Nacra 5.5 rudders #82524
08/15/06 07:39 AM
08/15/06 07:39 AM
White Bear Lake, MN
h17racer Offline OP
h17racer  Offline OP
White Bear Lake, MN
Could someone give me pointers on replacing the pull-up bungee lines on a Nacra 5.5 rudder system?
It looks pretty straight forward. For each, the plan is to use 5' of 5/16 shock cord with a couple of stainless hog rings to bind the bungee ends. Could it be that simple?
Pull-downs will be replaced at the same time with a 3/16" prestretch line.
Sail fast, Tom G
Re: Nacra 5.5 rudders [Re: h17racer] #82525
08/15/06 07:49 PM
08/15/06 07:49 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
I replaced the same lines on my 5.2 . It is that simple.
-Rob V.
Panama City
Nacra 5.2
Rob V. Nacra 5.2 Panama City
Re: Nacra 5.5 rudders [Re: h17racer] #82526
08/15/06 08:08 PM
08/15/06 08:08 PM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
Sail fast, Tom G
I took the opportunity to eliminate the bungies and went with a pull up / pull down system. I much prefer the ability to lock the rudders at any setting in between all the way up and all the way down.
Good luck,
Greg
Re: Nacra 5.5 rudders [Re: bullswan] #82527
08/16/06 03:24 AM
08/16/06 03:24 AM
Kennethsf Offline
Kennethsf  Offline
Bullswan
which system did you use?
Re: Nacra 5.5 rudders [Re: Kennethsf] #82528
08/16/06 07:38 AM
08/16/06 07:38 AM
White Bear Lake, MN
h17racer Offline OP
h17racer  Offline OP
White Bear Lake, MN
Thanks for the suggestions. Did one rudder last night. Simple, although lesson learned, always recheck the precut lengths before installing. Guess the cordage person decided to be a bit generous.
Sail fast, Tom G
Re: Nacra 5.5 rudders [Re: Kennethsf] #82529
08/16/06 02:20 PM
08/16/06 02:20 PM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
Bullswan
I got rid of the bungie cords and use two pull cord lines one to pull the rudders down and one to pull the rudders up. I used two Ronstan Cleats so that I can adjust the amount of UP or the amount of DOWN I want and it stays there. I also got rid of the slop in the tiller/tie bar connection by using tie-rod ends instead of the existing connectors. I got the idea from a prior posting. Can't take credit for what I stole!!! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Greg
Re: Nacra 5.5 rudders [Re: bullswan] #82530
08/17/06 08:11 AM
08/17/06 08:11 AM
Kennethsf Offline
Kennethsf  Offline
Bullswan
Greg
Guess it was me, I posted a picture with the tie-rods about a year ago, still works perfect for me. Nice to see that you use them as well!!
Re: Nacra 5.5 rudders [Re: Kennethsf] #82531
08/17/06 08:30 AM
08/17/06 08:30 AM
White Bear Lake, MN
h17racer Offline OP
h17racer  Offline OP
White Bear Lake, MN
Ken, for those of us who did not see your tie-rod ends. Could you enlighten further? I added Hobie 20 connectors to my H17 and they worked rather well.
Just finished refurbishing my rudders and they work like a dream. I added Hobie connector bushings in each of the pin connector points and basically eliminated all of the connector looseness.
Rudder bushings are next.
Sail fast, Tom G
Re: Nacra 5.5 rudders [Re: Kennethsf] #82532
08/17/06 09:15 AM
08/17/06 09:15 AM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
Bullswan
Greg
I'm sorry Ken for not giving you the credit directly but I did use your suggestion from last year and I love it. I didn't use the control lever on the rudder arms you designed. Instead I went with two simple Ronstan Cleats to control up and down of the rudders.
Re: Nacra 5.5 rudders [Re: bullswan] #82533
08/20/06 04:26 PM
08/20/06 04:26 PM
Kennethsf Offline
Kennethsf  Offline
Bullswan
Greg
no problem <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> for the others: I fill try to find the pictures and repost them
Re: Nacra 5.5 rudders [Re: Kennethsf] #82534
08/20/06 08:46 PM
08/20/06 08:46 PM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
Here is one of the pictures.... I saved it.
Re: Nacra 5.5 rudders [Re: bullswan] #82535
08/21/06 05:17 PM
08/21/06 05:17 PM
White Bear Lake, MN
h17racer Offline OP
h17racer  Offline OP
White Bear Lake, MN
Woaaa, now that is industrial strength! Thanks for the pic post bullswan.
Sail fast, Tom G
Re: Nacra 5.5 rudders [Re: h17racer] #82536
08/22/06 07:40 AM
08/22/06 07:40 AM
Kennethsf Offline
Kennethsf  Offline
found the other pictures
Re: Nacra 5.5 rudders [Re: Kennethsf] #82537
08/22/06 07:41 AM
08/22/06 07:41 AM
Kennethsf Offline
Kennethsf  Offline
another
Re: Nacra 5.5 rudders [Re: Kennethsf] #82538
08/22/06 07:42 AM
08/22/06 07:42 AM
Kennethsf Offline
Kennethsf  Offline
last one
Re: Nacra 5.5 rudders [Re: Kennethsf] #82539
08/22/06 08:56 AM
08/22/06 08:56 AM
I remember that now...I really like that flip lever you came up with...now if you can just figure out how to make it work the opposite direction and be able to adjust the height of the line as it turns toward the pivot arm so you can infinitely adjust the amount of pressure required for release...!
Re: Nacra 5.5 rudders [Re: Jake] #82540
08/22/06 09:07 AM
08/22/06 09:07 AM
Here's a thought...use a couple of those harken micro-through hull sheaves running part of the line internal to the rudder arm...The black standoff on top of the arm could be adjustable to control the angle of the line leading to the flip lever allowing you to really dial in the amount of pressure required to automatically release the rudder from a ground impact (or fish).
Re: Nacra 5.5 rudders [Re: Jake] #82541
08/22/06 01:57 PM
08/22/06 01:57 PM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
Here is my version.
Re: Nacra 5.5 rudders [Re: bullswan] #82542
08/22/06 01:58 PM
08/22/06 01:58 PM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
Number 2 picture...
Re: Nacra 5.5 rudders [Re: bullswan] #82543
08/22/06 02:08 PM
08/22/06 02:08 PM
catman Offline
catman  Offline
Number 2 picture...
Greg, your tiller arm looks like it's pointed in the wrong direction. Looks like you might of swapped the castings.
0 registered members (), 655 guests, and 139 spiders.
Posts267,056
