| Re: mast floats
[Re: MarkW_F18]
#81642 08/03/06 06:11 PM 08/03/06 06:11 PM |
Posts: 5,582 “an island in the Pacifi... | ...if a Tiger were flying the spinaker and was traveling West at 24 knots were to colide bow to bow with a H16 traveling north and close hauled at 16 knots, which boat would incur the most damage. Last century's technology will chew up the Tiger and use the mast for a tooth pick. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: mast floats
[Re: mbounds]
#81643 08/04/06 08:16 AM 08/04/06 08:16 AM |
Joined: Jun 2006 Posts: 35 Charlottesville, VA sruffner
Posts: 35 Charlottesville, VA | Tami - I'm a diver and a former chemist too. Here's a few things about neoprene:
- blown foam neoprene ala wetsuits does absorb some moisture; solid neoprene ala mechanical seals does not do so nearly so quickly. This has much less to do with the chemical structure of neoprene, than the construction of the material.
- sweaters work the same way as wetsuits do - air can get through your sweater, but the sweater traps a layer of air you've warmed with your body heat as an insulative layer. Air is not as conductive as other things. Although sweaters work to keep you warm (just wear one on a sunny day), you notice that cold air does still get through (why you still need a windbreaker on a chilly windy day). Neoprene wetsuits aren't nearly so permeable, but they are still permeable. This is less a physical property of the compounds in question than a mechanical property of their assembly.
- wetsuits do have pockets of air trapped in the foam 'matrix' - that accounts for bouyancy - but some water does get in through there. As Matt the Hobie guy says, a mast full of mostly air is more bouyant - that's because that air amounts to a giant air pocket/bubble, instead of lots of tiny ones.
Water molecules are rather small, just like, say, diatomic helium (think balloons), and they are capable of getting through very small "holes" in the 'matrix' of most solid compounds. You will notice that a helium balloon loses gas slowly, over a couple of days. That's because there are lots of very tiny holes - spaces between the rubber molecules - in the rubber of the balloon - and the gas leaks out very slowly through those holes, but it does.
Similarly, in neoprene foam, there are lots of tiny "faults" and voids in the neoprene, in addition to the air pockets. Water makes it's way in there. I think it's likely that neoprene that spends it's time at the top of a mast 99.9% of the time would stay pretty dry. But, Polystyrene (good old foam cooler material) foam is probably lower density. That stuff is also water-permiable, BTW. IIRC, the only mast float I've ever seen, on an Aqua-Cat, had a plastic skin around a polystyrene core - the skin helped provide mechanical protection, while the core provided bouyancy.
Finally - that's a great avatar. | | | Re: mast floats
[Re: sruffner]
#81644 08/04/06 08:23 AM 08/04/06 08:23 AM |
Posts: 3,348 | | | | Re: mast floats
[Re: David Parker]
#81646 08/04/06 09:42 AM 08/04/06 09:42 AM |
Posts: 35 Charlottesville, VA | diatomic == di-atomic == two atoms bonded == He2 http://en.wikipedia.org/wiki/DiatomicHelium is an ideal/inert gas, so, truthfully, He2 is not really stable - you have to pop some serious energy into it to get it to form, and it will quickly decay from that state back to a lower-energy (2)He (unbonded atoms). H2 is what was in my head, but then I though, nobody uses that anymore (at least since the Hindenburg!), so it would be a poor reference. I should've picked a different (and better) example. H20 is a much larger molecule/structure than a simple He atom. Nevertheless, I think the explanation still stands and is completely valid. I'm sure the mechanical engineers immediately thought of a mechanical seal, not unlike, say, the rear main oil seal on the crankshaft of your car (though neoprene pretty much rocks for all sorts of mechanical seals plenty of which are "watertight"). Because Water (H20) and oil (hydrocarbons - C(n)H(2n+2)) are much larger structures, they don't seep through as quickly. The real point of all this is: the bouyancy of the wetsuit is due to the air bubbles in the foam. The same properties make it susceptible to absorbing moisture. The older the suit, the more it will absorb, due to UV damage (breakdown of the neoprene) and mechanical breakdown (the little bubbles get broken open). | | | Re: mast floats
[Re: David Parker]
#81647 08/04/06 12:20 PM 08/04/06 12:20 PM |
Posts: 3,348 | dilithium crystals. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Can they be smoked? | | | Re: mast floats
[Re: fin.]
#81648 08/04/06 01:57 PM 08/04/06 01:57 PM |
Joined: Jun 2001 Posts: 975 South Louisiana, USA Clayton
Posts: 975 South Louisiana, USA | dilithium crystals. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Can they be smoked? Judging from your pic... somebody has???? <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> | | | Re: mast floats
[Re: sruffner]
#81650 08/04/06 04:13 PM 08/04/06 04:13 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | [color:"red"] "Helium is an ideal/inert gas, so, truthfully, He2 is not really stable" [/color] Right, it's NEVER been seen under terrestrial conditions, ever. You're right about He being small and a ballon is porous to it. However, your comment about H2 not being used anymore, here's a bit in use. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> ![[Linked Image]](http://static.howstuffworks.com/gif/space-shuttle-launch3a.jpg) | | | Re: mast floats
[Re: David Parker]
#81656 08/05/06 04:04 PM 08/05/06 04:04 PM |
Posts: 1,383 Kingston SE South Australia | Doesn't Hobie use a glued on neoprene anti-slip panel along the tramp frame? Does that feel spongy or water-filled?
Remember those thin neoprene bikinis back in the 80's? They were pure rubber, very thin with no fabric backing. They never seemed to get soggy. In fact, they seemed pretty hot at the time! I doubt if what looked good then looks as good now. See attached. Your my kind of scientist David.
1,271
guests, and 56
