6:1 downhaul #77062
06/06/06 09:44 PM
06/06/06 09:44 PM
Mary Esther, Fl
stocke2 Offline OP
stocke2  Offline OP
Mary Esther, Fl
on the harken 6:1 downhaul for the hobie 16, what is the bottom block attached to?
I had been considering using two single blocks I have laying around to make a downhaul on my boat so it would be easier to pull down, at least till i can afford to buy a 6:1
Re: 6:1 downhaul [Re: stocke2] #77063
06/07/06 09:07 AM
06/07/06 09:07 AM
Central Texas
yoh Offline
yoh  Offline
Central Texas
The Hobie brand downhaul kit comes with some sort of a bracket that can be inserted in the extruded slot in the mast (goes in before the boom is inserted in the same slot). I have a home made 4:1 nock off that uses a similar bracket to hold a violine block in the same place. I think I made this thing before the block style downhaul became class legal.
Patrick
Patrick, Hobie 16 '85
Re: 6:1 downhaul [Re: yoh] #77064
06/07/06 01:49 PM
06/07/06 01:49 PM
Mary Esther, Fl
stocke2 Offline OP
stocke2  Offline OP
Mary Esther, Fl
where did you get your bracket at?
Re: 6:1 downhaul [Re: stocke2] #77065
06/07/06 06:10 PM
06/07/06 06:10 PM
The bracket is the same as the top piece of the main traveller car.
Re: 6:1 downhaul [Re: mbounds] #77066
06/08/06 08:27 AM
06/08/06 08:27 AM
Matt, you're pic did'nt work. Will an eyestrap, secured with two track nuts and screws, work as well?
Re: 6:1 downhaul [Re: _flatlander_] #77067
06/08/06 09:57 AM
06/08/06 09:57 AM
The eyestrap may not have enough clearance - you would have to use a twist shackle to attach the lower block, or re-reeve the line every time you took the sails off the boat.
I bought a couple of the traveller top plates from the "used parts bin" of my local dealer for $5 each.
Got the photo to work this time . . .
Re: 6:1 downhaul [Re: mbounds] #77068
06/08/06 01:17 PM
06/08/06 01:17 PM
Mary Esther, Fl
stocke2 Offline OP
stocke2  Offline OP
Mary Esther, Fl
how did you get that to stay down, do you use a couple screws with nuts inside the track like the cleat that would normally be there?
and where did you get the peice to attach that cleat or is that part of the block?
Re: 6:1 downhaul [Re: stocke2] #77069
06/08/06 03:03 PM
06/08/06 03:03 PM
Is part of the block. #10-32 nuts to fit mast track at catsailor store as well.
Re: 6:1 downhaul [Re: _flatlander_] #77070
06/08/06 04:55 PM
06/08/06 04:55 PM
Coopersburg, PA
V
Vinny_M Offline
Vinny_M  Offline
V
Coopersburg, PA
This might sound a bit odd, but is there a noticable difference in the performance of a bullet block 6:1 downhaul versus a Carbo 6:1 downhaul? The image Matt placed of his system is Carbo, but the image John placed is a bullet block. Is there a difference performance-wise?
thanks.
~vinny~
Re: 6:1 downhaul [Re: Vinny_M] #77071
06/09/06 08:12 AM
06/09/06 08:12 AM
My two cents. I think the new carbo line is all about weight reduction, certainly a consideration but obviously more of a concern for the hp dinghy sailor.
I've got the carbo upper, purchased via auction, and 095 lower, purchased online. Price was my major concern.
Re: 6:1 downhaul [Re: _flatlander_] #77072
06/09/06 07:19 PM
06/09/06 07:19 PM
I don't use either (bullet or carbo). Harken Micro Blocks.
It's important to use square (not hex) nuts to secure the bracket. They will grip the inside of the track, whereas the hex nuts don't.
Even so, I still had a problem with the bracket working up the mast. Used a file to make a flat spot for it (and create a bit of a "ledge" at the top) fixed that problem.
The upper end uses an old tiller extension connector/bolt to replace the ring/pin that holds the gooseneck together. Otherwise, you'll shear the cotter pin right off.
Re: 6:1 downhaul [Re: mbounds] #77073
06/10/06 12:33 PM
06/10/06 12:33 PM
Thunder Bay ON CAN
M
mmadge Offline
mmadge  Offline
M
Thunder Bay ON CAN
The nut on the end of the bolt that holds the ring just fell off on my new boat.Matt do you know what size that nut is?
Re: 6:1 downhaul [Re: mmadge] #77074
06/10/06 03:30 PM
06/10/06 03:30 PM
1/4-20? Maybe the next size smaller (#12 I think)
0 registered members (), 185 guests, and 100 spiders.
Posts267,056
