Quick rigging and derigging a spinnaker (a method) #79611
07/10/06 05:01 AM
07/10/06 05:01 AM
Wouter Offline OP
Wouter  Offline OP
All,
Here are a few pointers to help you speed up things. Just last weekend I explained and builded a large portion of them on a boat by a friend.
You can REALLY speed up the rigging of the spinnaker so it will only add 5 minutes to the setup time. No kidding.
First get rid of any steel wires that are linked to the spi setup these are a hassle and sources of sharp edge and loose strands that can damage your spinnaker. I will continue as a listing of points and assume you have a single line setup. :
Summary :
Keep your spinnaker in your snuffer setup with the retrieval line/halyard and sheet still attached to it. Use only 3 mm dyneema lines with a well made outer mantle; don't go cheap on this because there are alot of imitation dyneema lines out there of very questionable quality. Use quick knots I describe and in some cases you don't even have to put your boat over at the last stage. I assume your boat is fully rigged and the spi is dry and that your are packing up. Rigging the boat is the exact same steps in reverse. People having permanent waterfront mast up storage are best served by a different method which I will not describe here now as I don't think Berny (and many Americans/ Australians) have that.
-1- Assume the spi is pulled out a little with both halyards more or less tight. The spi sheet is either permanently fitted to the spi by the middle or by one end. Leave that attached and run the sheet back through its blocks and bundle the line and shoove it partly down the snuffer from the front (snuffer mouth). Make sure that you pass to the back of both halyards, this to prevent screw-ups and tangles later when rigging the spi again. The spi halyard is stored that way.
-2- Grap both the tack and head eyes of the spinnaker (halyards are still attached) and put them on top of eachother and run a small line through them which you also tie to the front of the snuffer mouth or the pole just in front of it. NOW detach both halyards.
-3- Grap the top halyard and pull it all the way through the mast blocks, beam blocks and trampoline so you end up with a bundle of line of which one end runs into the rear of the snuffer and is still attached as a retrieval line to the spi. You never take the retieval line of its patches in this method. This saves alot of time and hassle, especially when rigging in strong winds. When rigging the spi setup later you just flip the boat over and run the halyard up the mast manually, this is alot quickler and simpler then any other method. Besides most crews want to fine tune their batten tensions like this anyway so most are flipping their boats over anyway. (with some halyard setups flipping the boat over is NOT necessary and the boat can stay upright, alot of F18's are having this slightly different system. It has other advantages too, more about this later). So you now tidy the retrieval/top halyard and you shoove it into the rear of the snuffer sock, it is stored there.
-4- I assume your tack halyard is secured to your pole itself with one end, run this line through its blocks and throw it in the snuffer sock as well from the front. The spinnaker is now fully detached from the boat. Now only we need to take off the spi pole
-5- Untie the strut or line that keeps the pole up in the middle (of the pole) the pole will now drop to the ground (gently of course). This will slacken ALL pole support lines. Creating the most slack in your mid pole support lines. Detach these from your bridle points. I use quick knots here but some use snap shackles or sister clips, other small sail hooks. That is all personal preference, as these lines are always under tension when the pole is fitted so none of these fastening methods will become undone. I use a figure 8 knot at the end of the dyneema line and just loop it through the eye of the bridle wire and then loop it once underneath itself (I think this is called a "singe hitch" knot). That is all. Lightweight, cheap and simple. Note that these methods all allows the lines to be of fixed length so your pole is always at the same position EVEN when reraking your mast. Throw the lines in the snuffer sock through the mouth, they stay permanently fixed to the pole.
-6- Now detach the pole from the mainbeam and slide the pole a little under the boat and now detach the front support lines. Best is to have large bowline knot loops at the pole end and throw these over the pole tip and looping them once around. They can't slide down the pole as the saddle taking the tack halyard block will be in the way. ... Now that these tip support lines are slack it will be very easy to slide them off the pole tip. The pole is now fully detached and ready to be put in the trailer.
The spinnaker setup is now fully removed from the boat with the possible exception of the pole tip support lines if you are using the loop trick as described above. This is not an issue when you are packing up the boat on the trailer or when you are always sailing with a spinnaker. But if you want to switch from spi-sailing to non-spi sailing frequently then it may be smart to use a different quick release setup on these tip support lines. This new trick will allow you to remove ALL spi related gear except mainbeam blocks and cleats from the boat in the same 5 minutes.
Ths trick goes as follows :
Use bowlines knots to permanent tie the tip lines to the end of the pole running them through the eyestrap that holds the tack halyard block. At the other end (bows) have a reasonably sized bowline loop and have the end of the line run an additional (say) 100 mm. In this loose end tie a figure 8 knot. Now push the loop through the hole in the bow and swing the loose end with the figure 8 knot around the bow and run it through the loop. Then pull on the support line so you are trying to pull the loop back out through the hole in the bow. The system will jam and hold the line. See picture.
