On its side
On its side
#84609
09/13/06
08:32 AM
09/13/06
08:32 AM
May 2002
St. Louis, MO
nova
nova
May 2002
St. Louis, MO
I need to put my boat on its side. Is the forestay enough to keep the mast in its base or do I need to put the jib on and tighten it up.
Re: On its side
Re: nova
#84610
09/13/06
08:37 AM
09/13/06
08:37 AM
Mar 2005
NC
drbinkle
drbinkle
Mar 2005
NC
If your shrouds are tight it should keep enough pressure on the forestay that you won't need to raise your jib.
Re: On its side
Re: nova
#84611
09/13/06
12:01 PM
09/13/06
12:01 PM
Jul 2005
St. Louis, MO
hobienick
hobienick
Jul 2005
St. Louis, MO
IF you are worried about it, you can always used the jib haryard to tighten the forestay with out having the jib attached.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: On its side
Re: nova
#84612
09/14/06
07:49 PM
09/14/06
07:49 PM
Jun 2001
Bogie
Bogie
Jun 2001
If the forestay is pinned in the lowest hole in the shackle and the shrouds are also pinned reasonably low, then that should be plenty safe.
I've done it lot's of times.
Re: On its side
Re: Bogie
#84613
09/18/06
03:54 PM
09/18/06
03:54 PM
Jun 2001
California
mmiller
mmiller
Jun 2001
California
Or... tie a line through the downhaul cleat, halyard and jib halyard cleats to the striker post. Tied tightly, that would hold the mast in the step cup even if the shrouds were loose.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Switch to Threaded Mode
0 registered members (), 332 guests, and 46 spiders.
