Hull Shape Question #82270
08/10/06 05:04 PM
08/10/06 05:04 PM
N
nhsailor Offline OP
nhsailor  Offline OP
N
I've got a 79 H16. Thinking about a new boat of some sort next year.
In looking at new boat options, seems the H16 is the only boat with rockered hulls? I like the idea of a brand-new H16 since I'm familiar with it, but can't help wonder if the shape of the hulls is somewhat outdated.
Is my assumption that a hull shape with less rocker has advantages over the old H16 design?
Re: Hull Shape Question [Re: nhsailor] #82271
08/10/06 06:19 PM
08/10/06 06:19 PM
Coopersburg, PA
V
Vinny_M Offline
Vinny_M  Offline
V
Coopersburg, PA
Funny, I was under the impression that the newer models had more of a curve built into the hulls. I could be wrong though, so it would be best to investigate the matter. Maybe mmiller could help us out with this one because I'm at a loss.
~vinny~
Re: Hull Shape Question [Re: Vinny_M] #82272
08/10/06 09:39 PM
08/10/06 09:39 PM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
Is this worth buying a ticket for???
[b] Sail Like you have a Pair
Re: Hull Shape Question [Re: Vinny_M] #82273
08/11/06 12:40 AM
08/11/06 12:40 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Unless you sail in surf do yourself a favour and go out on any daggerboarder of 16 or over. I took an H16 freak out recently on my old Hydra (16 foot Tornado copy) and he was shocked by how benign and well behaved it was. You can just go out in stronger weather if you need to be "on the edge".
The great thing about going from H16 to say an F18 (apart from speed) is that your reactions will seem superhuman. You will need to learn a little more about sail tech and trim. Those old Hobies are strong platfroms though eh!
Outdated is kind as far as the hulls are concerned.
only opinion so don't wet yourself if you love your H16.
Re: Hull Shape Question [Re: nhsailor] #82274
08/11/06 02:08 AM
08/11/06 02:08 AM
maui
jollyrodgers Offline
maui
you will find that the gcats have a well curved rocker line.
there was a year when a gcat 21 almost won the worrell 1000. the write up claims the g21 was quite abit faster than thae tornado, and did well to windward inspite of having no daggerboards.
Re: Hull Shape Question [Re: nhsailor] #82275
08/11/06 05:48 AM
08/11/06 05:48 AM
nh sailor,
Are you in a position to try modern 16 or 17 ft boat ?
If so try one, you'll know the difference soon enough.
In the way of 16 footers I can help you get on a boat, crews enough that will take you for a ride. It has been done often in the past.
Where are you located
0 registered members (), 2,424 guests, and 182 spiders.