Detaching goes in reverse. The support lines can now stay fixed to the spi pole and come of the boat each time leaving a clean "A cat" like uni-rigged singlehander. Handy for lazy evening sails or when getting out for a quick sail. All other steps (when fitting the spi) remain the same.
With this setup. rigging and derigging the spinnaker must be at max a 5 minute job and can be done singlehandedly. The spi setup has now also become a neat single package that can be thrown on your trailer, waiting for use next time. It will also be impossible to misplace any parts as all are permanently fixed to either the boat or pole.
If the spi is really wet then at home you can pull out the spi (without detaching any lines !) and have it dry in your shed only to be pulled back in using the retrieval line that is still fitted when it is dry. Thus ending up at the same tidy package again.
As said earlier, rigging the spi are the same steps in reverse.
Now for the newer style halyard system that don't require the boat to be flipped over.
This system can still be done as a single-line system althought alot of sailors are modifying it into a double-line system. Personally I really do prefer the single line systems on boats that are singlehanded often. Okay, so instead of having the double block running along side of the spi pole, this new system has the double block run along side the mast. Tune the line lengths such that during a hoist this double block comes all the way down the mast to say within 1 mtr of the mast base plate. Of course we won't hoist the spi on land, but when detaching the top halyard from the spi we can tie another line (about 8 mtr length) to the top halyard line and of course to the bottom of the mast and then pull the double block down the mast by pulling on the retrieval line. If we first secure the double block in this low position and only then pull the retrieval line through all the blocks and trampoline then we don't have to flip boat over when fitting the spi again. Because the double block it needs to run though in now within reach even with the boat upright and the mast raised. This block and retrieval line will then be hoisted to their intended position by pulling the extra line we added earlier and then detaching it.
There are some variations to these setups but basically the core to them is the same and once that is understood then is easy to adjust this core to your personal situation and liking. But remember don't let anybody tell you that is takes more then 5 minutes to rig and derig a spi if you are using a well thought out procedure, because it really can be done that quickly.
Good luck,
Re: Quick rigging and derigging a spinnaker (a method) [Re: Wouter] #79612
07/10/06 06:11 AM
07/10/06 06:11 AM
Wouter Offline OP
Wouter  Offline OP
I will try to make a full document of this with lots of pics.
Re: Quick rigging and derigging a spinnaker (a met [Re: Wouter] #79613
07/13/06 03:52 PM
07/13/06 03:52 PM
Stephen Offline
Stephen  Offline
I will be rigging my new Blade this weekend to get all the lines sized and to get familiar with the spinnaker and jib.
I hope to utilize your ideas to keep the spinnaker setup time to a minimum. I understand most of your description except the single line system and how to get the spin halyard back up the mast without turning the boat over.
I really can't yet visualize the entire spinnaker setup yet because I haven't set it up. I do have photos of how to do it and will be using those to get it right the first time.
Any additional details on how the spin halyard gets back up the mast with possibly photos would be much appreciated.
Thanks,
Stephen
Stephen
Phoenix Az
Re: Quick rigging and derigging a spinnaker (a met [Re: Stephen] #79614
07/14/06 10:47 AM
07/14/06 10:47 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Thanks,
Stephen
Shimmy up the mast. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
USA 777
Re: Quick rigging and derigging a spinnaker (a met [Re: tback] #79615
07/14/06 11:09 AM
07/14/06 11:09 AM
Stephen Offline
Stephen  Offline
I would but the Mast in Arizona when its 115 degrees is a little to hot.
Ha Ha
Stephen
Phoenix Az
Re: Quick rigging and derigging a spinnaker (a met [Re: Stephen] #79616
01/16/07 06:49 PM
01/16/07 06:49 PM
bump
Re: Quick rigging and derigging a spinnaker (a met [Re: fin.] #79617
01/17/07 02:54 PM
01/17/07 02:54 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Well, it's only 6 months since Stephen asked the question of how you get the halyard back up the mast, but here goes. Be warned, it's pretty cunning.
You do it before you raise the mast.
That's it. I use a similar method to that which Wouter describes, but I've never understood the difficulty. The line should be long enough: run it along the mast, through the block and tie it back at the base of the mast. Once the mast's up, untie it and attach it to the head of the kite.
Flipping the boat works fine on a sandy beach, but's a real pain in a tarmac car park.
I figured it was time to resurrect the wiki idea, and wrote up my method for storing the kite + snuffer. I go one step further than Wouter and leave the snuffer threaded through the tramp and cleat at all times. This saves crawling around in the mud trying to re-thread the retrieval line from under the boat. See: http://www.formula16.org/wiki/index.php?title=Quick_gennaker_rigging. Desperately needs some photos, but hopefully it's clear.
