Mast Leaks/small hull repair #80537
07/18/06 09:43 PM
07/18/06 09:43 PM
dannno Offline OP
dannno  Offline OP
Yup, here it is, another mast leak question. I have searched the forum for the other general mast leak questions, but this one is more specific.
After realizing that my mast was leaking, I thoroughly (or so I thought) sealed all rivets and mast cap with the heavy, white sealer/silicone recommended in previous posts.
But mast is still filling with water quickly following capsize. I've narrowed the leak to just below the mast cap at the top of the mast just behind the top halyard wheel (sorry, don't know what that wheel is called).
It's an alluminum mast on an '86 Nacra 5.0 and before drilling off the cap to see what's going on under there, I was wondering if anybody has any ideas where I'm leaking and whether the leak can be fixed without removing the cap. Is a cap a comp tip? Not sure what that is?
One other question if I may, evidently the keels on the 5.0 are a different compartment from the rest of the hull? I have to use 20 foot wooden ramps to slide my cat in the water off a 3 foot bank. The wood has worn the keel and has resulted in a small hole on the bottom, but I'm not taking on any water in the hulls while sailing.
Two quick questions, is there a quick, strong patch product for the keel until I can give it more attention at the end of the season? 2, I orginally had plastic latice on the ramps, but it was so slippery I could not control the cat up and down the ramp. Any suggestions about what I can add to the wooden ramps to reduce friction but at the same time not make it as slick as the plastice latice (plastic gutters nailed to the ramps?)
Dannno
Re: Mast Leaks/small hull repair [Re: dannno] #80538
07/19/06 08:06 AM
07/19/06 08:06 AM
For the small blind hole here is what I did. It was really easy.
I took a thin square piece of pressure treated wood (the biggest that would fit through the hole). I punched a small hole in the middle of the wood and put some thread through it. I slipped the wood in the hole and pulled it flush. I glued the block in place with super glue. I removed the thread. Then I filled the hole with “Marine Tex.” Once dry, I sanded it flush.
Matt
Re: Mast Leaks/small hull repair [Re: dannno] #80539
07/19/06 08:25 AM
07/19/06 08:25 AM
Danno,
Try putting marine carpet on the ramps - that should make some difference. Keel wear is a pretty standard thing and usually it is repaired by filling any holes and then putting an extra layer of fiberglass or kevlar on the keel. You can usually by a 2" wide roll of fiberglass (or kevlar) that works really well in this application.
Your mast cap is not a comptip - that is a plastic top mast section used on some Hobies and is about 3 or 4 feet long.
I'm not sure exactly what the top of your mast looks like but it sounds like you do need to remove the cap, reseal, and reinstall it. I'm guessing you have a cast aluminum cap that is recessed to fit inside the mast and is riveted in place? If so, just drill out the rivet heads with an oversized drill bit (1/4") (being carefull not to drill out any mast material). Punch the rivets into the mast, remove the cap, apply bunches of sealant (3m 5200), re-rivet the cap in place...alumnimum rivets would be fine in that application - monel as well.
Re: Mast Leaks/small hull repair [Re: Jake] #80540
07/19/06 08:36 AM
07/19/06 08:36 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
And, while you have the cap off, turn your mast upside down to get out anything that might be in there, like the inside of rivits that you drilled out.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Mast Leaks/small hull repair [Re: Chris9] #80541
07/19/06 10:13 AM
07/19/06 10:13 AM
I was hoping to do this when I removed the bottom mast casting (broke when putting up mast when I tried to straighten it too early). But I found out it was sealed about 7 cm from the base! I can't imagine how many rivets are in the mast- but probably less than in the HULLS!!!
BTW... good luck with getting the cap off. I about had a stroke trying to get the bottom off fighting the sealer and tryingnot to destroy the mast.
Re: Mast Leaks/small hull repair [Re: PTP] #80542
07/19/06 11:12 AM
07/19/06 11:12 AM
Electric paint stripper heatgun. Use carefully though!!!
Re: Mast Leaks/small hull repair [Re: Jalani] #80543
07/19/06 03:42 PM
07/19/06 03:42 PM
dannno Offline OP
dannno  Offline OP
Thanks all -
I did seal around the mast cap last season, but evidently, based upon the flow coming from that area when I raised my mast out of the water, you cannot properly seal the cap without first removing it.
There will be no plug or anything in the there that will have to be replaced? Just the cap/seal keep the water from entering the top of the mast?
Danno
Re: Mast Leaks/small hull repair [Re: dannno] #80544
07/19/06 04:19 PM
07/19/06 04:19 PM
NC
lowpuller Offline
lowpuller  Offline
NC
I would suggest a fence pole with winch mounted on it to control your boat when putting it in and out of the water, slick means less wear, less wear is better
Re: Mast Leaks/small hull repair [Re: lowpuller] #80545
07/20/06 12:44 PM
07/20/06 12:44 PM
dannno Offline OP
dannno  Offline OP
I've got that part figured out. I have a come-a-long permanently secured to a tree to pull the cat up the ramps -but that platic latice was way to slick, but would be a great way to move cats around on flat areas.
Dan
Re: Mast Leaks/small hull repair [Re: dannno] #80546
07/20/06 12:58 PM
07/20/06 12:58 PM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
Our fleet uses PVC Pipe, you could nail or screw several rows of the pipe in place and than you would also have foot holds.
Just a thought.
Sam
[b] Sail Like you have a Pair
Re: Mast Leaks/small hull repair [Re: Banzilla] #80547
07/20/06 01:03 PM
07/20/06 01:03 PM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
if the problem is controlling sideways motion, the gutter would work or how about lengths of pvc pipe that the boat would kind of sit in?
If the problem is footing, make several ladder rungs by securing the pvc pipe across the ramps. maybe both.
0 registered members (), 463 guests, and 41 spiders.
