| Re: Stilletto 23
[Re: I20RI]
#81223 07/29/06 09:20 AM 07/29/06 09:20 AM |
Posts: 591 Bradenton, FL | Look up Eric Sponberg on google. I'd be willing to be he could design you a composit mast that you could build yourself, or at the very least direct you to a good builder for what you need. He's best known for his freestanding, rotating wingmasts, and as such is highly knowlegeable in all things carbon.
Also, weigh your rigging. I bet you could save quite a few pounds by going with synthetic rope rigging instead of wire.
Hobie 14T
| | | Re: Stilletto 23
[Re: I20RI]
#81224 07/29/06 09:27 AM 07/29/06 09:27 AM |
Joined: Jan 2006 Posts: 195 Straight Outta Hell Boudicca
Posts: 195 Straight Outta Hell | There is a similar boat to your description, but it's a 27 come to think. It's in Birmingham AL. Tom Shannon, who monitors this list, knows the owner. That, and the Granger family, who modified my Fboat, are now working on a S27. They're doing ten kinds of mods to it. Contact the Grangers vis www.tcdyc.com and see if they can offer you suggestions. Hell, a stock S23 is a sweet ride stock (with updated sails). Have you thought about getting in touch with Ron Nicol over there in Florida? good luck with it, tami | | | Re: Stilletto 23
[Re: Boudicca]
#81227 07/29/06 03:42 PM 07/29/06 03:42 PM |
Posts: 1,121 Eastern NC, USA | It's a 23. Built to the specs you are talking about (carbon beams, mast, titanium parts to replace stainless, flathead, reacher, VERY cool graphics, blah, blah, blah). Very fast and almost too much boat over 12 knots of breeze
I'll PM some contact info to you.
Tom | | | Re: Stilletto 23
[Re: I20RI]
#81228 08/13/06 02:36 AM 08/13/06 02:36 AM |
Posts: 55 Los Angeles, CA | I have a mothballed stiletto 23 that I want to modernise with carbon rig and new foils. I thought that the rig for a f25c might do the trick, but I cant seem to find one. Does anyone have any ideas or feedback. I may just wind up seeing if Hall or southern or someone can make a custom one, but it would be much cheaper to find an existing section. What boats have 36 foot long rotating carbon rigs?
charlie I've been thinking about doing exactly the same thing...! The 25c rig is too heavy... Hall was too expensive... Dealing with Marstrom is a nightmare unless you are buying something they sell off the shelf (or ordering something REALLY expensive). What did Southern quote you? I'm not sure I would want a Southern spar, though... However, I ~may~ have received an interesting price from Forte RTS/Van Dusen Composites. PM me and I'll send you the 'details'. We can see if an order for 2 masts affects pricing. That would be good. Christopher | | | Re: Stilletto 23
[Re: chrisun]
#81230 08/14/06 11:05 AM 08/14/06 11:05 AM |
Joined: Jun 2001 Posts: 160 Connecticut Eric Anderson
Posts: 160 Connecticut | You guys should give Jeff Kent a shout. this sounds like a project that might be perfect for CSI. Actualy come to think about it you could get Henry Bosset at North sails to build the sails for the spar and I bet it would be awesome. Jeff is set up well for one off construction projects and their quality is awesome. Jeff is a former Tornado Helmsman who won the tornado olympic trials with Henry the year the US Boycotted the Games. Jeff also won the DN world Champs. Nice guy, good shop. I am not in any way affiliated with Jeff, but I do own a couple of his masts. http://www.csi-composites.com/Eric | | | Re: Stiletto 23
[Re: bvining]
#81233 08/15/06 05:55 AM 08/15/06 05:55 AM |
Posts: 53 CT Shoreline | $20 bucks a pound - very rough ballpark.
Another source for custom mast is Forte -www.forterts.com So what does a 36' carbon mast weigh? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> | | | Re: Stiletto 23
[Re: Eric Anderson]
#81235 08/15/06 07:48 AM 08/15/06 07:48 AM |
Posts: 1,226 Atlanta | $20 per pound was a guess knowing that carbon is $12 per pound.
My Hall Acat mast is $109 per pound - $2400 divided by 22lbs - thats clear coated and with a carbon gooseneck. Its a hand crafted part, with low amounts of carbon as compared to the amound of labor required to build it. Clear coating and the gooseneck add to the cost, but I dont remember the exact amounts.
My Forte HT mast is $29 per pound - $1300 divided by 44lbs -just the bare tube, no clear coat, built on a mandrel using a machine, with minimal labor - as compared to the Hall.
So, I would expect the heavier Stiletto mast to be closer to the Forte per pound price than the Hall per pound price, since it has more carbon and would probably need about the same amount of labor as any other composite tube.
I bet $50 per pound is probably a better number for a mast like that. Cheaper from a company that can use a machine to produce or that already has a mold, more expensive from a company that hand crafts it.
The mast makers are going to want to know what the old one weighed, the length, wall thickness and the profile to give you a good number.
Bill | | | Re: Stiletto 23
[Re: I20RI]
#81238 08/15/06 10:17 AM 08/15/06 10:17 AM |
Posts: 1,226 Atlanta | wow, 12 grand? How long is it? 40lbs, thats light, I would have expected it to be heavier. If you can afford it, it sounds like a sweet part. I've been very impressed with everything I've seen from them, they do nice work.
I would call Tony at Forte, he's making me a 33ft wing mast for $1300. He's using a Tornado wing mast section as a mandrel, so the part is going to be slightly larger than a T mast. I'm going to need to finish it myself, but thats not hard. Going to use a clear water based 2 part poly, System 3 as the finish once I sand the surface smooth.
Whats the shipping from Sweden? Make sure it goes in a container or it will get busted. I've heard plenty of stories of Acat masts that got shipped individually and they've all gotten ruined. I wouldnt risk it.
[Re: bvining]
#81239 08/15/06 10:42 AM 08/15/06 10:42 AM |
Posts: 4,451 West coast of Norway | Bill, what project will you use the tornado-moulded carbon tube on? Just curious.. BTW: Do you really consider the tornado sections as wing-shapes? The custom work Marstrøm does is very nice, and they are experts on pre-preg carbon stuff. I believe Torbjørn Linderson used to design their rigs, but I see they are searching for an engineer to lead their spar building team.. Ref: http://www.linderson.com/http://www.marstrom.com/ | | |
2,593
guests, and 166