Someone else can fill in methods for quick tie bridles.
Re: Quick rigging and derigging a spinnaker (a met [Re: pdwarren] #79618
01/17/07 04:58 PM
01/17/07 04:58 PM
I used to leave my spin halyard on the mast, rigged up and ready to raise as soon as I got to where I was going but I ruined one halyard when it got lose half way up the mast and chafed on the spreader-mast connection fitting while I was going down the highway. That was the only rough edge in the area and it nearly wore all the way through the halyard. Be sure to tie it up tightly or put some tape around the mast-halyard to hold it in place if you are going to trailer with it rigged. Then be sure to take the tape off before you step the mast...not that I've ever done that. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: Quick rigging and derigging a spinnaker (a method) [Re: Wouter] #79619
01/22/07 09:10 AM
01/22/07 09:10 AM
The hole in my bow isn't large enough to accommodate a bowline. It is just over 1 diameter of the line being used. To enlarge, I was considering drilling a 3 diameter hole, approx. 12mm.
My concern is the hulls will leak. So, I'm proposing this procedure: measure to ensure 12mm is sufficient to allow 1 diameter clearance; then allow 1mm additional. Fill the 13mm hole with thickened epoxy to seal the hull. After the epoxy is set, then redrill the 12mm hole.
Does any of this make sense? Comments?
Re: Quick rigging and derigging a spinnaker (a method) [Re: fin.] #79620
01/22/07 10:53 AM
01/22/07 10:53 AM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
My thoughts are that the area is built solid. A slight enlargement of the hole is not going disturb the watertight integrity. Of course Matt M. would be the go to guy on this.
Re: Quick rigging and derigging a spinnaker (a met [Re: bobcat] #79621
01/22/07 01:20 PM
01/22/07 01:20 PM
Thats sounds about right Bruce. I remember speaking to Matt back in the day when my boat starting cracking in this area. The cracks were only superficial (gelcoat) the fiberglass in this area is solid. You should be able to make the hole bigger without any problems or watertight integrity.
BUT, I would ask Matt first, to get his opinion on this matter.
Re: Quick rigging and derigging a spinnaker (a method) [Re: Wouter] #79622
01/25/07 05:35 PM
01/25/07 05:35 PM
See John Williams post on the Open Forum thread, "F18 question".
Re: Quick rigging and derigging a spinnaker (a met [Re: fin.] #79623
01/28/07 01:42 PM
01/28/07 01:42 PM
bobcat Offline
bobcat  Offline
Yeah but what did you do about the hole enlargement?
Re: Quick rigging and derigging a spinnaker (a met [Re: bobcat] #79624
01/29/07 12:49 AM
01/29/07 12:49 AM
Nothing yet.
Re: Quick rigging and derigging a spinnaker (a met [Re: fin.] #79625
04/13/07 10:30 PM
04/13/07 10:30 PM
bobcat Offline
bobcat  Offline
Well? Have you got off your butt on this yet?
The boat is almost out from under the snow. I was hoping you would do the drilling first.
Re: Quick rigging and derigging a spinnaker (a method) [Re: fin.] #79626
04/14/07 02:47 AM
04/14/07 02:47 AM
Wouter Offline OP
Wouter  Offline OP
Use a smaller diameter line !
3 mm 500 kg racing dyneema (NOT the 250 or 300 kg kind) will hold the spi pole just fine.
At least it has for many seasons on both my spinnaker boats (first the P18 and now the F16)
Re: Quick rigging and derigging a spinnaker (a met [Re: bobcat] #79627
04/14/07 09:28 AM
04/14/07 09:28 AM
Sorry Bruce, Wout.
Got lazy and cavalier and just poked a hole through the bow.
I bought a new spin halyard and am canabalizing the old one, so that's on the spin pole.
No problems. . . yet.
Re: Quick rigging and derigging a spinnaker (a method) [Re: bobcat] #79628
07/21/07 06:26 PM
07/21/07 06:26 PM
bump
Re: Quick rigging and derigging a spinnaker (a method) [Re: Wouter] #79629
07/21/07 07:49 PM
07/21/07 07:49 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Hey Wout. Just want to be clear. The attatchment shows the bow. Is it your bow? the Taipan? Have you re-shaped the bow? If so that has dropped to top height of the hole? I don't mean to second guess you as I like the attitude of everything you have presented. This knot you have shown...never fails?
Re: Quick rigging and derigging a spinnaker (a method) [Re: fin.] #79630
07/21/07 07:53 PM
07/21/07 07:53 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
I have drilled my Taipan and it was not so solid and there could be a chance of a leak. What you suggest I am sure would fix any prolems.
0 registered members (), 16,333 guests, and 811 spiders.
Most Online22,490
Yesterday at 08:14 AM
