Marine-Tex Penetrating Epoxy #82276
08/10/06 05:39 PM
08/10/06 05:39 PM
Albuquerque NM
Banzilla Offline OP
Banzilla  Offline OP
Albuquerque NM
Can either of these products be used for a de-lam repair on an H16? Will they melt the foam core? I ask, because I can get it localy and would like to do the repair before going to the lake tomorrow afternoon. It talks about a low % of solvent.
http://www.marinetex.com/PRODUCT%20PAGE_...y%20General.htm
or
http://www.evercoat.com/productDetail.aspx?pID=21
Thanks
Sam
[b] Sail Like you have a Pair
Re: Marine-Tex Penetrating Epoxy [Re: Banzilla] #82277
08/10/06 05:51 PM
08/10/06 05:51 PM
N
nhsailor Offline
nhsailor  Offline
N
I'd use the Marine-Tex. The second won't fully harden up. Either way, you've got to use an epoxy product so it will adhere to the inside surfaces. If you are talking about a soft deck, I wouldn't worry about the foam. I just did my boat and the foam was very crumbly disintegrated anyway.
I'd recommend buying more epoxy then you think you'll need, then return what you don't open if possible. I don't remember exactly, but I'm sure the 4oz kit won't be enough.
Re: Marine-Tex Penetrating Epoxy [Re: Banzilla] #82278
08/10/06 06:26 PM
08/10/06 06:26 PM
catman Offline
catman  Offline
You could make an argument for either product.
The only thing is if you do it now and then go sailing tommorrow no matter what you use, you will be wasting your time. The resin needs a week to cure to about 90%. A month to fully cure.
So what you need to do is do it now and go sailing next week or go sailing, take it easy and then do the repair when your done. Give it the time to cure as much as possible.
Since this repair (depending on size) is just a band aid and the area will most likely need attention again. I would use the polyester. The polyester will stick to cured poly better than epoxy will stick to cured epoxy. I would thin it a little and add a little mill fibre to it.
Re: Marine-Tex Penetrating Epoxy [Re: catman] #82279
08/10/06 06:38 PM
08/10/06 06:38 PM
Albuquerque NM
Banzilla Offline OP
Banzilla  Offline OP
Albuquerque NM
Mike, thanks for the advice. I am going to wait and do the repair next week, that way I can order the right stuff from Rick and do the job correctly even maybe add the ports.
Our Local fleet will be at NM's largest lake Elephant Butte (not that big of a lake) this weekend roasting a pig for their annual Luau.
Sea ya on the water
Sam
Re: Marine-Tex Penetrating Epoxy [Re: catman] #82280
08/10/06 07:11 PM
08/10/06 07:11 PM
Actually that's not true - epoxy sticks better to cured poly than poly sticks to cured poly. Epoxy sticks better to everything - but not everything sticks well to epoxy. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Re: Marine-Tex Penetrating Epoxy [Re: Jake] #82281
08/10/06 07:54 PM
08/10/06 07:54 PM
catman Offline
catman  Offline
The point is he will most likley have to mess with that area again. He cannot gain access to that area to prep it for another repair. Poly cures tacky, Epoxy cures smooth and slick. If it was a very small area and you knew you could effect a permanent repair then I would use the epoxy.
You should add the word cured between to & epoxy.
Including Epoxy. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> back at ya
If I was going to do the repair I would use Vinyl Ester.
Re: Marine-Tex Penetrating Epoxy [Re: Banzilla] #82282
08/11/06 01:01 PM
08/11/06 01:01 PM
Houston
carlbohannon Offline
Houston
If this is like "GIT-ROT" way down in the fine print is a notice something like
"do do mix if above 90F, mixture will boil"
They are not kidding and the scalding hot liquid sticks to you when it boils
chill both components down to about 45F if it's above 90F where you are.
Re: Marine-Tex Penetrating Epoxy [Re: carlbohannon] #82283
08/13/06 07:07 PM
08/13/06 07:07 PM
I was using some epoxy in an attempt to repair a friend's sunfish and mixed up some epoxy in 90-95 degree heat in a plastic container and it got so hot I couldn't hold it anymore.
0 registered members (), 286 guests, and 733 spiders.
