H16 Traveler #77717
06/15/06 12:20 AM
06/15/06 12:20 AM
Minnesota
hititmaestro Offline OP
Minnesota
My Traveler is a small bracket that sits in the slide, it is moved in the slide by pulling two lines that lock in jam cleats. can a more modern taveler be used in the exsisting slide? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
When i was your age Pluto was a planet Blake Johnson 1973 hobie 16 sail 2663
Re: H16 Traveler [Re: hititmaestro] #77718
06/15/06 07:15 AM
06/15/06 07:15 AM
Whoa! You're really old school. The traveller was upgraded to a roller bearing version in 1976.
Get the Hobie Catalog here.
A picture of what you need to get is at the top of page 25. Any Hobie dealer can get you a new traveller - make sure you get the "old" style with the smaller wheels.
Re: H16 Traveler [Re: mbounds] #77719
06/15/06 08:47 AM
06/15/06 08:47 AM
Minnesota
Minnesota
hey thanks also i am confused about the lower forestay does it not connect to the same place as the other wire?
Re: H16 Traveler [Re: hititmaestro] #77720
06/15/06 11:33 AM
06/15/06 11:33 AM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
No. The forestay holds the mast up until the jib is raised. Put the forestay in the top hole of the chain plate after stepping the mast. The cable in the jib can be placed in any hole (other than the top one) to adjust the rake of the mast.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: H16 Traveler [Re: hititmaestro] #77721
06/15/06 12:53 PM
06/15/06 12:53 PM
This may help
H16 Assembly Manual
0 registered members (), 224 guests, and 44 spiders.
