What kind of rope should I use? #8217
06/25/02 09:46 AM
06/25/02 09:46 AM
Anonymous OP
Anonymous OP
I have an h14 and I want to re-lace the tramp, what kind of rope should I use?
Re: What kind of rope should I use? #8218
06/25/02 10:23 AM
06/25/02 10:23 AM
http://www.nahca.org/hobies/hobie14_linelengths.htm
I use the same site for my 17 line lengths and types. So far, its been pretty accurate on everything except for my trapeze lines. (11' shock cord on a 17 is a bit to long [Linked Image] )
Re: What kind of rope should I use? #8219
06/25/02 10:24 AM
06/25/02 10:24 AM
I seem to remember that sailors didn't use lines for those H14 and H16 tramps but rather a thick diameter bungee cord.
Re: What kind of rope should I use? [Re: Wouter] #8220
06/25/02 12:19 PM
06/25/02 12:19 PM
Anonymous OP
Anonymous OP
I just relaced my H-16 tremp with 7/16" uv resistant shock cord. If you use shock cord you want to be sure and stretch it very tight. It's not the easiest stuff to work with but if you take your time and get it tight the end result is a nice taught tramp.
Re: What kind of rope should I use? #8221
06/25/02 01:52 PM
06/25/02 01:52 PM
Reno, NV
pschmalz Offline
pschmalz  Offline
Reno, NV
I've heard that using shock cord instead of line will increase the lifespan of the tramp. That way the cord will absorb some of the impact loads.
Re: What kind of rope should I use? [Re: pschmalz] #8222
06/25/02 03:28 PM
06/25/02 03:28 PM
As a general rule, if you were to use shock cord instead of regular line, what length proportionally should you get? I imagine if you use the same length shock cord, your butt would be getting wet [Linked Image]
Re: What kind of rope should I use? [Re: MauganN20] #8223
06/25/02 04:07 PM
06/25/02 04:07 PM
Anonymous OP
Anonymous OP
Thats why you have to pull the shock cord extremely tight. I can't remember the lengths but murray's sells the kit. I think it's only about $12-$16.
Re: What kind of rope should I use? [Re: MauganN20] #8224
06/27/02 04:28 PM
06/27/02 04:28 PM
Sailortect Offline
Sailortect  Offline
I thought that tramp tension was good because it affected hull stiffness?
I laced my H16 with 1/2" pre-stretched halyard line and two pairs of vice-grips. by the time I was done the side beams were each curved inward by about 2"
Re: What kind of rope should I use? [Re: MauganN20] #8225
06/27/02 05:28 PM
06/27/02 05:28 PM
Bogie Offline
Bogie  Offline
Just used the Murrays Shock Cord lacing kit a week or so ago. The Advertised lengths are 20' center by two 15' end sections. There was a noticeable disparity between the amount of cord given for the center section and the amounts for the end sections. The center section had lots of length left over before the cord was stretched. The end pieces had a little left over after they were stretched tightly into place.
This might be because after 83, the rear tramp section was double grommeted, and 15' is the old measurement. Just guessing.
0 registered members (), 20,501 guests, and 1,179 spiders.
Most Online23,137
40 minutes ago
