| It looks really different! #76998 06/06/06 10:09 AM 06/06/06 10:09 AM |
Posts: 285 | Have a look a this photo: http://www.bimare.net/fotox4/X-4-6-bis.jpgThe new BIMARE X-4 Formula 18 looks really different from the other F18s pictured (Cirrus, Hobie Tiger, Mattia Flash). | | | Re: It looks really different!
[Re: Catfan]
#77001 06/06/06 02:57 PM 06/06/06 02:57 PM |
Posts: 1,203 uk | Looks like a half decent race going on, any results for the new boat
Inf GBR7
[Re: Berny]
#77003 06/06/06 05:41 PM 06/06/06 05:41 PM |
Posts: 12,310 South Carolina | Good looking boat. A class hull shape was predictable. Interesting mainsail top treatment to transfer sheet loads to mast tip. Should go well. Are you talking about the triangular reinforcement patch? That is different.
Jake Kohl | | | Re: It looks really different!
[Re: Berny]
#77006 06/06/06 07:08 PM 06/06/06 07:08 PM | Anonymous
| Anonymous
Unregistered | It seems like this boat may be at an advantage in waves. Looks like a lot of freeboard and not much bow (will limit pitching). | | | Re: It looks really different!
[Re: ]
#77007 06/06/06 07:19 PM 06/06/06 07:19 PM |
Posts: 12,310 South Carolina | It seems like this boat may be at an advantage in waves. Looks like a lot of freeboard and not much bow (will limit pitching). In my opinion, I think you are right but to a point. Most F18s are already quite sensitive to driving in bows in the heavy stuff - those bows look like they could be very sensitive and the lack of rocker on the bottoms might make it difficult to trap far back and keep the bow high.
#77008 06/06/06 07:30 PM 06/06/06 07:30 PM | Anonymous
| Anonymous
Unregistered | Lack of rocker? Maybe I don’t understand what rocker is. When I saw the first picture (6 months ago) of the prototype from the side, the first thing I thought was “wow that’s a lot of rocker.” | | | Re: It looks really different!
#77009 06/06/06 07:32 PM 06/06/06 07:32 PM |
Posts: 2,921 Michigan | I ain't buying that this is a stable boat with spin up.
IMO
[Re: Berny]
#77011 06/06/06 08:04 PM 06/06/06 08:04 PM |
Posts: 3,114 BANNED | The A class has used that bow for some time now and if the other accompanying design features are included, and the boat is sailed to design, it works fine. As many on here are fond of pointing out, an F18 ain't no Acat. Not even the same ballpark. | | | Re: It looks really different!
[Re: bvining]
#77014 06/07/06 02:40 AM 06/07/06 02:40 AM |
Posts: 1,382 Essex, UK | Rocker = amount of curvature along the keel line in the vertical plane
Sheer = amount of curvature along the deck line in the vertical plane
Tumblehome = amount of curvature from the topsides towards the gunwhale/deck centreline
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: It looks really different!
[Re: MauganN20]
#77015 06/07/06 05:42 AM 06/07/06 05:42 AM |
Posts: 9,582 North-West Europe | As many on here are fond of pointing out, an F18 ain't no Acat.
Ain't that the truth ! There are indeed major differences in the design between these two boat types. There are things in either design that you simply won't do in the other for risk of ending up with a bad boat. An F18 needs to be designed as an F18 fully from "the ground" up.
[Re: bvining]
#77017 06/07/06 05:45 AM 06/07/06 05:45 AM |
F18 class allows carbon boards now. They have to otherwise they can't make their boards as long as they are now. The F18's are now using board that as over a meter long (as in the part that sticks out below the keel line) The stresses in these are pretty high. The newer F18's are running with aspect ratio's between 5 and 5.5 now. And that is very high.
1,082
guests, and 39
