Page 2 of 3 1 2 3
Re: Hull Colors [Re: warbird] #83946
09/04/06 08:23 PM
09/04/06 08:23 PM
Sounds like paint is in your future! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Hull Colors [Re: Jake] #83947
09/04/06 09:19 PM
09/04/06 09:19 PM
Locals just won't spray gel coat.
Simple.
Find new locals.
Re: Hull Colors [Re: Jake] #83948
09/05/06 01:15 PM
09/05/06 01:15 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Jake
I thought that spraying of gelcoat was outlawed in the USA because of all that nasty styrene.
Paul GBR7
Re: Hull Colors [Re: Jake] #83949
09/05/06 01:19 PM
09/05/06 01:19 PM
Israel
Erez Offline
Erez  Offline
Israel
I thin the gelcoat anywhere from 40 to 60% with styrene
I think it is too much, it will damage the jell coat quality, I thin 10% and use a gun with 2.5mm nozzle.
I've listened to plenty of advice - some yelled loudly to use the wax additive for the air dry but I've had miserable results with it and I've done a lot of sampling and paid a hefty fine for an incomplete cure.
I use 2% Paraffin wax and mix it thoroughly, it works fine for me, how ever if the wax is not mixed properly, then you will have an incomplete cure in some areas.
one more thing, once you put tape in order to set the boundaries of of your working area and clean the area with acetone some of the glue from the tape end can smeared and cause the Jell coat not to qure.
in addition I spread styrene on the old layer of Jell coat before i begin spraying, this will cause a cimical reaction to the old layer and the 2 (old & new)layers will merge rather then stick.
<img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />sorry my English is not perfect and its taking me for ever to write
Erez Ben Shoham http://www.cat-sail.co.il
Re: Hull Colors [Re: Erez] #83950
09/05/06 02:29 PM
09/05/06 02:29 PM
waterbug_wpb Offline OP
Interesting discussion. I have broadened my focus to just about any color. Hot Purple? Silver (talk about glare!)
No one has mentioned the "Mother of Pearl" finish you can find on some cars (color changes hue as you look from different angles). Is this possible with gelcoat? Perhaps a base color coat with a modified clearcoat?
I do like the International Orange for the daggarboards/rudders. Is this legal?
Re: Hull Colors [Re: waterbug_wpb] #83951
09/05/06 02:37 PM
09/05/06 02:37 PM
uhh, what rule would prevent a commonly used SAR color?
The reason that I recommended orange foils is because a silver boat would be very hard to spot from the air.
Do a dark, gunmetal silver with the orange boards and I'd want to make love to your boat.
Re: Hull Colors [Re: MauganN20] #83952
09/05/06 02:43 PM
09/05/06 02:43 PM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
Hey Maugan,
I share your taste in color. Just had my new (to me) boat painted a light grey. looking for orange to do the blades but can't find anyone that makes a two or even a 1 part poly in Orange. seems it's popular as anti-foul for offshore stuff, but not something awlgrip makes or even interlux... I'll send you a pic when all is said and done (may be awhile).
Todd Nacra 20 www.wrcra.org
Re: Hull Colors [Re: Todd Berget] #83953
09/05/06 03:02 PM
09/05/06 03:02 PM
worse comes to worst, home depot spray can marking paint + clear coat and polish.
<img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Hull Colors [Re: Todd Berget] #83954
09/05/06 03:13 PM
09/05/06 03:13 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Hi Todd
I don't know who told you that you can't get Awlgrip in Orange...see for yourself at http://www.boatpaint.co.uk/awlgrip_colours_chart.htm
Bob
Re: Hull Colors [Re: waterbug_wpb] #83955
09/05/06 03:19 PM
09/05/06 03:19 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Listening to the guys who dare "to go there' I cannot even think I need that sort of hassle. I know I will have work to do down the line but I figure if I have a thick coat I can cut in repairs with the two coat 1200 wet and dry.
