New Hobie F14 pics #78799
06/28/06 08:59 AM
06/28/06 08:59 AM
Norfolk, VA
Dan Berger Offline OP
Norfolk, VA
I have posted some pics of the latest Hobie F14s on thebeachcats:
http://www.thebeachcats.com/modules.php?...=view_album.php
Chip Buck at Whirlwind sails makes some pretty cool stuff!!
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: New Hobie F14 pics [Re: Dan Berger] #78800
06/28/06 08:40 PM
06/28/06 08:40 PM
Darryl_Barrett Offline
WOW that is some area of sail!!!! If only someone would put a set of T foil rudders on a Hobie 14 then they would really be able to use that power to it's fullest potentual.
Re: New Hobie F14 pics [Re: Darryl_Barrett] #78801
06/29/06 09:41 AM
06/29/06 09:41 AM
Norfolk, VA
Norfolk, VA
Yeah, when going upwind and you get a puff, you tend to go over backwards. Downwind is a hoot. The unfortunate thing is that the 14 doesn't have big enough bows--now, if I could get foils on the boat, it would be amazing!
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: New Hobie F14 pics [Re: Dan Berger] #78802
06/29/06 01:36 PM
06/29/06 01:36 PM
H
hobie17guy Offline
hobie17guy  Offline
H
Nice pics on the 14. Do you have the jib set up and the hooter?
Re: New Hobie F14 pics [Re: hobie17guy] #78803
06/29/06 02:59 PM
06/29/06 02:59 PM
Norfolk, VA
Norfolk, VA
Kinda--
I have the boat set up like a little Hobie 18 and I had Chip make me a jib with a zipper. I can run the Hooter with the jib as well, but that would be a lot of lines on the boat and I would take a big hit for carrying the sail. I use the same attachment location for either sail--I use Oxen blocks to control the Hooter and switch out to the stock Harkens when I go Turbo.
I tried it with both sails once and it was just too much. That was on another boat where I had it rigged as a stock Turbo and I attached the Hooter blocks on the side rails.
The only way I would run Hooter and jib at the same time would be if I had a self-tacking jib, but I don't see that ever hapening..
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: New Hobie F14 pics [Re: Dan Berger] #78804
07/20/06 11:28 PM
07/20/06 11:28 PM
Dan:
I am having trouble uncleating the reacher on my current setup on the 17. Would Oxens help this out. Attached current setup.
Doug
Re: New Hobie F14 pics [Re: ] #78805
07/26/06 09:48 AM
07/26/06 09:48 AM
Norfolk, VA
Norfolk, VA
You really don't want to ever cleat a headsail. In the light stuff, it would be OK, but in anything else, you are asking for trouble. I prefer the Oxens--mainly because I happened to have a set lying around and I got used to them. You really only need a ratcheting block that would help you hold the sheet. When I'm running the Hooter, I set the main and forget it. I sail by the Hooter sheet only, so I don't have to worry with two lines.
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
0 registered members (), 2,548 guests, and 457 spiders.
