Halyard Hook-Comptip: Rivets with Sleaves #82507
08/14/06 02:47 PM
08/14/06 02:47 PM
E
Eric_Lunceford Offline OP
E
Should have added this to the original post:
I cannot get the rivets with sleaves to grab. The holes that are there (in the wrong place) are a little oversized. Is that what is wrong? The rivet just expands through the depth of the hole and does not grab at the back. Should the sleave fit tightly in the hole for it to grab properly. I have tried this 3 times and am getting a bit frustrated. The last time it came loose, I broke my halyard!
I am considering not using the sleaves and just silicone in/around the hole and on the back of the hook and all around it. Is this a bad idea?
---------- '86 Hobie 16 Lake Hefner, OK
Re: Halyard Hook-Comptip: Rivets with Sleaves [Re: Eric_Lunceford] #82508
08/14/06 03:48 PM
08/14/06 03:48 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
You can get rivet casings from Murray's that will shim enlarged holes. Part # 19-5020 $.70 ea.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Halyard Hook-Comptip: Rivets with Sleaves [Re: hobie1616] #82509
08/15/06 08:56 AM
08/15/06 08:56 AM
E
E
Thanks Mike.
I am already using the sleaves, but the holes are larger than the sleaves. I am guessing that is why they would not grab.
Re: Halyard Hook-Comptip: Rivets with Sleaves [Re: Eric_Lunceford] #82510
08/15/06 12:35 PM
08/15/06 12:35 PM
Clinton, Mississippi
rattlenhum Offline
rattlenhum  Offline
Eric: Every H-16 comp tip halyard hook I've ever seen was mounted with stainless steel machine screws....not rivets. Not exactly sure of the size (M. Miller at Hobie could probably tell you), but I'm guessing something like 3/16" by 1". If you've buggered up the holes with rivets/casings, you might need to refill with epoxy/fiberglass strand and re-drill pilot holes. JB Weld would probably even work.
Jerome Vaughan
Hobie 16
Clinton, Mi'sippi
Jerome Vaughan
Hobie 16
Re: Halyard Hook-Comptip: Rivets with Sleaves [Re: Eric_Lunceford] #82511
08/15/06 12:36 PM
08/15/06 12:36 PM
hobie1616 Offline
hobie1616  Offline
Sounds like you need to find something to fill the holes with and redrill. Post a note in the general forum. I bet Jake or one of the other guys who have done complete boat rebuilds will have a good idea.
0 registered members (), 485 guests, and 97 spiders.
Posts267,056