Re: Hull Colors [Re: MauganN20] #83956
09/05/06 03:44 PM
09/05/06 03:44 PM
That's not the visual I needed <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
But if I were sponsored by H&K or something, that'd be my colorscheme...
Re: Hull Colors [Re: waterbug_wpb] #83957
09/05/06 04:02 PM
09/05/06 04:02 PM
beaudebo Offline
beaudebo  Offline
i wish i had kept the link that that shows a french guy preparing his catamaran in french polinesia for a few months of chartering , the piture shows him up to his waist in the water roller in one hand and tray in the other happily applying his second coat, he said the previous application had lasted more thn two years! get real guys its only a covering! the real action starts when you hoist the main!!
Re: Hull Colors [Re: beaudebo] #83958
09/05/06 04:51 PM
09/05/06 04:51 PM
Say hello to Agent Orange
Re: Hull Colors [Re: Jake] #83959
09/05/06 05:27 PM
09/05/06 05:27 PM
catman Offline
catman  Offline
I recommend, instead, to spray a layer of PVA over the uncured and freshly sprayed gelcoat to cure it (using air-inhibited gelcoat of course adn allowing enough time for the styrene thinner to flash off - usually about 10 to 20 minutes). It's very dependable doing it this way.
You of course mean after the final coat of Gel, spray the pva.
I re-gelcoated my hulls this spring using just the wax mixed in the last coat and had no problems with curing.
Over thinning and not using the right amount of MEK can lead to problems.
The Styrene I used recommended no more than 25% by weight not volume to thin.
Re: Hull Colors [Re: catman] #83960
09/05/06 05:34 PM
09/05/06 05:34 PM
Perhaps that was part of my problem, but I have since done tests with various amount of thinning and various amounts of wax additives (all in the same day with relatively similar ambient conditions). I got crazy results. I just don't see any reason to not use the PVA when it's so goof proof. I got some great results while thinning at 40% and it seems to be doing just fine - but I guess I would probably recommend less thinning and a thicker nozzle (and more sanding of orange peel).
Re: Hull Colors [Re: warbird] #83961
09/05/06 05:37 PM
09/05/06 05:37 PM
catman Offline
catman  Offline
Thanks for that. Sadly I have used epoxy to fare the boat and I don't have enough skill with a spray unit to DIY. Locals just won't spray gel coat. I will be more careful next time as I feel like a Luddite painting it.
Nothing wrong with painting. Tornados are painted. The only thing I would do if I were you is try to keep about a 4-inch strip of the bottom gelcoat. It's a better surface for dealing with the beach, beach wheels, etc. and it's easy to touch-up.
Re: Hull Colors [Re: Jake] #83962
09/05/06 06:29 PM
09/05/06 06:29 PM
catman Offline
catman  Offline
I use the PVA on small repairs and it works fine.
I used to do the mad scientist routine and I had problems. Now I follow directions, measure carefully. That way if I have a problem I can go back to the place I get my stuff from and get answers.
...and I know what your talking about when the stuff doesn't work <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
...and with painting you do most of your sanding up front and with Gel you do most of it after. There's no getting around it. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Re: Hull Colors [Re: catman] #83963
09/05/06 07:35 PM
09/05/06 07:35 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Sanding by hand with a block or with a machine sander?
USA 777
Re: Hull Colors [Re: tback] #83964
09/05/06 08:14 PM
09/05/06 08:14 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Block, wet and dry, for/aft, high/low and the cross angles to creat a true and flat shape.
Re: Hull Colors [Re: tback] #83965
09/05/06 08:53 PM
09/05/06 08:53 PM
catman Offline
catman  Offline
I don't normally use power tools when sanding. Depending on what I'm doing I'll use fart rock or a board file. Blocks are too small and can create the problems power sanders do.
That is low spots. However blocks are fine for small areas as long as your careful. I thought about using a air file ( air operated board file) but I'm just not a fan of the vibration or pounding the power tools create on a foam or any cored hull.
In case you don't know a file is about 16 inches long and 2.5 wide.
Page 2 of 3 1 2 3
0 registered members (), 3,045 guests, and 284 spiders.
