Page 2 of 4 1 2 3 4
Re: Mainsheet system: advantage [Re: Tornado] #84189
09/09/06 03:03 AM
09/09/06 03:03 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
I make 8:1 + 1:1 = 9:2 [Same as 8:1]
My money is still on 8:1
Re: Mainsheet system: advantage [Re: TEAMVMG] #84190
09/09/06 05:48 AM
09/09/06 05:48 AM
right result; wrong maths
it's is actually a 8:1, with a 1:1 on it, so
8:1:1 is a 8:1; 9:2 is 4.5:1
Re: Mainsheet system: advantage [Re: Tornado] #84191
09/09/06 10:12 AM
09/09/06 10:12 AM
CA
Glenn_Brown Offline
Glenn_Brown  Offline
CA
Yes, definitely 9:1.
For anyone who doubts: 1 lb of tension on the sheet (black line) leads to 2lbs of tension on the red lines, which is obviously 9lbs of tension between the boom and main traveller, or 9:1.
Re: Mainsheet system: advantage [Re: Glenn_Brown] #84192
09/09/06 03:02 PM
09/09/06 03:02 PM
Yes, and there are 4 red lines in the moving part of the system. (up and down from the boom to the back beam (well the wire to the back beam)
8:1
You have a 2:1 on the Black line system, the black line system is then pulling on a 4:1; 2:1:4:1 = 8:1
Re: Mainsheet system: advantage [Re: scooby_simon] #84193
09/09/06 03:53 PM
09/09/06 03:53 PM
It is a 9:1 system guys.
No doubt about it.
Re: Mainsheet system: advantage [Re: Wouter] #84194
09/09/06 05:48 PM
09/09/06 05:48 PM
Agreed and I stand corrected - that is 9:1
Re: Mainsheet system: advantage [Re: Wouter] #84195
09/09/06 05:56 PM
09/09/06 05:56 PM
I've had another look at this and think thus
Red system is a 4:1.
The black system is a 3:1 as the both blocks (2 and 3) on the boom are (in effect) moving in relation to the back beam.
As you pull the mainsheet in, the first block on the boom(2) is also moving down, as is the big block inside the boom(3), so the black system is a 3:1, making the total system a 12:1.
I cannot see how it can be a 9:1 as the internal cascade is 4:1 and so any multiplier must result in an even number unless there is just a "routing" block, which there are none as all the "big/black" blocks are moving except the back beam block.
Re: Mainsheet system: advantage [Re: scooby_simon] #84196
09/09/06 08:48 PM
09/09/06 08:48 PM
Try this
Re: Mainsheet system: advantage [Re: scooby_simon] #84197
09/10/06 02:37 AM
09/10/06 02:37 AM
Okay, let me explain how it works.
But first lets derive the tension in each line because we'll need that later.
Black line is held in hand and so all the black lines are under 1 unit tension; the pull of the skipper.
The red line is attached to the black line by an 1:2 purchase system so the tension in the red line is 2 units.
It is impossible for any line to have different tensions at different points. Think about this.
When a line makes a full 180 wrap around a block then it pulls 2 times the line tension downward, that is obvious. If a line makes a 90 wrap then the block is pulled down by 1 times the line tension. A termination point equal 1 times the line tension downward. All still pretty straight forward.
Now lets count the loads when looking only at the boom blocks, the others are unimportant.
Black line : about 1 partial wrap so roughly 1 unit down pull and nothing else
red line : 1 full wrap, 1 partial wrap and a termination point ; total = 4 times the line tension of 2 units = 8 units of downward pull
Add them all up and you get (by approximation) 9 units of downward pull for each single unit of pull by the skipper, ergo it is a 1:9 system.
And this is one of the few ways to do it right.
Re: Mainsheet system: advantage [Re: Wouter] #84198
09/10/06 05:21 AM
09/10/06 05:21 AM
You can't keep writing purchases a 1:x unless you are talking about an inverse purchase system. The standard nomenclature has the advantage shown FIRST.
8:1, 4:1, 6:1, 12:1 etc.
by writing 1:9 you are in effect saying that for every 1lb of effort applied at the load you need to apply 9lbs - usually bloody hard work!!!
Re: Mainsheet system: advantage [Re: Jalani] #84199
09/10/06 05:41 AM
09/10/06 05:41 AM
Australia
macca Offline
macca  Offline
Australia
Look, whatever the purchase is, its not enough for the new carbon mast on the T, so we have now a system with more purchase, by making the floating block inside the boom a 3:1 system.
We then run either 4:1 or 3:1 on the small blocks at the back, the change is achieved by dropping the last block in or out of the system depending on what you want at the time.
________________________
http://aus300.blogspot.com
Re: Mainsheet system: advantage [Re: macca] #84200
09/10/06 07:37 AM
09/10/06 07:37 AM
Tornado_ALIVE Offline
some pics, someone can link them so they appear in the posts but i have never worked that part out <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
This pic is the turning block at the front of the boom, the thin rope turns around this block and attaches to the floating block in the next pic.
