| Re: Rudder locking system
[Re: laiuppa]
#8461 07/03/02 02:51 PM 07/03/02 02:51 PM | Anonymous
| Anonymous
Unregistered | I had this problem with mine when I first got it. The most effective fix is to completely replace the Rudder cams by drilling out the rivets holding them, pulling the ball and spring out and cleaning them thoroughly and then replacing everything. if the cams are in good shape then you can keep them but if they are cracked at all or severely worn then I recommend getting some new ones. ... However if you don't want to go to all this trouble the quick fix is a simple flat head screw driver. Insert it between the ball and the cam and press the ball down so you can rotate the cam into the Rudders down position. this has always worked for me when my cams over rotated or were just plain stuck. but usually if it happens once it will happen again so it is best to do some preventive maintenance and just bite the bullet and do it.. if you have the right tools then taking apart both cam systems and cleaning them should only take about an hour. | | | Re: Rudder locking system
[Re: laiuppa]
#8464 07/05/02 04:35 PM 07/05/02 04:35 PM | Anonymous
| Anonymous
Unregistered | you really don't need a diagram for fixing those things once you take it apart it is pretty clear how it all fits together.. it literally consists of 3 parts ... the cam... the tension ball and the tension spring. spring and ball go in the hole... cam goes on top you will see when it is cleaned, and trust me it will pop back when your rudders hit the beach, it may even pop back when you hit some seaweed or floating debris.. the cat key is a handy tool if you can get your hands on one but once I got mine all cleaned they worked without any problem. ... the little plastic screw underneath the tension spring is to adjust that tension but I have never had to use it the amount it is able to move is so minimal that it never did any good. anyway... good luck. | | |
263
guests, and 40
