Q: is a cat suitable for this: #77259
06/09/06 06:37 AM
06/09/06 06:37 AM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
Hi all,
I've been away from sailing for a while, pursuing other interests. Now I'm looking for a quick'n easy solution to getting out on the water again from time to time. Renting has crossed my mind, but it's hard to rent a cat where I live.
I'm used to mucking about in open keelboats which, as you know, get their stability via primitive means, usually involving a sizeable hunk of lead.
What I believe I need now is:
1) easily trailerable behind a typical continental (no, not a Lincoln) economy car.
2) stowable inside my garage which is max 6m (+/-20') long.
3) available second hand at a (ridiculously) tight budget.
4) Here's what I believe to be the hard part: Able to be dry sailed like your typical keelboat. So you don't need a wet suit in gentle weather. I don't mind reefing to keep the boat stable, but the low clearance of a cat probably makes it impossible to stay dry at all, right?
Could anyone either
a) recommend a suitable model
or
b) tell me whether or not I'm totally out of my mind.
Thanks in advance,
Dennis
Re: Q: is a cat suitable for this: [Re: DennisMe] #77260
06/09/06 07:18 AM
06/09/06 07:18 AM
Straight Outta Hell
Boudicca Offline
Boudicca  Offline
Straight Outta Hell
For the dryness issue you claim, these cats come to mind, all wooden:
Shark
Wharram HITIA (maybe) or TIKI 21 (too long?)
Re: Q: is a cat suitable for this: [Re: DennisMe] #77261
06/09/06 08:33 AM
06/09/06 08:33 AM
Hi all,
Could anyone either
or
Thanks in advance,
Dennis
b) 4)mostly
Re: Q: is a cat suitable for this: [Re: fin.] #77262
06/09/06 08:59 AM
06/09/06 08:59 AM
where the heck do you live to start with.
Re: Q: is a cat suitable for this: [Re: DennisMe] #77263
06/09/06 09:15 AM
06/09/06 09:15 AM
the problem with garage storage is the mast - most masts well exceed the length of the hull.
Re: Q: is a cat suitable for this: [Re: DennisMe] #77264
06/09/06 09:15 AM
06/09/06 09:15 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
For the style of sailing you wish to do I would look into a Maine Cat 22. I'm not sure if they are being made anymore, but they would be perfect for the sailing you want to do. However, the size may not fit your garage, and the price may not be very low. It is trailerable (hinges in the middle). Also look for old Cougars, they came in wood and fiberglass, obviously you'd probably want the glass one. Not too common, but you might be able to scare one up.
some more details [Re: PTP] #77265
06/09/06 09:25 AM
06/09/06 09:25 AM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
PTP: I live in the south of the Netherlands.
TikiPete: The Wharram Tiki does look nice, I have his catalogue lying around from years ago. I'll go and dig it up. By miostly, do you mean mostly dry or mostly wet? I'm talking about sailing at below 4 Bft, above that I'd expect to get wet in any small boat on less than sheltered waters.
Boudicca: The shark looks nice, the designer must have been ages ahead of his time.
Thanks a lot everyone for helping out!
Re: some more details [Re: DennisMe] #77266
06/09/06 09:30 AM
06/09/06 09:30 AM
Your're gonna get wet!<img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
http://www.multihulls.uk.com/wharram/boats.htm
http://www.wharram.com/ctrek_photos/ctrek.shtml
Re: Q: is a cat suitable for this: [Re: DennisMe] #77267
06/09/06 10:42 AM
06/09/06 10:42 AM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
Farrier Tramp, a 19' Trimaran that was produced in Australia (and US as Eagle) many years ago.
Les Gallagher
Re: Q: is a cat suitable for this: [Re: sparky] #77268
06/09/06 12:59 PM
06/09/06 12:59 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
You may want to look at the older P-Cats (not Prindle). I think they are actually called Pacific Cats. They are completely fiberglass and are very comfortable boats to sail. They have a **** on each side that lets you sit in them as you would a large monohull.
They are heavy, I think about 700 lbs. This is the boat that most aged catamaran sailors in California coveted when they were young. Maybe the reason we are on a catamaran at all.
Later,
Dan
Thanks 2 all [Re: Dan_Delave] #77269
06/12/06 02:37 AM
06/12/06 02:37 AM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
Thanks everyone,
Dan, thanks for the P-cat tip and the pictures. This probably comes closest to what I need (to convince the wife)...
Sparky, thanks for the tramp tip, I'll keep my eyes peeled although they are very rare in these parts. I'm actually planning to build a Farrier design at some point in the future, but 'things' will have to settle down before I take on a project like that.
I think I'll just hang-out here for a while and just lurk. Who knows I just might learn something from you guys.
Dennis
Re: Q: is a cat suitable for this: [Re: Dan_Delave] #77270
06/12/06 03:14 AM
06/12/06 03:14 AM
Dan, I don't understand those "****" on the P-Cat. They look like convenient places to collect pools of water. Plus, they appear to be where the centerboard trunks are located.
Re: Q: is a cat suitable for this: [Re: Mary] #77271
06/12/06 09:37 AM
06/12/06 09:37 AM
Dan_Delave Offline
Dan_Delave  Offline
Mary:
I have not been near a P Cat in a while, I posted this pictures from another place, but as I remember the daggerboards are kick up and have a long slot in the boat for that. The draining of water is through that slot as well.
Re: Q: is a cat suitable for this: [Re: Dan_Delave] #77272
06/13/06 10:13 AM
06/13/06 10:13 AM
NC
calcheck Offline
calcheck  Offline
NC
Mast is about 25'storage outdoors-recommemded-as long is it is off the ground you should be OK. About the P-Cat sailed one in the '70's the **** are self draining they have a 2" pipe that leads throught the rear of the hull to the transom. When there is a breeze the rubber gaskets at the bottom of the centerboard wells allow a jet of water to come up behind or in front of the board and that fountain drains throught the transom too. Not a bad light air boat for how heavy it is since it has 267 sq. ft. of sail. Much faster than the Aqua Cat it replaced. We sailed in Erie PA so we usually stayed dry when possible.
John
Re: Q: is a cat suitable for this: [Re: calcheck] #77273
06/13/06 12:10 PM
06/13/06 12:10 PM
Hmmm, sounds like a combination potty and bidet. Either you are sitting on the drainhole or you are sitting on the fountain. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Q: is a cat suitable for this: [Re: Mary] #77274
06/13/06 01:16 PM
06/13/06 01:16 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Let's hope the drainhole doesn't back up and become a fountain. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
US Sail Level 2 Instructor
US Sail Level 3 Coach
So that's what the "P" stands for, is it? [Re: hobie1616] #77275
06/13/06 01:51 PM
06/13/06 01:51 PM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
I guess they never made a number two model then ;-P
Who knows what I'll run into. I'll keep my eyes peeled though.
Dennis
Re: So that's what the "P" stands for, is it? [Re: DennisMe] #77276
06/14/06 06:41 AM
06/14/06 06:41 AM
NC
calcheck Offline
calcheck  Offline
NC
We got our boat about 10 years old and maybe the gaskets for the centerboard well were toast- I forgot to mention we docked it in a marina and would only have to pump out a gallon or so of water once a week from our one slightly leaky hull.
0 registered members (), 12,481 guests, and 695 spiders.
Most Online11,466
3 seconds ago
