| Re: Removing sap from hulls
[Re: charlesa]
#7737 06/11/02 07:42 AM 06/11/02 07:42 AM |
Posts: 57 | | | | Re: Removing sap from hulls
[Re: Jacques]
#7738 06/11/02 09:02 AM 06/11/02 09:02 AM |
Posts: 833 St. Louis, MO, | If Acetone doesn't work try MEK (Methyl Ethel Keytone). It's available at large hardware stores. Wear gloves when you use it. MEK can dissolve a lot of stuff but not your hull.
Mike Hill
H20 #791
Mike Hill N20 #1005
[Re: charlesa]
#7739 06/11/02 10:58 AM 06/11/02 10:58 AM |
Posts: 805 Gainesville, FL 32607 USA | Tree sap is hardened non-polar resin most like turpentine. It will dissolve in a similar substance- like turpentine- that will not hurt polyester resin/gel coat. But turpentine (distilled from pine tree stumps) is now very scarce except in an art supply store. Use mineral spirits (or charcoal fire starter) to soften and dissolve it the sap. This takes a while for hard sap, even using a pad full of solvent sitting on it. Do NOT use lacquer thinner, acetone or MEK.
SIgned, Ph.D. Organic Chemist
20,854
guests, and 541
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 17 hours ago | | | |
