plane (just depends upon how long and how slender). | | | Re: Volvo Extreme 40 specs?
[Re: grob]
#76737 06/08/06 05:46 PM 06/08/06 05:46 PM |
Posts: 3,528 Looking for a Job, I got credi... | I find this part of the discussion quite interesting. We just need some hard figures from the crews now to establish what kind of top speeds they have reached so far. Perhaps somebody has the opportunity to ask one of the crew? I'm hoping to catch up with Will Howden in the next few weeks - he's been on Motorola a fair bit. I'll see what he has to say !
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Volvo Extreme 40 specs?
[Re: Rolf_Nilsen]
#76742 06/09/06 02:50 AM 06/09/06 02:50 AM |
Posts: 1,382 Essex, UK | Hi Rolf,
That pic was taken early 2005 as I recall, during a club race. We are beam reaching (just too shy for the kite) to our West Mark, in about 12-15mph of wind. It was just after this that I replaced the carbon boom with a stiffer ali one. We've got almost 180Kgs out on the wire!
That huge stern wave is more than likely caused by a bit of weed around the rudder - a permanent problem when our courses take us down into that corner of our sailing area!
In terms of displacement/planing arguments I'd hesitate to suggest that that pic proves anything!
[Re: Rolf_Nilsen]
#76744 06/09/06 03:17 AM 06/09/06 03:17 AM |
Posts: 3,528 Looking for a Job, I got credi... | Thanks John, everything explained..
What do yo do on the Stealth when you catch weed on the rudders? Park the boat to clean them? Try and sail faster ! Acttually a good question Rolf.. Not so easy to just flip the rudders up !
[Re: scooby_simon]
#76745 06/09/06 03:23 AM 06/09/06 03:23 AM |
Posts: 1,382 Essex, UK | I don't know about everyone else, but I take the opportunity mid-tack to lean over the stern and pull the weed off. Takes maybe 3-4 seconds, then another 5-6 seconds to get out of irons if it all works out! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: Keith]
#76746 06/10/06 03:36 AM 06/10/06 03:36 AM |
Posts: 9,582 North-West Europe | Using correction factors like that is nothing more then fitting the errornous formulae to reflect the data. And there that formula become extremely limited in its use. Afterall you must already now the REAL max speed to even calculate the correcttion factor needed. Additionally you screw up the relationship and you magnify the error.
Max. hull speed is nothing more then Froude's law with a different (and often errornous) intepretation.
Froude's law says that a wave with a wave length of X has a speed of Y ;
Wave speed = 1.54 * (wave length)^2
For alot of (displacement) sail boats this coincides with their maximum speed their hulls can travel through the water as their hull get trapped between two wave tops with insufficient drive to overcome the rapid rise in hull drag.
A good number of other sailcraft design DO HAVE enough drive to overcome this rise or have reduced the magnitude of the increase in drag to such an extend that it no longer plays an important role. The standard example of that is the catamaran hull shape.
It is of no use to use a corrector factor and just IMAGINE that the wave system is actually travelling faster then it is in real life just so to assume that that this corrected wave system encloses the cat hull at much higher speeds than it does in REALITY. We can just as well think up a story then little goblins start pushing against the bow of the hull at 20 knots; it has the same amoun to reality value = none.
That is the eternal myth of the max hull speed formula. And it is indeed immortal as in 12 months time we'll have this discussion AGAIN. In the mean time you can read this law 10's of times on so called professional boating magazines because the bulk of those journalists don't know squad about science as well AND because this formula is pretty accurate for heavy yachts.
And this is the way the "max hull speed" formula survives.
944
guests, and 120
