| Re: anti slip on marstroem cats?
[Re: Dirk]
#82163 08/10/06 09:06 AM 08/10/06 09:06 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | You can also add it to the paint and spray it on or you can spray one coat of paint on then using something like a salt shaker, shake some additive onto the wet paint then recoat with paint. This is a good way to do smaller areas.
I would use the finest additive you can find. Less wear on you and your gear.
[Re: catman]
#82164 08/10/06 11:20 AM 08/10/06 11:20 AM |
Posts: 185 Shanghai, China | great answers! thanks guys!
Dirk
A-Cat GER 5
F-16 CHN 1 (sold)
SC 6.5 CHN 808
[Re: catman]
#82167 08/11/06 09:11 AM 08/11/06 09:11 AM |
Posts: 1,187 38.912, -95.37 | You can also add it to the paint and spray it on or you can spray one coat of paint on then using something like a salt shaker, shake some additive onto the wet paint then recoat with paint. This is a good way to do smaller areas.
I would use the finest additive you can find. Less wear on you and your gear. From personal experience sailing hp dinghies. Emphasis on "the finest additive you can find". Otherwise you'll be replacing trap harness, boots (barefoot not an option) maybe a wetsuit every season or so and you'll end up with some nice scars on ANY exposed body parts. Tape some 120 grit on the hulls and check it out.
[Re: carlbohannon]
#82169 08/12/06 07:56 AM 08/12/06 07:56 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Don't try to sprinkle nonskid on 2 part paints unless you test it on scrap. A lot of these paints are really poor adhesives. The nonskid just will not stick. You have to mix the 2.
I have a crater shapped spot on my Tornado because I tried that Anytime you try a project like this you should always pratice on some scrap. Some paints do flash quickly which might cause adhesion problems. Of course all paints are not created equal. I've used Imron to do both methods and have had no problems. This stuff sticks and is sticky.
20,053
guests, and 1,598
