| Furling Hardware... load questions... #7987 06/18/02 03:27 PM 06/18/02 03:27 PM |
Posts: 3,114 BANNED | I crossed paths with a furling drum and swivel in a box of spare parts from our club. Since harken parts # 434 and 435 are identical dimensionally but differ in load tolerances, I emailed them and asked them if there was a way to find out. They said take it apart, and look at the color of the bearings, if they are green, then its the highload, if they are white or black, then the drum is the standard 500lbs load.
Now I openned it up, and the bearings were not green, they were not white, and they were not black, but rather a rather unfavorable shade of puke-brown. It looks like it may have been green at some point in time, but considering that these bearings aren't exposed to UV light, then I'm less inclined to believe that they got faded.
I was wondering if it was a good idea to put this on my H17 that has no furling hardware for the jib. If the max load of the drum is 500lbs, does that mean that the forestay is gonna break free, or does it simply mean that the drum will not turn, therefore eliminating the furling action?
Thanks for your help!
| | | Re: Furling Hardware... load questions...
[Re: MauganN20]
#7989 06/18/02 03:44 PM 06/18/02 03:44 PM |
Posts: 12,310 South Carolina | When I rebuilt my Harkan traveler I had the option of the Delrin or Torlon bearings. The Delrin bearings (low load) are white and the Torlon (high load) are brown. Sounds like you have the high load furler. I would agree with your assessment that the worst case is that the thing won't rotate - but I would check elsewhere as a) I'm no expert in this area and b) that would be an ugly demasting.
Jake Kohl | | | Re: Furling Hardware... load questions...
[Re: majsteve]
#7992 06/19/02 04:55 PM 06/19/02 04:55 PM |
Joined: Jun 2001 Posts: 292 Long Island, NY Ed Norris
Posts: 292 Long Island, NY | Is the only difference in the bearings? Can one change up to high load simply by changing them?
Thanks
Sail Fast,
Ed Norris
[Re: MauganN20]
#7993 06/20/02 04:35 PM 06/20/02 04:35 PM |
Joined: Jun 2001 Posts: 342 Lake Murray, SC,USA Cary Palmer
Posts: 342 Lake Murray, SC,USA | Any reason you can't just buy a 17 Sport Forestay? How did you convert your old forestay bridle to the new length? If you just added a couple short wires without the foil, I'd be real concerned that you were putting extreme stress on the hulls. The 17 hull is light, would increase the risk of fracturing/collapsing a hull with loading the stress in the direction pulling inward instead of up. The factory front foil is the same stock as a H-17 boom, but I would think any sort of reinforced aluminum tube would work just as well the only point of the foil on the 17 is to keep the working loads on the hulls in the directions for which it is designed, not pulling both hulls inward. If you coupled that with the pressure of the water pushing in the same direction that the forestay is pulling, you have drastically increased the load and are probably looking at a stress failure of the hulls at some point when you're having the most fun.
Just my .02
CARY
Hobie 17 Sport Guy, too
CARY ACAT XJ Special C&C 24
| | | Re: If you need any help
[Re: MauganN20]
#7995 06/21/02 10:48 AM 06/21/02 10:48 AM |
Posts: 390 | Hi Tad, If you need any help rigging your boat, give me a call(919)544-4521. I live in Durham at the edge of RTP. We have a website for Hobie Division 9(ww.hobiediv9.org) with our schedule and contacts. Our fleet, Hobie Fleet 97, serves central NC ( www.rtpnet.org/hobie97/). The next "local" event is the Fourth of July Regatta at Lake Norman Yacht Club ( www.lakenormanyachtclub.com/index.htm) near Charlotte. It is a big event open to any kind of sailboat. There is usually plenty of food, a beer truck, a band and a big fireworks display over the water. The next Div 9 event is the Ya Gotta Regatta at Myrtle Beach, SC (Huntington Beach State Park) on August 17 & 18. Then the Camp Hatteras Regatta in Rodanthe, NC (Camp Hatteras Campground, Hatteras Island) on August 24 & 25. See ya Sam Evans, Commodore, Hobie Fleet 97 | | |
668
guests, and 124
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
