On its side #84609
09/13/06 08:32 AM
09/13/06 08:32 AM
St. Louis, MO
nova Offline OP
nova  Offline OP
St. Louis, MO
I need to put my boat on its side. Is the forestay enough to keep the mast in its base or do I need to put the jib on and tighten it up.
Re: On its side [Re: nova] #84610
09/13/06 08:37 AM
09/13/06 08:37 AM
NC
drbinkle Offline
drbinkle  Offline
NC
If your shrouds are tight it should keep enough pressure on the forestay that you won't need to raise your jib.
Re: On its side [Re: nova] #84611
09/13/06 12:01 PM
09/13/06 12:01 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
IF you are worried about it, you can always used the jib haryard to tighten the forestay with out having the jib attached.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: On its side [Re: nova] #84612
09/14/06 07:49 PM
09/14/06 07:49 PM
Bogie Offline
Bogie  Offline
If the forestay is pinned in the lowest hole in the shackle and the shrouds are also pinned reasonably low, then that should be plenty safe.
I've done it lot's of times.
Re: On its side [Re: Bogie] #84613
09/18/06 03:54 PM
09/18/06 03:54 PM
California
mmiller Offline
mmiller  Offline
California
Or... tie a line through the downhaul cleat, halyard and jib halyard cleats to the striker post. Tied tightly, that would hold the mast in the step cup even if the shrouds were loose.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 298 guests, and 46 spiders.
