| Info on Genakers/Hooters/Screachers #8497 07/04/02 07:27 PM 07/04/02 07:27 PM |
Joined: Jul 2002 Posts: 32 Victoria, Australia Inland_Sailor OP
Posts: 32 Victoria, Australia | Just like some info on Genakers/Hooters/Screachers.
At the moment I'm now a little unsure of which is the best way to pursue the spinaker setting / retrieval strategy for my 20' Trailable Cat.
I'm not sure of using a bowsprit mounted snuffer with my current 300sq ft asymmetrical or swaping over to a furling type of spinnaker.[Genaker/Hooter/Screacher]
I dont know much about either system really, but want something that is easy for my crew to use.
Does anybody out there have any definitive answers to what makes these sails different from an asymmetrical spinaker?
Why can they be furled and spinakers need to be dropped?
Does a formula exist in calculating the appropriate size hooter. Eg - 90% of spinnaker size etc.
What fabric is best?
What are the benifits/disadvantages of each type of sail.
Whilst I have a regular crew, this situation can change and part timers need all the help they can get.
My sailing is generally round the bouy racing, so if someone can recommend which type of sail is better for this application, rather than the others.
My Cat has a bowsprit that is 2.2m in length, and is movable in both horizontal and vertical planes. We hardly ever alter the height of the pole, but regularly adjust the pole across the boat according to the wind direction. It can be moved about 40 - 45 degrees from the centre.
I know this has probably been discussed before, but I'm new here and dont know where to look.
Just considering my options.
Inland Sailor
Magnum
| | | Here is info on Hooter
[Re: Inland_Sailor]
#8499 07/08/02 04:42 PM 07/08/02 04:42 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Here is some info on Hooters: http://www.catsailor.com/update_hooter.htmlSince the discovery of the Hooter, spinnakers have gotten smaller and flatter. Advantage of a Hooter is that it serves more points of sail and can actually sail upwind in light winds at angles the same as a jib, plus is honks off the wind -- just need to keep it more heated up than a spinnaker. Also, check out my video on Downwind Sailing in our Book Store http://www.catsailor.com/rampress/ram_press.htmlGood luck, Rick | | | Re: Info on Genakers/Hooters/Screachers
[Re: EasyReiter]
#8500 07/08/02 07:08 PM 07/08/02 07:08 PM |
Posts: 32 Victoria, Australia | marc
I'll try to answer your questions as best as I can.
The bowspritwhich is 2" [50mm] constuction grade aluminium with a 3/16th [4mm] wall. It has a spinnaker pole clip on the end and clips/attaches to the crossbeam via a stainless steel U bolt that goes through the beam, but a padeye would probably do the same thing.
This gives the pole tha ability to move through any plane as mentioned in my post. [similar to a normal spinaker pole attached to a mast].
To hold the pole down, a line is attached that runs from bow to bow. The line runs through a small block. on the bow sprit and is cleated down. Than a second continuous line runs to each bow and back along the hulls to cleats just near the jib blocks then returns via the other hull to the tip of the bowsprit. This line can be cleated down on either side of the boat.
To move the pole, all that is required is to unleat both cleats and pull the pole around to the desired position and then recleat.
Hope this helps
Any more questions, just ask
Magnum
[Re: Inland_Sailor]
#8501 07/08/02 10:01 PM 07/08/02 10:01 PM |
Posts: 12,310 South Carolina | What kind of 20' catamaran are we talking about?
Jake Kohl | | | Re: Info on Genakers/Hooters/Screachers
#8502 07/08/02 11:34 PM 07/08/02 11:34 PM |
Posts: 32 Victoria, Australia | An Aussie built Windrush 600 [20]' trailable. [They can still be built but the factory is now concentrating on the 700 model.See link. http://www.wevo.com/w700.htmWhen I get a picture of mine I'll put it on the forum so you can see the difference from its larger brother. I've attached a picture of W600 for you anyway.This doesn't show the bowsprit, but it is attached in a similar manner to that on the W700 http://www.traileryacht.com.au/windrush.htm
Magnum
[Re: EasyReiter]
#8504 07/13/02 06:29 PM 07/13/02 06:29 PM |
Posts: 32 Victoria, Australia | Sure the Windrush is heavier [and dryer] than a beach cat but sails and handles just like one. She weighs in at about 700lbs [or 350kg].
On the water she beats Hobie turbo's Nacras 4.5s regularly and even the odd Hobie 16. On light days She.s a dream and can even beat Tiapans on handicap. As well as all that she has pleanty of room for a cooler full of cold refreshments for skipper and crew.
Inland Sailor
Magnum
3,175
guests, and 228