Here you go mate...... I must spend too much time doing this $hit <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: Mainsheet system: advantage [Re: macca] #84201
09/10/06 07:38 AM
09/10/06 07:38 AM
this is the floating block, we have a new systems that allows us to change from 9:1 to 12:1 in seconds, but more on that when i put the boat back together and take pics. way to complex to explain here <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Mainsheet system: advantage [Re: Jalani] #84202
09/10/06 02:40 PM
09/10/06 02:40 PM
Dependents on which view point you have.
You can view it from a force points of view or from travelled distance point of view.
Force : 1 lbs effort => 9 lbs end result
distance : 9 units distances pulled => 1 unit distance travelled by boom
And there are many more, and several have to be called 9:1 and others 1:9
So I just the beach talk version that is fashion of here and that puts the 1 in front mostly because in Dutch it just flows betters. I think it does so too in English.
Re: Mainsheet system: advantage [Re: Wouter] #84203
09/10/06 03:56 PM
09/10/06 03:56 PM
Sorry Wouter gotta disagree here. In the UK, (IMO) people will always use the multiplier first.
Back to this multi purchase...
in the picture I agree that up to the last block on the boom, there is a an 8:1 system.
But I do not understand where "only" an extra 1 comes from.
The block is moving down, and there is a (at least a 8:1) moving over this block, BUT as this block is moving itself there MUST (I think) be some multiplyer on the rest of the system. I agree it cannot be 2 as there is not a 180 degree turn, but I cannot see how it can be 1 as the block on the boom is moving.
Re: Mainsheet system: advantage [Re: scooby_simon] #84204
09/10/06 04:49 PM
09/10/06 04:49 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
The "count the moving blocks" thing will only work on a standard system of blocks. The key issue here is that the black rope does not come back down to the beam. Instead, it feeds into a second system. If you removed that system and simply anchored it in the boom you'd have a 1:1 system.
I find these things easier to look at in terms of rope moved. What does it take to move the boom 1 unit down? Well, if you remove the final block and imagine yourself sitting on the boom, it's pretty obviously 8 units. Now sit back on the boat and use that final block. How much more rope do you have to pull to shift the boom that 1 unit? 1 unit, so you've pulled 9 units, so it's 9:1.
It's not going to be a multiplier because it's not a cascade. There's only one floating block in the system and that's the one that gives you the 2 x 4 = 8 : 1.
Re: Mainsheet system: advantage [Re: scooby_simon] #84205
09/10/06 05:07 PM
09/10/06 05:07 PM
Norway
Stein Offline OP
Stein  Offline OP
Norway
Although my first proposal on 3:1 and 5:1 was found incorrect, I cannot resist commenting on the "Macca-system".
The confusing point here is the 90 degree turn to put blocks inside the boom. If you straighten out the system, you find a 4:1 compund system and a 2:1 cascade. Total = 8:1 (Or 1:8 if you are the boom).
For cascades, you cannot simply count number of line segments.
Seriously:
May I propose that you publish mainsheet setups that you really like here. This would be most useful to all of us.
Macca has provided an exellent example.
Stein
Re: Mainsheet system: advantage [Re: Stein] #84206
09/10/06 05:35 PM
09/10/06 05:35 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Nope. If you straighten it out and anchor the "static" turning block (the one originally at the far right) to the boat not the boom (e.g. tie it to a cable from the top of the mast) then you'd be nearly right. In fact, you'd only get 7:1 because the black rope is tied off to the boom not the deck. Fix that and you do finally get to a standard 2 x 4 cascade.
Straightening out the system doesn't change it, and either way you can't get away from the fact that the cascade is anchored in the moving boom, which means you have to move an extra unit of rope.
Re: Mainsheet system: advantage [Re: Stein] #84207
09/10/06 06:14 PM
09/10/06 06:14 PM
Australia
macca Offline
macca  Offline
Australia
Ok, here is the new system, you can change the purchase really easily by moving the red line from terminating on the boom to terminating at the bottom block on the bottom of the system. we call the min purchase 9:1 anf the max purchase 12:1 but I am sure you all will find 500 other ways to calc it out <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Mainsheet system: advantage [Re: scooby_simon] #84208
09/10/06 10:54 PM
09/10/06 10:54 PM
CA
Glenn_Brown Offline
Glenn_Brown  Offline
CA
Here is a simple geometric explanation:
With the sheet taught, lift the boom, pulling the 4:1 blocks 1" further apart. This pulls 4" of the red line into the 4:1 system, moving the floating block 4", and pulling 8" of the black line into the end of the boom. However, since the end of the boom moved 1" away, this pulls 9" of line through the main sheet cleat.
So, it's 9:1, with the "extra 1" coming from the boom movement as you sheet.
Here's another simple geometric explanation:
Imagine you had a conventional 8:1 rigged upside down like this:
BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB Boom
/O
/4 4
/ 4 4
4 4
O
and then you take the line at the end and run it through the bottom set of blocks like this:
O
5 4
5 4
O______
Suddenly, it is 9:1. It's no different for the cascaded system. That's where the "extra 1" comes from.
Page 2 of 4 1 2 3 4
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
