10' wide N20 #79054
07/03/06 07:49 PM
07/03/06 07:49 PM
David Offline OP
David  Offline OP
While admiring a molded wood Tornado at the Stature race, one of the racers said that sailing a 10' wide cat is such a great feel. It handles so much better than our 8.5' wide cats. Obviously the 8.5' beam is for trailerability rather than sailability.
So here's a question for all you engineers out there, how could you make a 10' wide, easily trailerable cat like, say a Nacra 20? If you used sliding beams, you would only need to slide 9" on each side; that doesn't seem so much to accomplish, yet no one has done it. It seems like technology should be able to solve this issue.
David
Hobie 20
781
Re: 10' wide N20 [Re: David] #79055
07/03/06 08:16 PM
07/03/06 08:16 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Keep it simple with a trailer that will raise one hull so the horizontal plane is reduced to eight feet. There's another thread with a picture of a flip up trailer being towed by a Mini Cooper.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: 10' wide N20 [Re: hobie1616] #79056
07/03/06 08:41 PM
07/03/06 08:41 PM
H
HobieZealot Offline
HobieZealot  Offline
H
You would need to raise one hull by about 5 1/2 feet to get a 10 foot beam down to an 8 1/2 foot beam.
Re: 10' wide N20 [Re: HobieZealot] #79057
07/03/06 09:08 PM
07/03/06 09:08 PM
hobie1616 Offline
hobie1616  Offline
That's pretty much what the trailer/boat being pulled by the Mini looked like. IMHO flipping the boat up is a lot easier than expanding/collapsing the boat every time it's used.
Re: 10' wide N20 [Re: hobie1616] #79058
07/03/06 09:11 PM
07/03/06 09:11 PM
Just get a Tornado tilting trailer. That's how they do it. The real engineering question is, what about the beams? I would like to see some carbon fiber 10' beams for the Inter 20. The problem is that the bed on the hull is flat and most carbon beams are round. What do the Tornado guys use for beams, flat or round on the bottom?
Re: 10' wide N20 [Re: Timbo] #79059
07/03/06 09:15 PM
07/03/06 09:15 PM
Actually, the sliding / expanding beams has been done before - about 20 years ago.
The original Hobie 21 had them.
Re: 10' wide N20 [Re: mbounds] #79060
07/03/06 09:43 PM
07/03/06 09:43 PM
Yes, and it weighed about 600 lbs...
Re: 10' wide N20 [Re: hobie1616] #79061
07/03/06 10:46 PM
07/03/06 10:46 PM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
That Mini and Tornado belong to Mike Dobbs. Very cool set up. He built the trailer himself.
Re: 10' wide N20 [Re: mbounds] #79062
07/03/06 11:12 PM
07/03/06 11:12 PM
hobie1616 Offline
hobie1616  Offline
Didn't the 21 have problems with the locking pins enlarging the holes in the crossbars?
Re: 10' wide N20 [Re: mbounds] #79063
07/04/06 08:42 AM
07/04/06 08:42 AM
As did the Supercat 20s.
Re: 10' wide N20 [Re: David] #79064
07/04/06 09:53 PM
07/04/06 09:53 PM
DHO Offline
DHO  Offline
How about a quick-release setup on the beam bolts? Maybe something similiar to bicycle hubs. You could reduce slop in the the joint by putting a dome or slot on the hull and a complementary dome or slot on the crossbeam. With a quick release cam fitting, you may be able to get a good tight fitting without all the hassle of regular bolts.
I don't have a patent on this, so if anyone wants to take the ball and run with it, be my guest.
David Ho
TheMightyHobie18 1067
0 registered members (), 384 guests, and 43 spiders.
