| Adjusting Trapeze harness #85335 09/24/06 10:32 PM 09/24/06 10:32 PM |
Joined: Sep 2003 Posts: 270 Nepean (Ottawa) Ontario Canada Frozen OP
Posts: 270 Nepean (Ottawa) Ontario Canada | I am new to trapezing. Any thoughts on adjusting the harness and line length? I singlehand a Tiger and a H14.
Right now I am adjusted so that when I come in, I am a bit above the deck. This makes it tricky to get off in a hurry, so I will adjust it down a bit. I would guess that I should be coming in right on the deck with a slight amount of tug from the trapeze wire.
I have a large "Magic Marine" harness with a hook and a wire gizmo (on the hook) that gets in the way. I am 5'11". (1.7944 meters) I have it adjusted as far up my body as I can safely adjust it (for back support) and about half way out on the straps.
One strap came undone one day so I will sew the straps so they can't undo... Water's too cold here for a surprise dip <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Also I am adding my old windsurfer foot straps. Any thoughts on location?
Cheers Alan F
Tiger
| | | Re: Adjusting Trapeze harness
[Re: warbird]
#85339 09/25/06 05:31 PM 09/25/06 05:31 PM | Anonymous
| Anonymous
Unregistered | Just use a traditional dog bone, that way you have two height options (one for each loop). | | | Re: Adjusting Trapeze harness
[Re: warbird]
#85341 09/25/06 07:23 PM 09/25/06 07:23 PM | Anonymous
| Anonymous
Unregistered | Warbird:
I have never used the adjustable but it looks like it would work real easy. The problem with have two is you might grab the wrong one and not know til you are out on the wire. I would try the adjustable one that doesn't require cutting shrouds, that way it it doesn't work, you can just go back to old system.
Doug Snell Hobie 17 "Stress Free" #007 Mystere 4.3 #149 Sunfish | | | Re: Adjusting Trapeze harness
[Re: warbird]
#85342 09/26/06 08:14 AM 09/26/06 08:14 AM |
Posts: 270 Nepean (Ottawa) Ontario Canada | Hate dog bones as my face and ear is always in their way. I have gone for a softer option. Softer option raises all kinds of possibilities in my mind.... <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> but what were you speaking of...
Cheers Alan F
Tiger
[Re: Frozen]
#85343 09/26/06 08:50 AM 09/26/06 08:50 AM |
Posts: 1,246 Orlando, FL | I noticed Robi had 6 mm line with a loop in the end for the "hook". The loop had rubber tubing covering the line ... I suppose for strength and to keep the line firmly in a loop shape.
Very *soft*.
Also has the benefit of not easily coming un-hooked if not under load. I occassionally have this problem with one of my harnesses when I wear a PFD. The PFD seems to want to make the trapeze handle disengage.
USA 777
[Re: Frozen]
#85344 09/26/06 09:06 AM 09/26/06 09:06 AM |
Posts: 465 Oxford, UK | I assume he's referring to these things: http://store.catsailor.com/tek9.asp?pg=products&specific=jmorenhnf0I much prefer these to dogbones. Easier to get on and off, and much less painful when they hit you in the face. I have adjusters on the rear trapezes of my boat. I find it really useful to be able to lengthen the trapeze when trapezing right at the back of the boat going downwind. Paul | | | Re: Adjusting Trapeze harness
[Re: pdwarren]
#85345 09/26/06 09:17 AM 09/26/06 09:17 AM |
Posts: 270 Nepean (Ottawa) Ontario Canada | I assume he's referring to these things: http://store.catsailor.com/tek9.asp?pg=products&specific=jmorenhnf0I much prefer these to dogbones. Easier to get on and off, and much less painful when they hit you in the face. I have adjusters on the rear trapezes of my boat. I find it really useful to be able to lengthen the trapeze when trapezing right at the back of the boat going downwind. Paul Are you referring to the rope loop on that page? HARKEN BLOCK ACCESSORIES: LOUP, 11MM DIAMETER BY 400MM(16") LENGTH HARKEN BLOCK ACCESSORIES: LOUPS, 11MM DIAMETER BY 400MM(16") LENGTH Developed by Harken by Aramid Rigging in.. Or the wire loop (as on my Tiger)? My Tiger shows the adjustable trap as the crew one so I'll try switching.
Cheers Alan F
Tiger
[Re: Frozen]
#85347 09/26/06 11:44 AM 09/26/06 11:44 AM |
Posts: 130 CA | My recommendation is to use dogbones. Adjust the forward dogbone to just touch the deck. Adjust the aft dogbone so the
[b]top[/b] ring just touches the deck.
The rationale is that no further adjustment is required on the water: [*]The crew[*]uses the forward bottom ring upwind, and [*]uses the aft bottom ring downwind (when the crew is well aft).[/LIST][*]The skipper[*]uses the aft top ring upwind, and [*]sits on the hull downwind.[/LIST][/LIST]
This way, the aft trap wire can be used by the skipper (upwind) and crew (well aft downwind) without adjustment. If it gets rough, the crew switches to the top rings, and the skipper (upwind) moves aft for more clearance (since he will want to move aft as the wind builds, anyway).
For a novice, these settings will seem 6" too low, but they are not, since you should not be on the wire if you're not flying a hull 6" above the water. ;-)
If you want soft dogbones, some have been known to make them from spectra line passed through nylon tubing (from your local hardware store). | | | Re: Adjusting Trapeze harness
[Re: Glenn_Brown]
#85348 09/26/06 12:21 PM 09/26/06 12:21 PM |
Posts: 606 League City, TX | If you want soft dogbones, some have been known to make them from spectra line passed through nylon tubing (from your local hardware store). I like dogbones but have avoided putting them on my boat because of the teeth chipping factor. The soft bone sounds like the perfect solution. Are both top and bottom rings and the connecting piece constructed of spectra in nylon tube? Chris. | | | Re: Adjusting Trapeze harness
[Re: Dan_Delave]
#85353 09/27/06 10:27 PM 09/27/06 10:27 PM | Anonymous
| Anonymous
Unregistered | Dan:
I agree J & H is the way to go. Never missed hooking up and they have never dropped me. Dogbones are DANGEROUS. Keep your teeth!!!
Doug | | |
1 registered members (FredL),
2,799
guests, and 283
