| Re: Shock and Awe at JPOR
[Re: fin.]
#76862 06/05/06 09:15 AM 06/05/06 09:15 AM |
Posts: 5,590 Naples, FL | Pete,
Where did you think your weakness was? What would you do different next time? How did the blade handle the chop?
[Re: waterbug_wpb]
#76863 06/05/06 09:19 PM 06/05/06 09:19 PM |
Posts: 3,348 | Where to start?
I'm not good mechanically. I had rigged the boat as butt-backward as possible. If Ian (from Vectorworks) hadn't pitched in I might not have made it onto the water at all.
1. Lack of preparation!- fault number one! Huge, Huge error. This is a very subtle and sophisticated boat. Preparation is too important to overstate.
2. Lack of familiarity- tiller is more sensitive than any other boat I've sailled. The sail is flatter higher up, so it's very easy to go into irons. The mast is more bendy. The mast rotation is more important.
That's just a beginning! This will be quite a learning process. But, that's a good thing! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Other than the obvious preparation and familiarity problems. I'm sure I have too much mast rake. So raking the mast forward, is the first and most obvious adjustment. As it is now, there is quite a lot of weather helm.
Also, I'm having problems with the mast rotation. For most guys, that's a quick fix. For me, it will take a while. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
The boat handles chop just fine. It's the skipper that has the difficulty.
[Re: fin.]
#76864 06/05/06 10:44 PM 06/05/06 10:44 PM | Anonymous
| Anonymous
Unregistered | Pete:
If your squaretop is sending you into irons try this. Foot a little right before you tack and AS soon as you go head to wind let out about 2-3 feet on sheet and cleat it. This should help you from going into irons. But you will have to experiment as I don't know your boat.
Not to steal thread. But Pete I had my best two weekends of sailing with the reacher/squaretop setup on the 17. Two weeks ago was 22-25 and it flew. Just kissed the water going to weather and rocket downwind. You will love new boat when you get the hand of it. It just take time on the water.
How far are you from Fort Walton? If we go to get the 4.3 on the 17th at Great Bay Race can you meet us?
Doug and Ashleigh | | | Re: Shock and Awe at JPOR
[Re: ]
#76868 06/06/06 03:05 AM 06/06/06 03:05 AM |
If you have a large head on your mainsail then you pretty much have to let out some mainsheet when you pass through the wind (sooner then that may be allright as well). This has the added benefit that you speed up quicker on the new tack as well. The difference can be quite significant and it becomes more pronounced with a larger head.
[Re: fin.]
#76869 06/06/06 03:17 AM 06/06/06 03:17 AM |
Posts: 9,582 North-West Europe | Humm,
I usually don't link errors with mastrotation with weather helm. Sounds almost like your port rudderblade wasn't push down far enough. (not fully vertical). Although then you should also have some weather helm on the port tack.
Mast rotation bugs usually leave you feeling underpowered or leave the boat feel flighty. (= easily lifting the hull in a gust). With the superwing mast you should not look at how the mast is lined up with the back of the sail (smooth curve) but trim it completely to feel and performance. More often then not your mast LOOKS underrotate with respect to the sail curvature when you have it set right. This looks funny but does really work best. Mast rotation on the Superwing mast (Taipan and Blade) is often very little. Typically you have it between pointing to the daggerboard and rudderboard. This is noticeably less then on most other design especially older designs with teardrop shaped masts. I have yet to set it pointing to the side stays, I just never seem to go there, that is too much rotation while this was a good setting on older boats and even some new F18's. When you are singlehanding you reduced mast rotation to depower the rig.
Okay sometimes when the foot of you mainsail is too loose you end up with too much weather helm on the sloop rigged boat. Typcially have the foot fairly tight. Max deviation of foot of sail from boom at max point is about 4 inches. And that is in my experience a absolute maximum. Typically I used halve that; about 2 inches. That looks rather flat but works for me. When singlehanding with only the mainsail you can sail with more foot round. When you have weatherhelm again, try pulling the foot of the mainsail tighter and see if the weatherhelm goes away.
Good luck.
[Re: Wouter]
#76870 06/06/06 08:41 AM 06/06/06 08:41 AM |
Posts: 5,590 Naples, FL | Pete, does the rudder just "feel" heavy, or when you let the rudder go does the boat spin to windward in a hurry?
If it just feels hard to steer, perhaps the rudder rake could be adjusted to relieve a bit of that.
Also, like they said above, if it's just weather helm on one tack, there may be an issue with the rudder alignment or toe-in setting...
Was there any current or swell you saw at JPOR that may have caused the difference in helm feel? I believe there is usually a south-north current there, which can play tricks on your mind if they set the course for the prevailing southeasterly breeze...
Jay | | | Re: Shock and Awe at JPOR
[Re: arbo06]
#76873 06/07/06 08:41 PM 06/07/06 08:41 PM |
Posts: 3,348 | Could be a loose nut on the tiller.
(jus kiddin) Absolutely! No kiddin'! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> | | |
740
guests, and 167
