Removing sap from hulls #7736
06/11/02 01:07 AM
06/11/02 01:07 AM
Denver
charlesa Offline OP
charlesa  Offline OP
Denver
As a result of an unwise storage choice, one of my hulls has a good deal of hardened tree sap on it. I'm in the process of getting my H-17 ready for the water again (after more than four years on land) and I'd like to figure out how to get rid of the sap. The greatest accumulation is on the side of the hull below the waterline.
Choices that come to mind are:
* Buff sanding and then repairing the gelcoat
* Chipping/chiseling and then repairing the gelcoat
* Some sort of chemical/enzyme solution
Any suggestions? I'm already going to be doing some work to repair delamination and various chips and scrapes from over the years, so I'm prepared to spend a good deal of time in the garage over the next couple of weeks in any event.
Re: Removing sap from hulls [Re: charlesa] #7737
06/11/02 07:42 AM
06/11/02 07:42 AM
Jacques Offline
Jacques  Offline
Did you tried aceton?
Re: Removing sap from hulls [Re: Jacques] #7738
06/11/02 09:02 AM
06/11/02 09:02 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
If Acetone doesn't work try MEK (Methyl Ethel Keytone). It's available at large hardware stores. Wear gloves when you use it. MEK can dissolve a lot of stuff but not your hull.
Mike Hill
H20 #791
Mike Hill
N20 #1005
Re: Removing sap from hulls [Re: charlesa] #7739
06/11/02 10:58 AM
06/11/02 10:58 AM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Tree sap is hardened non-polar resin most like turpentine. It will dissolve in a similar substance- like turpentine- that will not hurt polyester resin/gel coat. But turpentine (distilled from pine tree stumps) is now very scarce except in an art supply store. Use mineral spirits (or charcoal fire starter) to soften and dissolve it the sap. This takes a while for hard sap, even using a pad full of solvent sitting on it. Do NOT use lacquer thinner, acetone or MEK.
SIgned, Ph.D. Organic Chemist
Dacarls:
Re: Removing sap from hulls [Re: dacarls] #7740
06/11/02 11:57 AM
06/11/02 11:57 AM
Denver
charlesa Offline OP
charlesa  Offline OP
Denver
Thanks for the info. This is just the sort of thing I was looking for. What are the dangers with something like lacquer thinner, acetone or MEK?
-C
Re: Removing sap from hulls [Re: Jacques] #7741
06/27/02 06:50 PM
06/27/02 06:50 PM
Denver
charlesa Offline OP
charlesa  Offline OP
Denver
Acetone did the trick. I tried mineral spirits, but it
took much too long. Acetone, with a little scrubbing
got rid of the sap and the hard water stains. Very nice.
I stayed away from MEK. It scares me - not too sure what
it would do to my lawn in the process.
0 registered members (), 2,497 guests, and 327 spiders.
