Blade yard cover #83605
08/28/06 10:44 AM
08/28/06 10:44 AM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
Attached pic of Blade yard cover...needs some tweaking to the pattern, but pretty close for building the cover without a boat to fit it.
I do not think it was meant to go over the boom, hence the sides are a little short. Needs reinforcement where the cover sits on the beams.
Re: Blade yard cover [Re: tshan] #83606
08/28/06 10:47 AM
08/28/06 10:47 AM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
Another
Re: Blade yard cover [Re: tshan] #83607
08/28/06 11:24 AM
08/28/06 11:24 AM
You have a sweet boat cover
A sweeter trailer
And even a sweeter MAST UP storage location!
I envy you!
Also, you blade can do levitation!!!! WAY COOL!!! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Blade yard cover [Re: Robi] #83608
08/28/06 11:58 AM
08/28/06 11:58 AM
Is that your road cover also, or is it just for storage?
You guys must have some serious UV levels!
Robi, mast-up storage is very common in Europe. I am continously amazed by how many boats are living on their trailers elsewhere. I dont think I would be sailing as much as I do if I had to rig the boat every time.
Re: Blade yard cover [Re: Rolf_Nilsen] #83609
08/28/06 12:07 PM
08/28/06 12:07 PM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
Only for storage in the boat yard, not for trailering on the roadways. UV is a problem, as is the sap/debris from the surrounding trees. More pics on the F16 website.
I just had the supports for the trailer made last week. It does look like the boat levitates. I haven't gotten everything sorted out yet, but working on it.
Front beam supports pictured, notice the two part fore mast stand. So I could keep the spi pole intact.
Re: Blade yard cover [Re: tshan] #83610
08/28/06 12:22 PM
08/28/06 12:22 PM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
rear beam trailer supports
Re: Blade yard cover [Re: tshan] #83611
08/28/06 12:52 PM
08/28/06 12:52 PM
That is a no joke trailer. All it needs a nice sail box and you are set.
Re: Blade yard cover [Re: tshan] #83612
08/28/06 01:32 PM
08/28/06 01:32 PM
Arkansas, USA
C
CaptainKirt Offline
CaptainKirt  Offline
C
Arkansas, USA
Tom-
It looks like it is not meant to go over the boom, my Taipan cover IS meant to go over the boom and it has triangular "flaps" extending down from front portion of the tramp cover part that velcro together to enclose the front of the cover- Otherwise the sun/crud can still get to the tramp- Not good! I'm sure if you measure how high your boom attaches above the front beam Phil (I presume it's a Kinder cover- looks very familiar!) can insert a dart piece in the middle of the tramp portion and add the little front flaps like I have. I am out of town right now and don't have a photo of mine to attach on the web <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />- but if you remind me I can take one when I get home next weekend. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Regards!
Kirt
Kirt Simmons
Taipan, Flyer
Re: Blade yard cover [Re: CaptainKirt] #83613
08/28/06 01:54 PM
08/28/06 01:54 PM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
It is Kinder and a prototype. They want the feedback, so I'll give it all to them. My old N5.5 cover was as you described with the front flaps. Note how the bow covers do not slide over the front portion of the hulls, either - just top cover. Not sure I like that.
You can't really see it, but there are mesh squares over the rear part of the tramp cover that will allow for drainage - maybe that is why they did not plan for the "over the boom setup". It is great fabric - the Top Gun material.
Cover [Re: tshan] #83614
08/28/06 03:05 PM
08/28/06 03:05 PM
Arkansas, USA
C
CaptainKirt Offline
CaptainKirt  Offline
C
Arkansas, USA
Mine has the rear mesh as well- I was thinking it would be nice to have the mesh but have a "flap" of the solid material beneath (or even a "tube" running to the edge of the cover so the dirt, that gets through the mesh, doesn't end up pooled under the mesh?). They hold up well too- mine is ~6 years old and holding up well-
Kirt
Kirt Simmons
Taipan, Flyer
Re: Cover [Re: CaptainKirt] #83615
08/28/06 03:34 PM
08/28/06 03:34 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
I have my missus working on a cover right now. Got a good deal on Sunbrella Marine on EBAY. I was hoping she will be able to figure out how to cover the spin bag too. Mine is a black material. With a cover over the mouth to keep the popcans out.
Re: Cover [Re: bobcat] #83616
08/29/06 12:39 PM
08/29/06 12:39 PM
G
gary145 Offline
gary145  Offline
G
heres a picture of my chute cover
its made with 2 chunky zips to go either side of the bridle bit
gary
Re: Cover [Re: gary145] #83617
08/29/06 01:03 PM
08/29/06 01:03 PM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
One piece chute cover with slit for compression strut attachment. You must remove tension before bagging.
Re: Cover [Re: tshan] #83618
08/29/06 01:10 PM
08/29/06 01:10 PM
Tom your boat only has ONE set of trap wires?
I am now having boat cover envy! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Cover [Re: Robi] #83619
08/29/06 01:37 PM
08/29/06 01:37 PM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
Currently the boat is rigged for 1-up sailing, so I took the second set of trap wires off. I also added a forestay without the jib halyard block at the top.
Probably does not lessen the windage much, but it makes me feel better. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I assumed the Cover from Kinder would be blue, so I made the spi pole cover to match - WRONG.
Re: Cover [Re: Robi] #83620
08/29/06 02:30 PM
08/29/06 02:30 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Mine too...why have another pair dangling when you sail 1-up.
Tom, who's alum trailer box in the background? Can I buy it?
USA 777
Re: Cover [Re: tback] #83621
08/29/06 02:33 PM
08/29/06 02:33 PM
Me too! One butt, one bucket! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Cover [Re: fin.] #83622
08/29/06 05:09 PM
08/29/06 05:09 PM
Good idea guys. I usually sail Uni with both wires. BLEH!
Re: Cover [Re: Robi] #83623
08/29/06 05:51 PM
08/29/06 05:51 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Following on TikiPete's thread ... big butt--two wires <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
USA 777
Re: Cover [Re: tback] #83624
08/30/06 07:21 AM
08/30/06 07:21 AM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
You can have it. Come pick it up. It is a fiberglass box that would be fine cleaned up. It has a door that swings down on one end and a top lid that is unhinged (used to be hinged, now have to pick it up and slide it over).
A good time to come would be Oct. 28th and 29th for our annual Halloween Cat Caper. Open multihull regatta, 36th year for the event. it has been everything from NACRA MidWinters, to NAMSA, to Performance Districts, etc. Usually good wind with no (or very little) wave action.
We will even give your boat a salt water rinse before you leave!!!!
0 registered members (), 2,548 guests, and 457 spiders.
