Blade Dagger Board #83362
08/23/06 08:47 AM
08/23/06 08:47 AM
Stephen Offline OP
Stephen  Offline OP
Has anyone drilled out the obvious hole location for a retrieval line in the Blade Dagger boards?
I think this is what was originally used by the Taipan to raise the boards.
Stephen
Stephen
Phoenix Az
Re: Blade Dagger Board [Re: Stephen] #83363
08/23/06 02:30 PM
08/23/06 02:30 PM
Netherlands
geert Offline
geert  Offline
Netherlands
I do have drilled the hole locations on my Blade, no problem. What you probably also need is this eyelet:
Otherwise you risk the retrieval line getting jammed between the daggerboard and the hull.
Geert
Re: Blade Dagger Board [Re: geert] #83364
08/26/06 08:37 PM
08/26/06 08:37 PM
Orange County, CA, USA
JJD Offline
JJD  Offline
Geert:
Do yo have a photo of the board inserted with the retrieval line attached?
Thanks
John, Blade 720
Re: Blade Dagger Board [Re: JJD] #83365
08/26/06 10:16 PM
08/26/06 10:16 PM
Tornado_ALIVE Offline
On some of my old single handers, I had a second eyelet along side to pull the board dwon too.
Re: Blade Dagger Board [Re: JJD] #83366
08/29/06 04:58 PM
08/29/06 04:58 PM
Netherlands
geert Offline
geert  Offline
Netherlands
JJD,
Sorry, no pictures. It was the regular Taipan 4.9 setup; a retrieval line attached to the hole in the daggerboard, then through the eyelet and then somewhere to the other hull (or knot both retrieval lines together)so you can retrieve it without going to the lee-side.
Geert
Re: Blade Dagger Board [Re: JJD] #83367
08/30/06 04:06 AM
08/30/06 04:06 AM
Re: Blade Dagger Board [Re: Wouter] #83368
12/04/06 06:24 AM
12/04/06 06:24 AM
M
Mirjam Offline
Mirjam  Offline
M
Here is a picture of a Blade build by Dynautic with its daggerboard lifting system.
Re: Blade Dagger Board [Re: Mirjam] #83369
12/04/06 02:11 PM
12/04/06 02:11 PM
Israel
Erez Offline
Erez  Offline
Israel
Hi Mirjam,
Can you post more detailed pictures of your(Dynautic)Blade?
Thanks,
Erez Ben Shoham http://www.cat-sail.co.il
Re: Blade Dagger Board [Re: Mirjam] #83370
12/04/06 04:28 PM
12/04/06 04:28 PM
waynemarlow Offline
waynemarlow  Offline
I know carbon is all the rage but isn't the piccie of the Dynautic boat with its dagger board set in a nice carbon case just begging for long term problems. Yah see carbon is very very soft and very prone to abrasion unlike Kevlar or even good old E glass, now one has to raise that board pretty often together with all its little bits of attached sand etc acting as sandpaper, mmmmm I think I'll want to review that design in a couple of years time.
0 registered members (), 196 guests, and 51 spiders.
