| Re: Help with rigging old Mosquito
[Re: joey]
#85366 09/25/06 04:57 AM 09/25/06 04:57 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum
Posts: 556 Somers, Westernport Bay, Victo... | Joey, Welcome to the Mosquito class. I hope you have many great adventures on your Mozzie. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> Ask away. That's exactly what this forum is for. Everyone who visits and contibutes on this forum are only too willing to provide assistance no matter how small the issue. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> The gooseneck rod does just slide onto the boom which should have an end fitting with a matching hole. If you have a boom vang then it will stay in position and won't come out. If you don't have any fittings on the boom then it's off to the chandler to get some new fittings. Check out the Ronstan catalogue on line to see what you need. http://www.ronstan.com/marine/range.asp?RnID=114Mast rotation will only be restricted by the diamond wires and everyone is always trying to get maximum free mast rotation. Yes there has to be some limitation of mast rotation otherwise the sail won't align with the back of the mast section and there may even be too much stress on the mast. The amount of mast rotation relative to the boom and sail is limited by the rotation bar located on the mast just below the boom. I think that's what you call the mast arm. A piece of 6 mm dia. rope is mounted on a saddle rivetted off the boom just rearward of and close to the end of the mast rotation bar. The rope is then passed through a small pulley on the rear end of the bar then back onto a cleat mounted on the boom. This will limit the mast rotation and provide some means for adjusting when sailing. If you need more pics just visit the Mozzie website. http://s51.photobucket.com/albums/f392/v...gAnch=imgAnch17Good luck with sorting out the setup and getting out on the water. Regards, Peter
Mosquito 1814 Macka Mozzie
[Re: joey]
#85367 09/25/06 05:06 AM 09/25/06 05:06 AM |
Posts: 461 Victoria, Oztralia | Hi Joey
I think were on the same page! But when the boom is fitted to the gooseneck, it should hold itself on when the mainsail is attached. There probably isn't anything else to lock the boom on.
The rotation arm is usually attached to the boom via a small sheet which is adjustable (with cleat) This way the mast will follow the boom as the main is released, or the rotator arm can be released or adjusted for different modes of sailing. So the mast is limited in rotation with this anyway.
The standing rigging should still allow the mast to be rotated, the normal hound fitting has the attach points on the front surface of the mast. So theres nothing special that I'm aware of. Flick through recent threads on this forum, you'll find some info on the mast hounds and diamond attachment points.
Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: soggy]
#85369 09/25/06 05:49 AM 09/25/06 05:49 AM |
Posts: 461 Victoria, Oztralia | Gday Paul
I could probably be corrected on this but, I've sailed a few sloop boats, we never had a downhaul for the jib, unless you really want it, I would set up from the beach.
Nice job on the boat by the way! Did you do it yourself? Really good finish.
Regards
Matt
Matt Harper
[Re: soggy]
#85371 09/25/06 06:24 AM 09/25/06 06:24 AM |
Posts: 556 Somers, Westernport Bay, Victo... | Paul,
Before you get rid of the luff control try it out in a few races. It probably won't be needed in heavy weather but it may make all the difference to jib shape and the jib slot in medium to light winds. Our club champion has luff control and uses it to his advantage. When you're looking for those extra metres it might just be the thing that gets you over the line first. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Peter
[Re: joey]
#85373 09/26/06 01:55 AM 09/26/06 01:55 AM |
Joined: Feb 2006 Posts: 135 Bendigo, Victoria, Australia colmc
Posts: 135 Bendigo, Victoria, Australia | G'day Joey,
Where do you come from?
If you're going to be anywhere near Lake Bonney, Barmara, S.A., on the weekend of 30/09 & 01/10 a group of Mozzie sailors will be there and would be only too happy to look at your boat and help you with what is required to get it going. You could also look at some other boats and get ideas you might like to try. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Col "Now What?" Mosquito 1810
[Re: soggy]
#85374 09/26/06 06:49 AM 09/26/06 06:49 AM | Anonymous
| Anonymous
Unregistered | Hi Paul,
I had a similar system on my sloop rigged Mossie and the crew adjusted it a fair bit, downwind to upwind as the forestay went slacker downwind, tighter upwind and for different wind strengths. Some newer Mossies use a single line system from the Halyard down the mast, which is not so obvious but does the same thing.
Hey if you are in Canberra keep in touch with any regattas worth coming to, as you are only 5hrs. away for Tim and 4hrs for Neil, I wouldn't mind doing some either, although I don't have a Mossie these days. I can help with rig set up though <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />. Maybe you could visit down here, (Gippsland Lakes) some time it's warmer <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />.
Regards Gary. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> | | | Re: Help with rigging old Mosquito
[Re: joey]
#85376 09/26/06 07:19 AM 09/26/06 07:19 AM |
Posts: 556 Somers, Westernport Bay, Victo... | Joe,
It appears that Mozzies are really coming out of the sheds/backyards/cobwebs. We are seeing some phenomenal growth. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
As for lashing a block to the boom and using a D ring and spectra for mast rotation control, try tying the spectra around the boom and put the D ring and block on the end of the mast rotation spanner then run the spectra back onto the boom and tie it off. At least it will give you some measure of mast rotation control all be it temporary. Set the mast rotation to match the leeward curve of the sail before you leave the beach; it's just a starting point.
Did you get your gooseneck problem sorted out ? You don't want that to get free and out of control.
Peter
[Re: joey]
#85378 09/26/06 11:26 PM 09/26/06 11:26 PM | Anonymous
| Anonymous
Unregistered | Hi Joe,
are you near Forster NSW? Come along to the Great Lakes S.C. this weekend and look for the Botany Blue F16 and say hello, I can probably help you with some of the questions.
Regards Gary. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | | Re: Help with rigging old Mosquito
[Re: joey]
#85382 09/29/06 05:03 PM 09/29/06 05:03 PM |
You would possibly be looking a Riley Fitting, RM 85, Pin type gooseneck with slide to fit RM 103 track, spring loaded plunger pin locates slide in position on track. Pin diameter 9.5mm. Find someone who stocks Riley, possibly whitworths.com.au or binksonline.com.au, and you can buy over internet.
Regards
Matt Harper
[Re: joey]
#85384 09/30/06 04:03 AM 09/30/06 04:03 AM |
Posts: 461 Victoria, Oztralia | I may have given you a bit of a bum steer with whitworths or binks, I've just had a look and couldn't find them. Are you in Vic? Not that it probably matters anyway but, get onto www.victoriansailingsupplies.com.au, fellas name is Matt Kelly, he'll help you out, no worries. Good Bloke, and good friend of mine, should have suggested him first off, but I was thinking more of online shopping. SORRY just looked back and saw your in NSW, but still that won't matter, you can still order through VSS. Regards
Matt Harper
2,429
guests, and 653
