| Re: It's not a cat but....
#80014 07/13/06 04:07 PM 07/13/06 04:07 PM |
Posts: 18 | Wow! How do you get the 3D shape and did you base the design on an existing boat?
Tikoes
FX One 203
[Re: tikoes]
#80015 07/13/06 09:27 PM 07/13/06 09:27 PM |
Joined: Jun 2001 Posts: 12,310 South Carolina Jake OP
Posts: 12,310 South Carolina | The short answer to your question is that this shape is simply hand carved. Bogy, one third of our trio, is quite an artist and carved the plug after we had a sketching session where we came up with several profile sketches of what we wanted this version to look like - narrower than the previous ones and we wanted to try kicking up the bottom of the hull near the stern from the water (like modern catamarans). I wanted to draw it up in 3D on the computer and slice out bulkheads to strip plank build it but Bogy already had this plug and it was very pretty and already proved to be faster than the other versions we had made...it just needed a bit of fairing. So we moved forward with what we already had.
Jake Kohl | | | Re: It's not a cat but....
#80016 07/13/06 10:38 PM 07/13/06 10:38 PM |
Posts: 248 Colorado | Nice work, Jake, that thing's really cool. I've been wanting to get an R/C boat for winter/off-season sailing. Be sure to post pics of the finished product.
H-20 #896
[Re: DHO]
#80019 07/15/06 07:31 AM 07/15/06 07:31 AM |
Posts: 12,310 South Carolina | David
I do have a catamaran ... I'll try and take some pictures this weekend. It's very quick but very sensitive to puffs. I'm reworking the rudder system to get more motion out of the rudders because the boat doesn't steer fast enough right now.
In this boat, the radio receiver will be mounted in teh center of the hull on a plate off the bottom of the boat. A portion of the deck will be removable and will be held in place by a decal that is shaped to the perimiter of the hatch. The boat should be so watertight that that will be all we do there. The on off switch will be connected through the **** bulkhead by a small piece of rod with a ball on the outer end so it's not directly exposed. The charging jack will just be mounted on the same bulkhead with a rubber insert.
Typically, however, like in the catamaran...the receiver is in a plastic bag with a couple of rubberbands surrounding the area where the wires come out to the batteries and the servos. By and large, the servos and batteries are water resistant so if you can keep them from being submerged, they'll be fine.
#80021 07/16/06 12:15 AM 07/16/06 12:15 AM |
Joined: Jun 2006 Posts: 177 Sydney/Northern Beaches Bandit
Posts: 177 Sydney/Northern Beaches | I would reccomend using a party balloon and push your reciver gear inside it and zip tie the open end closed around the wires. Also locate some sponge at the low piont in the hull to collect water and avoid splashing the electronics. Some guys use a sealable lunch box to house there gear with rubber bellows to allow the steering rods to move in and out while keeping the container sealed.
Sail 1635
Blue Tongue
#80022 07/16/06 12:20 AM 07/16/06 12:20 AM |
Posts: 177 Sydney/Northern Beaches | If you need radio gear let me know as I have a full brand new 2ch kit 12 months old with a winch to suit 1 meter class at home. The left overs from projects that time would not permit.
Sail 1635
Blue Tongue
#80025 02/27/07 08:57 AM 02/27/07 08:57 AM |
Posts: 829 Charleston, SC | Jake, you've been sniffin' way too many fumes. It's a little too late for the breather...
Trey
[Re: MauganN20]
#80027 02/27/07 09:14 AM 02/27/07 09:14 AM |
Posts: 12,310 South Carolina | I need to invest in one of dem thingers. I've been sanding way to much pinkfoam and epoxy lately without breathing protection. You appear to be proud of it. The way I see it, a $40 respirator is cheaper than chemotherapy.
#80028 02/27/07 09:26 AM 02/27/07 09:26 AM |
Posts: 3,114 BANNED | You appear to be proud of it. I thought it was funny to take pictures of my white boogars. | | | Re: It's not a cat but....
[Re: Dan_Delave]
#80030 02/27/07 11:14 AM 02/27/07 11:14 AM |
Posts: 12,310 South Carolina | I've got a 4' bed on my pickup with a cap so I definitely need this to be easy to disassemble. This boat will not only be transportable but the hull / keel / radio will have an optional single case available at some later date. We've put a lot of thought into making things assemble quickly and easily while having tight tolerances during production. The keel will be removable with a thumb screw and the stock rig will be detachable by removing four snap clevises.
The keel/bulb/keel fin trunk in the hull is the next major challenge.
These hulls are intended to be laid up in two vacuum-bagged halves and then joined. The majority of the seam will need to be removed after joining but having it there offers some neat advantages that we'll go into detail later.
#80031 02/27/07 03:24 PM 02/27/07 03:24 PM |
Posts: 12,310 South Carolina | I should add that this is a completely revised hull shape from the one I showed earlier in this thread. This one is much narrower and should be a rocket upwind.
Jake Kohl | | |
3,195
guests, and 376
