| Re: 5.0 Roller Furling Jib
[Re: jbugbee126]
#83870 08/31/06 01:49 PM 08/31/06 01:49 PM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | Jeff- Do NOT buy a Hobie to get a roller furler jib- whoever responded to that obviously isn't very familiar with the comparable Hobie- the 16 (with fully battened jib!). I had a 5.0 (#1030) for 17 years- I rigged it with a roller furler for "cruising" only- I raced with the "stock" setup. My boat had the jib halyard that ran down the front of the mast so you could adjust jib tension on the water. I simply put the swivel at the top of the forestay, the roller drum at the bottom. You have to add a small cleat on the front beam for the furler line. Raise the jib "normally" but attach the jib tack to the furler. Make sure your jib sheets are long enough to reach when furled. Slack the halyard some (you have to experiment to get the best amount), release the sheets and furl. The top of the halyard will end up wrapping around the forestay but I never had a problem with it. The 5.0 sails pretty well on just the main so if you get overpowered you can furl and then furling when launching/landing is a nice ability too. If you really want to do it "right" then you have to use a forestay with a jib block incorporated (ala a Hobie 14/18 or a Prindle 16/18 etc. with halyard that runs inside the jib luff) which is more hassle/expense/weight/problems IMO. Enjoy the 5.0- tough boat that handles high wind well. If you have an '86 you hopefully have a lighter boat than mine which was the old solid fibreglass with stringer construction.
Kirt
Kirt Simmons Taipan, Flyer
[Re: CaptainKirt]
#83871 08/31/06 02:53 PM 08/31/06 02:53 PM |
Posts: 53 CT Shoreline | Kirt,
I'm not that familiar with either the H16 or the 5.0 but... I was just ribbing my neighbor Jeff (hence the J/K) as I just bought a H16 that came with a roller jib. LOL. He knows far more about both boats than I do!
<img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
[Re: Wet1]
#83872 08/31/06 03:24 PM 08/31/06 03:24 PM |
Posts: 12,310 South Carolina | I thought those were my initials or something....
Jake Kohl | | | Re: 5.0 Roller Furling Jib
[Re: self_inflicted]
#83875 09/02/06 06:17 PM 09/02/06 06:17 PM | Anonymous
| Anonymous
Unregistered | Guys:
I have a small block with a becket on mine on a piece of line long enough to go from a cleat on the front crossbar to the furler. I run the line from the furler through the block and tie to the bridle by the furler. This gives me a 1 to 2 purchase . For every foot I pull it furls 2. Works great for sitting between races.
Doug and Ashleigh Snell Hobie 17 "Stress Free" #007
264
guests, and 46
