| Re: I20 jib and self tacker
[Re: EasyReiter]
#81733 08/04/06 02:41 PM 08/04/06 02:41 PM |
Posts: 12,310 South Carolina | You also have a choice of fully battened self-tacking jib or a regular roller furling jib - dacron or Pentex. Having tried both self-tacking jibs, I don't think there's is much (if any) advantage to the fully battened jib. We ended up taking out the top batten because we could never get it to shape right (and I tried everything I could think of). Many folks think you can't go wrong with the roller furling (non fully battened) dacron jib - personally, I think they're all pretty even. Do note that if you go with the fully battened jib, you loose the capability to roller furl it.
Jake Kohl | | | Re: I20 jib and self tacker
[Re: Keith]
#81735 08/04/06 09:43 PM 08/04/06 09:43 PM |
Posts: 6,049 Sebring, Florida. | You don't have to buy a new jib for the self tacker, they sell a clew plate you can rivet on to your existing jib that has the holes for adjustment in it. You might want to take it to a sail maker to have them get it on correctly as you will have to cut about 45 degrees across the bottom corner of the old jib clew.
I had the same trouble with the full batten jib, the top batten was too flat, so I cut it out and installed a very light strip of fiberglass and sewed it in. In heavy air I liked the mylar full batten jib, in light air the dacron jib seemed to have a better shape. Either way, it is well worth the effort to install the self tacker as it will make your tacks much faster and the crew can get out on the wire faster too. They will thank you for it!
Blade F16 #777
[Re: Timbo]
#81736 08/04/06 10:16 PM 08/04/06 10:16 PM | Anonymous
| Anonymous
Unregistered | Marc:
My Pentex reacher furls real easy with 1 to 2 system and the telltales always flow good, light or blowing stink. Furler is nice when the wind picks up and you just want to chill or when you are waiting between races.
Doug | | | Re: I20 jib and self tacker
[Re: Chris9]
#81738 08/05/06 10:01 AM 08/05/06 10:01 AM |
Posts: 12,310 South Carolina | The cut of the jib is different - the foot is shorter. I've tried sanding the batten, I've tried putting a string tensioner on the batten, but nothing really got it shape well in light air.
[Re: Rolf_Nilsen]
#81740 08/05/06 11:48 AM 08/05/06 11:48 AM |
Posts: 12,310 South Carolina | I have noticed pretty much the same thing with the Tornado. The top batten in the jib is so short that it flattens out the sail too much in light winds. Surely SOMEBODY thinks that batten is a good idea?
[Re: Chris9]
#81742 08/05/06 11:47 PM 08/05/06 11:47 PM |
Posts: 1,459 Annapolis,MD | I've been relegated to "another Team" hmmm....:) I'll take MY crew back!! We're both through with your crew, he's found his own ride! By the way, the jib I'm using is borrowed from yet another team, and that boat has self tacker while our boat does not. I wonder... | | |
3,695
guests, and 114
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online4,027 1 hour ago | | |
