Re: Dismasting [Re: MauganN20] #85320
09/25/06 07:04 PM
09/25/06 07:04 PM
the hound plate itself wore out because of the friction of the shackle sliding back and forth.
We put plastic washers on the shackle "shaft" to keep the hound plate in the middle of the shaft and thus stop the chaffing.
Negative - that hound (Nacra / Inters) doesn't wear from friction. Even with spacers taking up all the slack, the hound opening will elongate just from the repeated cycle stress (waves, sheeting, etc). My F18 looks similar as well - neither are anywhere near failure but they are showing the same stress even with the spacers. The hound material is simply a little too thin to last a 'lifetime' and the hound will need to be replaced occasionally (at the first sign of cracking of the bottom weld).
I put the spacers in to A) keep the shackle from slipping over and pinching the spinnaker halyard leading to a jam or a chaffed spin halyard and B) eliminate a concern-provoking, "I'm 10 miles offshore and something sounds like it's going to break", POP/BANG as the shackle settles on every other jibe.
Re: Dismasting [Re: Frozen] #85321
09/25/06 09:46 PM
09/25/06 09:46 PM
Jimbo Offline
Jimbo  Offline
Re: Dismasting [Re: Frozen] #85322
09/25/06 10:40 PM
09/25/06 10:40 PM
Alright, why not just check the darn things prior to sailing each time? If you wrap them with tape then you hide the crap you are supposed to be checking. Just check each time, you use wire then you start cutting stuff (what is this about something used in the manufacturing process that inhibits coagulation? if so, figure out what it is and you could make millions in the pharmaceutical market). sorry, just check them like you check to make sure the plugs are in, etc.
all deployment and no sailing makes PTP pissed!
Re: Dismasting [Re: PTP] #85323
09/26/06 01:44 AM
09/26/06 01:44 AM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
forget that, I just checked all my cans of lockwire and have researched it some more, no warnings, a hangover from the old days, stab yourself with lockwire all you want, the blood will coagulate. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Dismasting [Re: Frozen] #85324
09/26/06 08:54 AM
09/26/06 08:54 AM
Frozen Offline OP
Frozen  Offline OP
I did some checking of my pins and shackles etc. and noticed that the shackles I had used for my port and stbd shrouds were too small. The remaining pin was a bit loose and was probably headed the same direction as the failed one. So I replaced with larger shackles.
Season is almost over so I will probably get the Wichard ones this winter. The few bucks is worth the peace of mind, especially in an area that ropes are around and potential for damage is higher. I was lucky that day. If the wind had been stronger, I would be facing the purchase of another boat as it would have been trashed on the rocks.
I checked out the mast while it was down and noticed that I had put some pins on the spreader upside down... They should be pointed (ring) down so if the ring came off it would remain in place. An aircraft mechanic friend of mine once told me that bolts or pins should be down, back or in.
On my H14 I use AN steel bolts with ESNs. There is some minor corrosion after 6 years, however I will replace with SS and ESNs. I also noted that the hound plate hole on my H14 is elongated so I will replace. Thanks jake.
Oh... and I also taped up all the rest of the rings and pins and put Locktite on the shackles.
0 registered members (), 626 guests, and 34 spiders.
