| Re: Eigenbaum 38? Know anything about it?
[Re: Sycho15]
#80769 07/25/06 08:50 AM 07/25/06 08:50 AM |
Posts: 591 Bradenton, FL | OK, I finally found some information on this boat and figured I'd post it in case some of you come across one yourselves some day.
Mr. Eigenbaum built ~30 boats in northern FL. This one in particular was built in wood/epoxy composite.
It is 38' long, 23' wide, and has an 18" draft. The open bridge-deck has an underbelly clearance of ~3' to 3.5' to the water. There is one dagger-board in the port hull.
Accomodations are a double, with head and sink, in each hull. Electronics and Nav to port and Galley to starboard
Hobie 14T
[Re: David Parker]
#80771 07/25/06 01:57 PM 07/25/06 01:57 PM |
Posts: 591 Bradenton, FL | I'm not sure I can/should post information like that on this forum as the boat is not advertised with Catamaran Sailor magazine. It's not mine, but I'd need a go-ahead from Rick or Mary before I'd post that type of information. I've called the owner and gotten all the information on it, whats new, what needs work, etc.
I'm desperately trying to get out of debt and get a second job to replace the one I've lost so I can afford it.
Hobie 14T
274
guests, and 53
