Spitfire with Broken Beams #81331
07/31/06 07:10 AM
07/31/06 07:10 AM
taipanfc Offline OP
taipanfc  Offline OP
Hi All
Not something you normally see, but passed a Spitfire that had broken one of its beams. Racing on a Farr 40 at Cowes Week so this was in The Solent. The 2 hulls looked to be fine as they were floating above the water with no obvious damage to them. Guys were OK and in the process of being helped by a rescue boat. Big job dismantling the boat to be towed in. Weather wasn't that bad being 15-20 knots and waves fairly flat. Can only postulate that the dolphin striker broke, or the beam failed.
JC
Re: Spitfire with Broken Beams [Re: taipanfc] #81332
07/31/06 07:39 AM
07/31/06 07:39 AM
Dubai, UAE
davidh Offline
davidh  Offline
Dubai, UAE
No dolphin striker on the spitfire.
Dave H VWM Blade F16 UAE719 Dubai
Re: Spitfire with Broken Beams [Re: taipanfc] #81333
07/31/06 07:50 AM
07/31/06 07:50 AM
Do you have the web address to view the starts at Cowes? The Spitfire I sailed on was very stout, I can't imagine a beam breaking, maybe it came unbolted from the hull? I've seen that happen on other boats. Thanks.
Re: Spitfire with Broken Beams [Re: davidh] #81334
07/31/06 07:50 AM
07/31/06 07:50 AM
Z beam instead.
Maybe they got hit / Hit something ?
Re: Spitfire with Broken Beams [Re: Timbo] #81335
07/31/06 08:59 AM
07/31/06 08:59 AM
Gower, Wales, UK
sailwave Offline
sailwave  Offline
Gower, Wales, UK
The webcam is on www.cowes.co.uk (erractic here) and the radio is on www.skandiacowesweek.co.uk
Re: Spitfire with Broken Beams [Re: sailwave] #81336
07/31/06 12:25 PM
07/31/06 12:25 PM
Thanks and good luck in the racing. I'll be flying over the Needles about 09:00 local on Weds. morning, I'll be looking for you!
0 registered members (), 274 guests, and 52 spiders.
