| Re: Wave Rigging ?? Pain or piece of cake or in betwee
[Re: gcmarshall]
#78841 06/28/06 10:12 PM 06/28/06 10:12 PM |
Posts: 6 fort scott ks | Hello gcmarshall, I live a mile from the lake and trailer the boat each time i sail. Almost always I sail alone. Each time i step the mast i think "that wasnt so bad . It is much easier than a 14 or 16. This boat is so easy to set up and get on the water you sail it more often. Who ever designed this boat was a genius! It is a simple boat but it is rugged and espeically fun in heavy air. Get one. rbrazz
rbrazz
[Re: gcmarshall]
#78842 06/28/06 10:57 PM 06/28/06 10:57 PM |
Posts: 5,582 “an island in the Pacifi... | Is it a hair-splitting, tedious hour long episode to set up and take down? Are there a lot of tedious little adjustments to the mast that need to be made each time one wants to sail? What is the real world bottom line on tjis for someone of average capability and skill, not an expert, but not a beginner, for example. I am particularly interested in this topic with respect to adjusting the shrouds and forestay as well as whether or not rigging this boat and stepping the mast by oneself if easy or if two people are required. Are you sure you're not considering a H20? US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Wave Rigging ?? Pain or piece of cake or in betwee
[Re: gcmarshall]
#78843 06/29/06 06:45 AM 06/29/06 06:45 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Piece of cake. Rick says he can have the boat from trailer to beach, completely rigged, in five minutes. Of course, he's had a lot of practice, but I would think even a first-timer could easily do it in 15 minutes.
We leave our shrouds attached and we leave our rudders on for trailering. So all you really have to do is raise the mast, attach the forestay, pull the boat off the trailer and hoist the sail. | | | Re: Wave Rigging ?? Pain or piece of cake or in betwee
[Re: gcmarshall]
#78844 06/29/06 06:53 AM 06/29/06 06:53 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | If I hurried, I could have it rigged on the beach with the sail up in less than 5 minutes. Piece of cake.., never had a an easier boat -- even more simple than a Laser or Sunfish.
Couple of tips: 1) You don't need to take the mast apart -- the mast is not that long anyway, so I leave it in one piece and tie it to the boat. 2) I leave the shrouds connected to the mast 3) Upon arrival, I put the base of the mast on the ball, use the tail end of the halyard and tie it to the bridle wire in the middle 4) Raise the mast. If you keep forward pressure on the mast, you don't even need the retainer pin.., haven't used one in a couple of years now. 5) Retrieve the bridle wire attached to the halyard and connect the forestay. 6) I always leave the rudders on as well. 7) Take boat off trailer and on to beach wheels 8) Hoist sail, hook up clew and go sailing. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Not to mention, there are a good many organized Wave regattas around the country. So, Join Us!
Rick | | | Re: Wave Rigging ?? Pain or piece of cake or in betwee
[Re: gcmarshall]
#78847 06/29/06 09:56 AM 06/29/06 09:56 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | You don't really need the trailer mast support for a Wave. We just secure ours down flat on the boat, with padding, of course, at the support points. How far you can put it forward depends upon how long your trailer tongue is, but since it will probably be down the centerline of the boat, you can bring it pretty close to the back of your vehicle, so you don't have too much hanging out behind.
The bob is what will be in back, so in addition to hanging a flag back there, you can put a piece of reflective tape on the top of the bob if you are driving at night.
Also, because the Wave mast has the two separate parts, not glued together, you should secure both ends of the halyard at the base of the mast so the comptip cannot wiggle off during transport.
We do not detach the shrouds from the mast if we are trailering one Wave (or any catamaran, for that matter). I don't know you mean by "mainstay," but I assume you are referring to the forestay. Rick covered that in his post above. That has to be detached in order to drop the mast. So you secure it to the mast by tape, shock cord, line, whatever, so it can't fall off during trailering. The shrouds (still attached to the boat and mast) are coiled up and also secured to the trampoline in the method of your choice.
And, as I said, we do not take off the rudders for trailering, but they should be secured in the "up" position.
As far as the Wave being easier to rig than a Sunfish or Laser, I have sailed all, and I have to agree that the Wave is definitely easier and faster to rig than either of those boats. At least it is for me. And,at the very least, it would be same time. And for sure it is easier to go sailing, because with the Laser and Sunfish, you have to get the boat into deep enough water to put in the daggerboard and then try to jump aboard -- I'm too old for that stuff. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> | | |
1 registered members (vasil),
289
guests, and 39
