| Re: Do Daggerboards Really Help Point Higher?
[Re: nhsailor]
#83994 09/01/06 05:02 PM 09/01/06 05:02 PM |
Posts: 164 | | | | Re: Do Daggerboards Really Help Point Higher?
[Re: I20RI]
#83995 09/01/06 05:16 PM 09/01/06 05:16 PM |
Posts: 5,582 “an island in the Pacifi... | Very much so. The 16's asymetrical hulls fight each other; one wants to go right, the other left. That alone will reduce pointing ability. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Do Daggerboards Really Help Point Higher?
[Re: nhsailor]
#83998 09/01/06 07:31 PM 09/01/06 07:31 PM |
Posts: 5,582 “an island in the Pacifi... | Every type of boat is different but most leaners will out point most cats. So the real question might be, do ya wanna point higher or do ya wanna haul butt?
As far as recommendations, you can't get a boat that's any simpler to sail than a H16. If you want boards take a look at the H17 and TheMightyHobie18. The H20 has a bunch of stuff to do for set up but it screams once it's on the water. I'm sure others will chime in with their recommendations. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Do Daggerboards Really Help Point Higher?
[Re: hobie1616]
#84000 09/01/06 08:44 PM 09/01/06 08:44 PM |
Posts: 12,310 South Carolina | Every type of boat is different but most leaners will out point most cats. So the real question might be, do ya wanna point higher or do ya wanna haul butt?
As far as recommendations, you can't get a boat that's any simpler to sail than a H16. If you want boards take a look at the H17 and TheMightyHobie18. The H20 has a bunch of stuff to do for set up but it screams once it's on the water. I'm sure others will chime in with their recommendations. Actually monohulls don't point higher into the breeze - they typically sail with a very similar apparent wind (actually a little less on the nose). The difference is that they go slower hence their apparent wind doesn't point back so far. We actually sail at very high angles of attack when it comes to apparent wind, but we move so much faster, that the wind we generate from speed changes the angle of the wind we have to trim to. The faster you go, the lower you have to sail to keep some sort of angle on the wind across the sails. Next time you're out - try pointing with a monohull...you can do it easily but it's just not the fastest way to sail the cat.
Jake Kohl | | | Re: Do Daggerboards Really Help Point Higher?
[Re: Darryl_Barrett]
#84004 09/01/06 10:27 PM 09/01/06 10:27 PM |
Posts: 12,310 South Carolina | If that wasn't a loaded question coming from an ARC21 owner! (boards are in front of the main beam - "shared lift" with the rudders is the interesting idea proposed by Mr. Bill Roberts). I can't imagine that forward mounted daggerboards help the boat tack quickly but the idea of the board and the rudder sharing the lift of the sails is an "out of the box" idea...Looking at the latest trends in F18, the boards keep getting further and further back. ![[Linked Image]](http://static.flickr.com/88/231512891_d2436af59d.jpg)
[Re: hobie1616]
#84007 09/02/06 03:23 AM 09/02/06 03:23 AM |
Posts: 9,582 North-West Europe | As far as recommendations, you can't get a boat that's any simpler to sail than a H16.
...ehhh, Hobie Wave ? Also if you want boards then forget about the H17 and TheMightyHobie18. Those of the TheMightyHobie18 are huge. They have all the issues that modern boards have and then some more because they are really big and they point slightly lower as well. The H17 for that matter does't have boards but more like windsurfer skegs. These boards are absolutely tiny. They help balance the boats in steerage but are far too small to help upwind performance. It is actually very comparable to a skeg boat in performance. So if you want a boarded cat then go for one of the more modern kind. These can now be had for relatively small investments. Wouter
[Re: nhsailor]
#84008 09/02/06 03:28 AM 09/02/06 03:28 AM |
In your case NHsailor I would look at modern skeg boats, like the nacra 5.0 or nacra 500. It will suit all your wishes the best and have slighlty better upwind performance then asymmerical boat like the H16. It is also less weight sensitive.
Boarded cats are great but I don't think you really want to go that way. Often these boats are more race oriented and therefor are fitted with more and more complex systems.
[Re: nhsailor]
#84009 09/02/06 03:30 AM 09/02/06 03:30 AM |
Posts: 130 CA | Long daggerboards are more efficient by having a higher aspect ratio, which reduces tip losses. According to Frank Bethwaite, pointing ability is a function of efficiency (lift to drag ratio).
Similarly, unirigs can point higher because of their higher aspect ratio mains. (A jib makes the sail plan wider, but no taller, reducing aspect ratio.)
Boardless boats, such as the Hobie 16 are the ultimate in low aspect ratio centerboards, using the hulls as boards. On these boats, the mast is typically raked to load up the rudders because the rudders are much higher aspect ratio than the lifting hulls, and therefore much more efficient lifting devices. To transfer as much load as possible to the more efficient rudders, you must rake the rig as much as possible. | | | Re: Do Daggerboards Really Help Point Higher?
[Re: warbird]
#84010 09/02/06 04:17 AM 09/02/06 04:17 AM |
Posts: 915 Dublin, Ireland | A good comprimise is the Spitfire which has "keels" and goes great. If you were thinking of a Getaway.. the Spitfire has all of its advantages like roller furling and no boom) but is a grownups boat.
I presume that you mean the Topcat Spitfire <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Dermot Catapult 265
[Re: Dermot]
#84011 09/02/06 04:59 AM 09/02/06 04:59 AM |
Posts: 1,382 Essex, UK | A good comprimise is the Spitfire which has "keels" and goes great. If you were thinking of a Getaway.. the Spitfire has all of its advantages like roller furling and no boom) but is a grownups boat.
I presume that you mean the Topcat Spitfire <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> 'thought I'd let you chime in on that one Dermot! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Do Daggerboards Really Help Point Higher?
#84012 09/02/06 06:45 AM 09/02/06 06:45 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | When moving the boards back, you also rake the mast aft to load up both boards and rudders to get that shared lift. One theory is to use the boards for lift and then the rudders just steer the boat.., this is the way things were for years. Then folks started raking masts aft, copying the Hobie 16, to put load on the rudders as well. At first it was not particularly effective.., probably because we were not using enough aft rake.
Wouter mentioned the Wave which sails very high to windward with only a skep. But, the mast is raked way aft to utilize the skeg and the rudders for underwater lift. Rick | | |
4,680
guests, and 1,088
